Electrical Connector - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Electrical Connector (/showthread.php?tid=6590) |
Electrical Connector - bubblerboy64 - 04-13-2008 04:54 I am trying to find an electrical connector so that I can make up another cable to plug in the the "Big Napper". I am looking for a part number or information to order a female plug to match the one I have. The connector is a Crouse-Hinds and it says 30A 125/250V on the edge of the plug. In the center of the plug are the letters AH. I can not find a plug to match. The coach is old and I suspect this plug is discontinued. Anyone have one or can you direct me to a source. John Heckman central Pa 1973 FC Electrical Connector - Joe Garner - 04-13-2008 05:07 Check on the Hubbell site, they have a chart that shows all the plug configurations... https://www.hubbellnet.com/max_htm/tech_stuff/NEMA/front.html You should be able to find the plug there... HTH, Joe bubblerboy64 wrote: > > > I am trying to find an electrical connector so that I can make up > another cable to plug in the the "Big Napper". I am looking for a part > number or information to order a female plug to match the one I have. > The connector is a Crouse-Hinds and it says 30A 125/250V on the edge of > the plug. In the center of the plug are the letters AH. I can not > find a plug to match. The coach is old and I suspect this plug is > discontinued. Anyone have one or can you direct me to a source. > John Heckman > central Pa > 1973 FC > > __._ Electrical Connector - bubblerboy64 - 04-13-2008 05:56 Joe, That's the problem. Can't seem to get even close. John > > Check on the Hubbell site, they have a chart that > shows all the plug configurations... > > https://www.hubbellnet.com/max_htm/tech_stuff/NEMA/front.html > > You should be able to find the plug there... > > HTH, Joe > > > > bubblerboy64 wrote: > > > > > > I am trying to find an electrical connector so that I can make up > > another cable to plug in the the "Big Napper". I am looking for a part > > number or information to order a female plug to match the one I have. > > The connector is a Crouse-Hinds and it says 30A 125/250V on the edge of > > the plug. In the center of the plug are the letters AH. I can not > > find a plug to match. The coach is old and I suspect this plug is > > discontinued. Anyone have one or can you direct me to a source. > > John Heckman > > central Pa > > 1973 FC > > > > __._ > Electrical Connector - bubblerboy64 - 04-13-2008 10:36 Solved that one. I took the male plug off of the coach and replaced it with another 30A plug for which I could find connectors and just started over. Very similar plug. When I removed it I found the ground wire wasn't even connected so I fixed that while I was at it. The other end of the wires are the standard 30 amp plugs common to camp grounds. Why the odd ball connect on the coach who knows. I just used a standard L6 30A twist connector. Rated the same and I am good to go. I want a couple leads for different applications. The one which came with coach is 8 gage and two heavy to be used just to plug into the 110 to charge the batteries. Yes I know not to run the air conditioner or micro wave on light wires but I can't do that at the house anyway. I don't have a 30A service (yet). Got a good bit done today. John Heckman central Pa 1973 FC. Mike good luck with the Doc's and the coach. > > Joe, That's the problem. Can't seem to get even close. John > > > > > > > > Check on the Hubbell site, they have a chart that > > shows all the plug configurations... > > > > https://www.hubbellnet.com/max_htm/tech_stuff/NEMA/front.html > > > > You should be able to find the plug there... > > > > HTH, Joe > > > > > > > > bubblerboy64 wrote: > > > > > > > > > I am trying to find an electrical connector so that I can make up > > > another cable to plug in the the "Big Napper". I am looking for a > part > > > number or information to order a female plug to match the one I > have. > > > The connector is a Crouse-Hinds and it says 30A 125/250V on the > edge of > > > the plug. In the center of the plug are the letters AH. I can not > > > find a plug to match. The coach is old and I suspect this plug is > > > discontinued. Anyone have one or can you direct me to a source. > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > __._ > > > |
