Generator fixed, for now!! - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Generator fixed, for now!! (/showthread.php?tid=6592) |
Generator fixed, for now!! - thomas_sorrentino - 04-13-2008 12:16 While at Maxton last weekend my generator just quit. It was raining to hard to take a look at it and John was kind enough to let me plug into his 30 buddy plug. The generator motor would start and stay running as long as the start switch was held in or the fuel solenoid held in. It was producing no AC voltage on the gages and the fan wasn't running. I found that on one of the brushes the little wire had broken off. Now this had happened before not that long ago (less than a year). So I took a closer look at the (slip rings?) part the brushes rub on. The most forward ring, the one that the brush was broke on, is not a nice round shape (looking at it from the end). It has a 1/8" deep grove worn but only over approx. 1/3 of the circle. So now I think I know why I'm going thru brushes. How big of a job is it to replace those rings? Are they even replacable, or should I just buy brushes by the case? Tom Sorrentino 1987 PT38 Bedford Hills, NY 12.5 KW Yanmar/Kohler Generator fixed, for now!! - Scott Forman - 04-13-2008 12:41 Tom, Had the same thing happen to me a few months ago. Gen quit putting out AC, found to be bad brush. Brushes replaced. Gen ran for approximately 6 hours before quitting again. Determined that slip ring and other parts too worn to be reliable, would just keep eating brushes. Initially decided to purchase entire new brushless head unit for a few grand. Mechanic spent some time looking at old unit and determined that slip rings could be pressed out and replaced. With that in mind, decision made to replace all the replacable parts inside the generator (rings, bearings, brushes) and put it back on. Cost of doing all this was half what the new head unit would have cost, and it is basically a brand new generator now. Even though it is "previous generation" technology, it should be reliable for another 20 years just like the original was. There are lots and lots of old brush-style generators used in marine applications every day. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > While at Maxton last weekend my generator just quit. It was raining to > hard to take a look at it and John was kind enough to let me plug into > his 30 buddy plug. > The generator motor would start and stay running as long as the start > switch was held in or the fuel solenoid held in. > It was producing no AC voltage on the gages and the fan wasn't running. > I found that on one of the brushes the little wire had broken off. Now > this had happened before not that long ago (less than a year). So I > took a closer look at the (slip rings?) part the brushes rub on. The > most forward ring, the one that the brush was broke on, is not a nice > round shape (looking at it from the end). It has a 1/8" deep grove worn > but only over approx. 1/3 of the circle. So now I think I know why I'm > going thru brushes. How big of a job is it to replace those rings? Are > they even replacable, or should I just buy brushes by the case? > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > 12.5 KW Yanmar/Kohler > Generator fixed, for now!! - thomas_sorrentino - 04-13-2008 13:57 Scott, Were they able to do that without pulling the gen. out of the coach? Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Tom, > > Had the same thing happen to me a few months ago. Gen quit putting > out AC, found to be bad brush. Brushes replaced. Gen ran for > approximately 6 hours before quitting again. Determined that slip > ring and other parts too worn to be reliable, would just keep eating > brushes. Initially decided to purchase entire new brushless head > unit for a few grand. Mechanic spent some time looking at old unit > and determined that slip rings could be pressed out and replaced. > With that in mind, decision made to replace all the replacable parts > inside the generator (rings, bearings, brushes) and put it back on. > Cost of doing all this was half what the new head unit would have > cost, and it is basically a brand new generator now. Even though it > is "previous generation" technology, it should be reliable for > another 20 years just like the original was. There are lots and lots > of old brush-style generators used in marine applications every day. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > While at Maxton last weekend my generator just quit. It was raining > to > > hard to take a look at it and John was kind enough to let me plug > into > > his 30 buddy plug. > > The generator motor would start and stay running as long as the > start > > switch was held in or the fuel solenoid held in. > > It was producing no AC voltage on the gages and the fan wasn't > running. > > I found that on one of the brushes the little wire had broken off. > Now > > this had happened before not that long ago (less than a year). So I > > took a closer look at the (slip rings?) part the brushes rub on. > The > > most forward ring, the one that the brush was broke on, is not a > nice > > round shape (looking at it from the end). It has a 1/8" deep grove > worn > > but only over approx. 1/3 of the circle. So now I think I know why > I'm > > going thru brushes. How big of a job is it to replace those rings? > Are > > they even replacable, or should I just buy brushes by the case? > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > 12.5 KW Yanmar/Kohler > > > Generator fixed, for now!! - Scott Forman - 04-13-2008 14:17 No, it was pulled Scott --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Scott, > > Were they able to do that without pulling the gen. out of the coach? > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > Tom, > > > > Had the same thing happen to me a few months ago. Gen quit putting > > out AC, found to be bad brush. Brushes replaced. Gen ran for > > approximately 6 hours before quitting again. Determined that slip > > ring and other parts too worn to be reliable, would just keep > eating > > brushes. Initially decided to purchase entire new brushless head > > unit for a few grand. Mechanic spent some time looking at old unit > > and determined that slip rings could be pressed out and replaced. > > With that in mind, decision made to replace all the replacable > parts > > inside the generator (rings, bearings, brushes) and put it back > on. > > Cost of doing all this was half what the new head unit would have > > cost, and it is basically a brand new generator now. Even though > it > > is "previous generation" technology, it should be reliable for > > another 20 years just like the original was. There are lots and > lots > > of old brush-style generators used in marine applications every day. > > > > Scott Forman > > 86 PT38 > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > > > > While at Maxton last weekend my generator just quit. It was > raining > > to > > > hard to take a look at it and John was kind enough to let me plug > > into > > > his 30 buddy plug. > > > The generator motor would start and stay running as long as the > > start > > > switch was held in or the fuel solenoid held in. > > > It was producing no AC voltage on the gages and the fan wasn't > > running. > > > I found that on one of the brushes the little wire had broken > off. > > Now > > > this had happened before not that long ago (less than a year). So > I > > > took a closer look at the (slip rings?) part the brushes rub on. > > The > > > most forward ring, the one that the brush was broke on, is not a > > nice > > > round shape (looking at it from the end). It has a 1/8" deep > grove > > worn > > > but only over approx. 1/3 of the circle. So now I think I know > why > > I'm > > > going thru brushes. How big of a job is it to replace those > rings? > > Are > > > they even replacable, or should I just buy brushes by the case? > > > > > > Tom Sorrentino > > > 1987 PT38 > > > Bedford Hills, NY > > > 12.5 KW Yanmar/Kohler > > > > > > |
