8v92 will not crank update-bad starter??? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 8v92 will not crank update-bad starter??? (/showthread.php?tid=6619) |
8v92 will not crank update-bad starter??? - Scott Forman - 04-20-2008 07:39 My day of troubleshooting tells me that I have a bad starter. When the starter is engaged by the key, the solenoids click and the starter itself makes a loud click but does not turn. The same starter click happens when jumping across the solenoid. I can turn the crankshaft with a wrench, so it's not locked up (thank God). The starter has not exactly been what I would call 'strong' for the year I have owned the coach anyway, and it looks plenty old, so I am thinking it just gave up the ghost. Agree/disagree? Scott Forman 86 PT38 Memphis 8v92 will not crank update-bad starter??? - Richard Gideon - 04-20-2008 08:51 Scott: Try clamping a heavy jumper cable from the starter housing to a good battery ground...easy to do and is an additional way to rule out have a bad ground. Dick Gideon 1989 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > My day of troubleshooting tells me that I have a bad starter. When the > starter is engaged by the key, the solenoids click and the starter > itself makes a loud click but does not turn. The same starter click > happens when jumping across the solenoid. I can turn the crankshaft > with a wrench, so it's not locked up (thank God). The starter has not > exactly been what I would call 'strong' for the year I have owned the > coach anyway, and it looks plenty old, so I am thinking it just gave up > the ghost. > > Agree/disagree? > > Scott Forman > 86 PT38 > Memphis > |
