Alcoa Wheels - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Alcoa Wheels (/showthread.php?tid=666) |
Alcoa Wheels - Jack & Donna Smith - 05-22-2005 05:39 Noted on Ebay: 8 used 11X24.5 Budd Alcoa Aluminum Wheels. $610 as of now. Wont fit MY Bird!! Darn!! Ebay # 4550764417 Jack Smith Alcoa Wheels - Jeff Miller - 05-22-2005 05:58 The low-profile 275 24.5 is the same diameter as an 11Rx22.5 or a 10.00x20. - Jeff Miller http://www.millercoachworks.com http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > Noted on Ebay: > 8 used 11X24.5 Budd Alcoa Aluminum Wheels. $610 as of now. > Wont fit MY Bird!! Darn!! > Ebay # 4550764417 > Jack Smith Alcoa Wheels - Dennis Nichols - 05-22-2005 12:52 At 5/22/2005 12:39 PM, you wrote: >8 used 11X24.5 Budd Alcoa Aluminum Wheels. $610 as of now. >Wont fit MY Bird!! Darn!! >Ebay # 4550764417 Now $710 and 25 hours to go. But the reason I'm writing is that I think the specification of 11x24.5 is wrong. It is likely that these are 8.25x24.5 wheels on which the owner ran 11x24.5 tires. -- Dennis Nichols '88 WB40 XXV "Priscilla" -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.322 / Virus Database: 266.11.15 - Release Date: 5/22/2005 Alcoa Wheels - Steve Pfiffner - 08-22-2007 05:25 SW Wheel in Dallas is a big stocking distributor with online prices http://www.southwestwheel.com/ Steve BB Wannabee Alcoa Wheels - bubblerboy64 - 02-27-2008 08:22 I've been lookin' for a while and I have a lead which might work out. Quick question. My ole 73 has the axles off a 1984 I believe. I am assuming that the wheels will fit. The alcoa's are off a BB bus. Before I get into this too deep would the wheels on the pushers be the same as the FC's? I know I have not provided much information but if the wheels on the pushers don't fit the FC's then my hunt continues. My bus has 22.5 inch steel wheels. Ten bolt stud piloted but beyond that I will have to reseach. Thanks in advance. John Heckman central Pa 1973 FC Alcoa Wheels - Leroy Eckert - 02-27-2008 08:56 I do not know if this will help. When I changed my valve stems I found that pre-1995 22.5" Alcoa's have a two inch round hand hole. Later models have two and one half inch handhole. It is a ten lug set up. Classifications were for motor homes and buses-diesel so one might conclude they are the same for those years. Perhaps someone else may have more info. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion bubblerboy64
Looking for last minute shopping deals? Find them fast with Yahoo! Search. Alcoa Wheels - bubblerboy64 - 02-27-2008 09:20 Well, Just a little more information, The wheels are off a pusher mid eighties. They are stud piloted and 22.5 inches which is what I need but beyond that the fellow parting out the bus doesn't know. So any information would be appreciated. I tried call BB and to this point have only been able to talk to an answering machine. I'd like be able to tell the fellow ASAP that I will take them so they don't get gone. John Heckman central Pa 1973 FC > > I do not know if this will help. > When I changed my valve stems I found that pre-1995 22.5" Alcoa's have a two inch round hand hole. Later models have two and one half inch handhole. It is a ten lug set up. Classifications were for motor homes and buses-diesel so one might conclude they are the same for those years. Perhaps someone else may have more info. > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > bubblerboy64 been lookin' for a while and I have a lead which might work out. > Quick question. My ole 73 has the axles off a 1984 I believe. I am > assuming that the wheels will fit. The alcoa's are off a BB bus. > Before I get into this too deep would the wheels on the pushers be the > same as the FC's? I know I have not provided much information but if > the wheels on the pushers don't fit the FC's then my hunt continues. My > bus has 22.5 inch steel wheels. Ten bolt stud piloted but beyond that I > will have to reseach. Thanks in advance. > John Heckman > central Pa > 1973 FC > > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > Alcoa Wheels - Leroy Eckert - 02-27-2008 09:27 Call this company. They make specialty valve stems for dual wheels, steel and Alcoa. He was very helpful. Plus, I like his product. Borg Equipment Supply, Tujunga, CA 800-300-2674 or 818-352-8717 Leroy Eckert 1990 WB -40 Smoke N Mirrors Dahlonega, GA Royale Conversion bubblerboy64
Looking for last minute shopping deals? Find them fast with Yahoo! Search. Alcoa Wheels - Mike Hohnstein - 02-27-2008 10:06 The only concern is the width. 83s came with 7.5s, ya want 8.25" wide. 10 bolt stud pilot is older, careful you don't get sold some hub pilot. Ya gotta watch the bead seat area, it can get worn out, sharp edge that can cut into the tire bead.
MH
Alcoa Wheels - lcondosta - 02-29-2008 10:51 --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: >I have four firestone original oem 85 pt40 22.5X8.25 Lee Condosta85PT40 Holden Beach N.C > I've been lookin' for a while and I have a lead which might work out. > Quick question. My ole 73 has the axles off a 1984 I believe. I am > assuming that the wheels will fit. The alcoa's are off a BB bus. > Before I get into this too deep would the wheels on the pushers be the > same as the FC's? I know I have not provided much information but if > the wheels on the pushers don't fit the FC's then my hunt continues. My > bus has 22.5 inch steel wheels. Ten bolt stud piloted but beyond that I > will have to reseach. Thanks in advance. > John Heckman > central Pa > 1973 FC > |
