1988 PT38 Ft. at CW in Pooler Ga. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1988 PT38 Ft. at CW in Pooler Ga. (/showthread.php?tid=6686) |
1988 PT38 Ft. at CW in Pooler Ga. - Howard O. Truitt - 05-02-2008 01:25 Fellows,
My brother and I went over to Camping World at Pooler, Ga. to Check out the 88 PT38 listed in RV Trader for $39,900.00.
IMHO it is a basket case. No Blue Box or maintenance records. The oil in the engine and generator was black, black.The engine cranked and smoked heavy for about 15 minutes. After warming up oil pressure showed about 8 lbs. on high idle.We could not crank the generator.We did not road test it. I did not feel safe taking it off the lot. I saw three different brands of tires on passenger side. The inside was very heavily worn.It would take an hour to go through the list of negatives on the bus.I was not interested inthat challenge. I'm sure someone else may find it a challenge worth taking on.
The only positive about the trip was a pleasant day spent with my brother.
Howard Truitt
Camilla, Ga.
86 PT40
1988 PT38 Ft. at CW in Pooler Ga. - p_a_lazar - 05-02-2008 07:48 And all this time you thought Camping World slipped up. ![]() Paul 97wb43 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Fellows, > My brother and I went over to Camping World at Pooler, Ga. to Check out the 88 PT38 listed in RV Trader for $39,900.00. > IMHO it is a basket case. No Blue Box or maintenance records. The oil in the engine and generator was black, black. The engine cranked and smoked heavy for about 15 minutes. After warming up oil pressure showed about 8 lbs. on high idle. We could not crank the generator. We did not road test it. I did not feel safe taking it off the lot. I saw three different brands of tires on passenger side. The inside was very heavily worn. It would take an hour to go through the list of negatives on the bus. I was not interested in that challenge. I'm sure someone else may find it a challenge worth taking on. > The only positive about the trip was a pleasant day spent with my brother. > Howard Truitt > Camilla, Ga. > 86 PT40 > 1988 PT38 Ft. at CW in Pooler Ga. - Gregory OConnor - 05-02-2008 19:05 Paul, the safest advice is to not play but no one ever won who did not play. a good dealer wont go out of the way to hide the clues to isues too big for the buyer to tackle. Bravo to CampingWorld. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "p_a_lazar" wrote: > > And all this time you thought Camping World slipped up. ![]() > > Paul > 97wb43 > > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > Fellows, > > My brother and I went over to Camping World at Pooler, Ga. to Check > out the 88 PT38 listed in RV Trader for $39,900.00. > > IMHO it is a basket case. No Blue Box or maintenance records. The > oil in the engine and generator was black, black. The engine cranked > and smoked heavy for about 15 minutes. After warming up oil pressure > showed about 8 lbs. on high idle. We could not crank the generator. We > did not road test it. I did not feel safe taking it off the lot. I saw > three different brands of tires on passenger side. The inside was very > heavily worn. It would take an hour to go through the list of > negatives on the bus. I was not interested in that challenge. I'm sure > someone else may find it a challenge worth taking on. > > The only positive about the trip was a pleasant day spent with my > brother. > > Howard Truitt > > Camilla, Ga. > > 86 PT40 > > > |
