Hub problem resolved - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Hub problem resolved (/showthread.php?tid=673) |
Hub problem resolved - geez_al - 05-23-2005 05:05 If anyone is interested. If anyone is interested. It turns out that there is a larger reservoir then can be seen in the sight glass of the hub. When the installer put in the new hubs he neglected to completely fill the hub so I wasn't seeing any level. He used silicon on the paper gasket which caused a little leakage that clued me into the whole thing. Anyway, I put another 700 miles on the bus since topping off the hub level and replacing the gasket and everything looks good. Thanks again for the help. Al S. '81 31' FC Now in Sturgis, SD PS. The RV Park here in downtown Sturgis is only charging $12 per night while they're restrooms are being remodeled. Full hook-up's with 50 amp and 70 cable channels. Nice Park. In case anyone is traveling through in the next few weeks. [Non-text portions of this message have been removed] Hub problem resolved - randydupree - 05-23-2005 11:49 geez,al,your really getting around! have fun! randydupree93wb ----- Original Message ----- From: geez_al To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 23, 2005 1:05 PM Subject: [WanderlodgeForum] Hub problem resolved If anyone is interested. If anyone is interested. It turns out that there is a larger reservoir then can be seen in the sight glass of the hub. When the installer put in the new hubs he neglected to completely fill the hub so I wasn't seeing any level. He used silicon on the paper gasket which caused a little leakage that clued me into the whole thing. Anyway, I put another 700 miles on the bus since topping off the hub level and replacing the gasket and everything looks good. Thanks again for the help. Al S. '81 31' FC Now in Sturgis, SD PS. The RV Park here in downtown Sturgis is only charging $12 per night while they're restrooms are being remodeled. Full hook-up's with 50 amp and 70 cable channels. Nice Park. In case anyone is traveling through in the next few weeks. [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
