Detroit Diesel Coolant Info. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Detroit Diesel Coolant Info. (/showthread.php?tid=6799) |
Detroit Diesel Coolant Info. - Curt Sprenger - 06-01-2008 03:13 Good information to save. I'm finally getting around to installing a coolant filter. http://www.detroitdiesel.com/Public/brochures/7SE298.pdf -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Detroit Diesel Coolant Info. - Larry Kehler - 06-01-2008 08:58 Curt Which filter are you installing and where are you getting the unit? I have been thinking about the same install. Larry Kehler 94 PT40 WB "BAM" St. Louis --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Good information to save. I'm finally getting around to installing a coolant > filter. > > http://www.detroitdiesel.com/Public/brochures/7SE298.pdf > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > Detroit Diesel Coolant Info. - Curt Sprenger - 06-01-2008 09:44 Larry, I purchased the coolant filter adapter at our local big truck parts store. It's a WIX 24019. NAPA most likely has them or can order one; NAPA number is most likely 4019. NAPA drops the first number from a WIX number. The first filter will be a Wix 24074 (NAPA 4074). In a year or sooner the plan is to replace it with WIX 24071 (NAPA 4071). That will depend on how the coolant tests out. On Sun, Jun 1, 2008 at 1:58 PM, Larry Kehler <"llkehler@gmail.com"> wrote:
