Has anyone checked into this device?? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Has anyone checked into this device?? (/showthread.php?tid=6800) |
Has anyone checked into this device?? - Jon - 06-01-2008 15:34 http://www.runyourcarwithwater.com/?hop=watertt Has anyone checked into this device?? - Jack & Donna Smith - 06-01-2008 15:47 Yeah Jon: I dont think this is anything new, except the hype. Crosley made an attempt at a Sportscar in the 50s called the "HotShot" that used a water injection system. They ran a 10 or 10.5 compression, and used the water to control detonation, or something like that. I think they also said to add alchol to the mixture.. Oldsmobile had something similar on their small supercharged F85, during the same era, I think.. Wasn't something similar on the P-38 Lightning's turbochargers during WW-2 ? Jack Smith 73FC35 SoCal --- In WanderlodgeForum@yahoogroups.com, "Jon" > > http://www.runyourcarwithwater.com/?hop=watertt > Has anyone checked into this device?? - Curt Sprenger - 06-01-2008 16:13 Jack, A long time ago I tried these remedies on a 1979 Ford 460 engine. Even built a fuel pre-heater to atomize gasoline; along with water injection...the 460 got better HP/MPG, and no "ping"; pulled the trailer beyond belief. Not sure what this was doing to the engine. I abandoned the project because I was out of time. Perhaps I should dig this project out from the moth balls...might make a few bucks. On Sun, Jun 1, 2008 at 8:47 PM, Jack & Donna Smith <"jaxdon@cox.net"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Has anyone checked into this device?? - Gardner Yeaw - 06-02-2008 12:48 I read an article recently about someone who developed an engine that alternated between fuel and water injection. On the first cycles diesel was injected creating lots of heat and pushing the piston down, on the next cycles water was injected and converted to steam from the heat of compression and the residual heat from the first combustion stroke. This not only took advantage of the residual heat, it also cooled the engine so little other cooling was required. I believe it is still in the development stages, but it was a pretty good design. --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Jack, > > A long time ago I tried these remedies on a 1979 Ford 460 engine. Even built > a fuel pre-heater to atomize gasoline; along with water injection...the 460 > got better HP/MPG, and no "ping"; pulled the trailer beyond belief. Not sure > what this was doing to the engine. I abandoned the project because I was out > of time. Perhaps I should dig this project out from the moth balls...might > make a few bucks. > > > On Sun, Jun 1, 2008 at 8:47 PM, Jack & Donna Smith wrote: > > > Yeah Jon: I dont think this is anything new, except the hype. > > Crosley made an attempt at a Sportscar in the 50s called the "HotShot" > > that used a water injection system. They ran a 10 or 10.5 > > compression, and used the water to control detonation, or something > > like that. I think they also said to add alchol to the mixture.. > > Oldsmobile had something similar on their small supercharged F85, > > during the same era, I think.. > > Wasn't something similar on the P-38 Lightning's turbochargers during > > WW-2 ? > > Jack Smith > > 73FC35 > > SoCal > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "Jon" > > > > > > http://www.runyourcarwithwater.com/?hop=watertt > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > Has anyone checked into this device?? - Gardner Yeaw - 06-02-2008 12:54 Here is the article. http://thekneeslider.com/archives/2006/02/24/crower-six-stroke- engine/ Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > I read an article recently about someone who developed an engine > that alternated between fuel and water injection. On the first > cycles diesel was injected creating lots of heat and pushing the > piston down, on the next cycles water was injected and converted to > steam from the heat of compression and the residual heat from the > first combustion stroke. This not only took advantage of the > residual heat, it also cooled the engine so little other cooling was > required. > > I believe it is still in the development stages, but it was a > pretty good design. > > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > Jack, > > > > A long time ago I tried these remedies on a 1979 Ford 460 engine. > Even built > > a fuel pre-heater to atomize gasoline; along with water > injection...the 460 > > got better HP/MPG, and no "ping"; pulled the trailer beyond > belief. Not sure > > what this was doing to the engine. I abandoned the project because > I was out > > of time. Perhaps I should dig this project out from the moth > balls...might > > make a few bucks. > > > > > > On Sun, Jun 1, 2008 at 8:47 PM, Jack & Donna Smith > wrote: > > > > > Yeah Jon: I dont think this is anything new, except the hype. > > > Crosley made an attempt at a Sportscar in the 50s called > the "HotShot" > > > that used a water injection system. They ran a 10 or 10.5 > > > compression, and used the water to control detonation, or > something > > > like that. I think they also said to add alchol to the mixture.. > > > Oldsmobile had something similar on their small supercharged F85, > > > during the same era, I think.. > > > Wasn't something similar on the P-38 Lightning's turbochargers > during > > > WW-2 ? > > > Jack Smith > > > 73FC35 > > > SoCal > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > "Jon" > > > > > > > > http://www.runyourcarwithwater.com/?hop=watertt > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > Has anyone checked into this device?? - Hugh Turner - 06-04-2008 19:19
