Minimal CCC that you would accept - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Minimal CCC that you would accept (/showthread.php?tid=6839) |
Minimal CCC that you would accept - Ross - 06-10-2008 04:42 Hi, If you were looking at a new tag axle coach, what would you accept as a CCC (coach carrying capacity) CCC is a standard term used by the RV industry and is : GVWR less: UVW (unloaded vehicle weight) less: Full fuel weight less:full water less: SCWR (sleeping capacity - 4 x 154 lbs.) = CCC GVWR - UVW - fuel - water(1000 lbs) - SCWR (616 lbs) = CCC or GVWR - wet weight - SCWR = CCC Before year 2000 they used NCC net carrying capacity. For Interest, reviewing Trailer Life, the tag axle RV's range from a low of 3300 lbs for the Monaco Dynasty to 9436 lbs for the Newmar Mountain Aire The Allegro Bus is 4018 Lbs Travel Supreme Select 6418 lbs. Would you accept 3000 lbs. Would you worry about resale if this was a new coach? Thanks, Ross 450 LXi Minimal CCC that you would accept - Pete Masterson - 06-10-2008 06:30 In a large, tag axle class A, a 3000 lb. CCC is way too small -- it's way too easy to overload an axle (even if you don't exceed the 3000 lbs.) when the CCC is that low. I suppose that a CCC of 5000+ lbs would generally be adequate for most folks -- it would give some flexibility in loading when considering the weight distribution. Personally, the more CCC (within reason) the better. Indeed, the recent recall of 450lxi due to the front axle overload is an obvious problem that lack of CCC can have. I note that when I'm fully loaded for a long trip, we have about 1000# of our GVWR available -- that's not a lot of margin, as filling the fresh tank without dumping the black and gray tank could put you right up to or over the GVWR without realizing it. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jun 10, 2008, at 9:42 AM, Ross wrote:
