insulation - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: insulation (/showthread.php?tid=684) |
insulation - Stephen Birtles - 05-24-2005 05:16 We have just recieved a new shipment of composite insulation 1inch foam, vinyl blocker 1/4 inch foam, Faced on one side with fiber reinforced mylar and hi temp pressure sensitive adhesive on the other Size 24x 54 Priced at 47.00 per sheet plus shipping 3 sheet bundles 40.00 per sheet plus shipping shipping based on 34 pounds from 14305 Stephen 77fc35 insulation - Stephen Birtles - 02-19-2006 19:11 We also have insulation with a high heat presure sensitve adhesive already applied. Have had my doghouse insulated for 2 years with no problems Stpehen 77fc35 insulation - erniecarpet@... - 02-19-2006 22:46 scott- stephen birtles sells the insulation and adhesive. ernie-83pt40 in louisiana [Non-text portions of this message have been removed] insulation - Scott Forman - 02-20-2006 03:15 Who is "we"...where do I get some of this? --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > We also have insulation with a high heat presure sensitve adhesive > already applied. > Have had my doghouse insulated for 2 years with no problems > Stpehen 77fc35 > insulation - Ernest Ekberg - 11-25-2008 10:00 I have just completed the insulation of Bob Lawrences generator compartment. I had previously, many years ago, used JC Whitney's material. Ralph has been doing that work the past few years and since he delegated me to do this task we chose insulation from Stephen Birtles. I thought Whitneys insulation was the best till I worked with this. Not only is it heavier but is thicker, also. Thank you, Stephen, very good product. Ernie-83PT40 in Texas insulation - Leroy Eckert - 11-25-2008 11:13
insulation - erniecarpet@... - 11-27-2008 07:12 Just like Don said, the hardest part, due to the fact that there is a steel plate suspended about 3 inches from the roof of the compartment, is scraping the old off. I have a long handled scraper with a razor blade and will try and work on Bob Lawrence's engine compartment probably after it warms up a bit tomorrow-- and after I burn off the volume of what I consumed, today.
Ernie Ekberg 83PT40 Wanderlodge Weatherford, Texas insulation - Jack and Liz Pearce - 11-27-2008 11:07 --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > I have just completed the insulation of Bob Lawrences generator > compartment. I had previously, many years ago, used JC Whitney's > material. Ralph has been doing that work the past few years and since > he delegated me to do this task we chose insulation from Stephen > Birtles. > I thought Whitneys insulation was the best till I worked with this. Not > only is it heavier but is thicker, also. > Thank you, Stephen, very good product. > Ernie-83PT40 in Texas > Could this insulation be used in the engine compartment? We have lost chunks of insulation which drops down on the hot engine and melts. Phew. TIA, Liz insulation - Donald Spithaler - 11-27-2008 11:32 Liz I put it in my engine compartment over three years ago & it is doing great. The hardest part of it was taking the old off. Don Spithaler 89 SP 36' Butler, PA On Thu, Nov 27, 2008 at 6:07 PM, Jack and Liz Pearce <"jacklizpearce@gmail.com"> wrote:
insulation - Stephen Birtles - 11-27-2008 14:29 Jack an Liz Yes you cam use in the engine compartment that is what was spec.ed for you can also use it for ares that need sound deadening If you have any questions please dont hesitate to call me Use my quarter 888 668 4288 Stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > > --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > > > I have just completed the insulation of Bob Lawrences generator > > compartment. I had previously, many years ago, used JC Whitney's > > material. Ralph has been doing that work the past few years and since > > he delegated me to do this task we chose insulation from Stephen > > Birtles. > > I thought Whitneys insulation was the best till I worked with this. > Not > > only is it heavier but is thicker, also. > > Thank you, Stephen, very good product. > > Ernie-83PT40 in Texas > > > > Could this insulation be used in the engine compartment? We have lost > chunks of insulation which drops down on the hot engine and melts. > Phew. > > TIA, > Liz > |
