dump sensor light - Printable Version
+--- Thread: dump sensor light (/showthread.php?tid=6854)
dump sensor light - Jim Riordan - 06-13-2008 14:38
1988 WBWL
I have been trying to resolve this problem. we got under the coach
today and found..
Checked all three dump indicator pressure switches front and tag
switches have two electrical leads drive axle has only one lead, a
question mark.
we aired up suspension tested each switch individually these switches
are normally closed..all showed open..however the indicator light is
still on. is there a relay for this system?? I am thinking that maybe
it has gone bad..
Thoughts
help
suggestions (reasonable)
would be greatly appreciated
Jim Riordan
88 WBWL XXV
stuart, fl
772-260-1328
dump sensor light - Gregory OConnor - 06-13-2008 16:35
Does the buzzer go off when the bags air up but the light stays on?
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "Jim Riordan"
> 1988 WBWL
> today and found..
> question mark.
switches
is
maybe
> it has gone bad..
> Thoughts
> help
> Jim Riordan
> 88 WBWL XXV
> stuart, fl
> 772-260-1328
dump sensor light - jim riordan - 06-15-2008 13:47
yup!
GregoryO'Connor
94ptRomolandCa
--- In "WanderlodgeForum%40yahoogroups.com", "Jim Riordan"
> 1988 WBWL
> today and found..
> question mark.
switches
is
maybe
> it has gone bad..
> Thoughts
> help
> Jim Riordan
> 88 WBWL XXV
> stuart, fl
> 772-260-1328
dump sensor light - Gregory OConnor - 06-15-2008 17:25
I think the light is a part of the suspension dump relay and
indicates that the relay is asked to dump????? The buzzer indicates
that the bags have dumped (a low pressure is achived). May be the
relay has a fault and wont stop sending 12v to the light I tested my
light and it is grounded. on and off is the introduction of 12V+.
The dump fuse is sk32 near the parklight fuse "lower front load
center K38?????? It is some sort of timed relay and may look
different. I realy have no Idea where it is these are just some
hints from the plans I have yet sent to kinko's
--- In WanderlodgeForum@yahoogroups.com, jim riordan
> yup!
light stays on?
> GregoryO'Connor
> 94ptRomolandCa
> > 1988 WBWL
coach
> > today and found..
a
> > question mark.
> switches
light
> is
> maybe
> > it has gone bad..
> > Thoughts
> > help
> > Jim Riordan
> > 88 WBWL XXV
> > stuart, fl
> > 772-260-1328
dump sensor light - jim riordan - 06-16-2008 14:29
Greg thanks..
Jessie says.. there are three low pressure sensor switchs on my coach. one is for steering and drive axle up front axle one is for tag axle by tag axle. and another one apparently near thefront load by the generatorfan there is supposed another sensor, something to do with the brake system?? I will try to locate it tomorrow and update..
Jim Riordan
--- In "WanderlodgeForum%40yahoogroups.com", jim riordan
> yup!
light stays on?
> GregoryO'Connor
> 94ptRomolandCa
> > 1988 WBWL
coach
> > today and found..
a
> > question mark.
> switches
light
> is
> maybe
> > it has gone bad..
> > Thoughts
> > help
> > would be
greatly appreciated
> > Jim Riordan
> > 88 WBWL XXV
> > stuart, fl
> > 772-260-1328
dump sensor light - Gregory OConnor - 06-16-2008 19:03
The pressure switch is turning off the buzzer! If some on is in
their '88ish pt coach could you check to see what turns the light
on, is it a throw of the switch to dump???? or does it only come one
once the buzzer sounds????
I still think it is the relay and not a switch
GregoryO'Connor
94ptRomolandCa
> Greg thanks..
tag axle by tag axle. and another one apparently near the front load
by the generator fan there is supposed another sensor, something to
update..
> Jim Riordan
indicates
my
> > yup!
> light stays on?
> > GregoryO'Connor
> > 94ptRomolandCa
> > wrote:
> > > 1988 WBWL
> coach
> > > today and found..
tag
lead,
> a
> > > question mark.
> > switches
> light
> > is
that
> > maybe
> > > it has gone bad..
> > > Thoughts
> > > help
> > > Jim Riordan
> > > 88 WBWL XXV
> > > stuart, fl
> > > 772-260-1328
dump sensor light - Drew May - 06-17-2008 07:37
FYI, just had my coach at Buddy Gregg with the exact same issue on my 1988 WB40 and they replaced a bad relay which apparently is going to resolve the issue.
--- On Tue, 6/17/08, Gregory OConnor wrote:
Subject: [WanderlodgeForum] Re: dump sensor light
Date: Tuesday, June 17, 2008, 12:03 AM
GregoryO'Connor
94ptRomolandCa
> Greg thanks..
update..
> Jim Riordan
indicates
my
> > yup!
> > Gregory OConnor
> light stays on?
> > GregoryO'Connor
> > 94ptRomolandCa
> > wrote:
> > > 1988 WBWL
> coach
> > > today and found..
tag
lead,
> a
> > > question mark.
> > switches
> light
> > is
that
> > maybe
> > > it has gone bad..
> > > Thoughts
> > > help
> > > Jim Riordan
> > > 88 WBWL XXV
> > > stuart, fl
> > > 772-260-1328
dump sensor light - Mike McMahan - 06-17-2008 08:45
Drew, Do you know which relay they replaced. Thanks, MIke Mcmahan
--- In WanderlodgeForum@yahoogroups.com, Drew May
> --- On Tue, 6/17/08, Gregory OConnor Gregoryoc@... wrote:
> From: Gregory OConnor Gregoryoc@...
one
> GregoryO'Connor
> 94ptRomolandCa
> --- In WanderlodgeForum@ yahoogroups. com, jim riordan jqrjr@
> > Greg thanks..
my
load
> update..
> > Jim Riordan
> and
> indicates
tested
> my
12V+.
load
some
<jqrjr@>
> > wrote:
> > > yup!
> > light stays on?
> > > GregoryO'Connor
> > > 94ptRomolandCa
> > > --- In WanderlodgeForum@ yahoogroups. com, "Jim Riordan"
<jqrjr@>
> > > wrote:
> > > > 1988 WBWL
under the
> > coach
> > > > today and found..
front and
> tag
only one
> lead,
> > a
> > > > question mark.
individually these
> > > switches
indicator
> > light
> > > is
thinking
> that
> > > maybe
> > > > it has gone bad..
> > > > Thoughts
> > > > help
> > > > Jim Riordan
> > > > 88 WBWL XXV
> > > > stuart, fl
> > > > 772-260-1328
dump sensor light - jim riordan - 06-17-2008 14:10
do you lnow where that relay is??
Jim Riordan
772 260 1328
com>
GregoryO'Connor
94ptRomolandCa
> Greg thanks..
my
update..
> Jim Riordan
indicates
my
> > yup!
> light stays on?
> > GregoryO'Connor
> > 94ptRomolandCa
> > wrote:
> > > 1988 WBWL
> coach
> > > today and found..
tag
lead,
> a
> > > question mark.
> > switches
> light
> > is
that
> > maybe
> > > it has gone bad..
> > > Thoughts
> > > help
> > > Jim Riordan
> > > 88 WBWL XXV
> > > stuart, fl
> > > 772-260-1328
dump sensor light - Drew May - 06-17-2008 15:24
I do not, but I'm going to try and find out which one it was.
--- On Tue, 6/17/08, jim riordan wrote:
Subject: Re: [WanderlodgeForum] Re: dump sensor light
Date: Tuesday, June 17, 2008, 7:10 PM
Jim Riordan
772 260 1328
GregoryO'Connor
94ptRomolandCa
> Greg thanks..
sensor switchs on
my
update..
> Jim Riordan
indicates
my
these are just some
> > yup!
> light stays on?
> > GregoryO'Connor
> > 94ptRomolandCa
> > wrote:
> > > 1988 WBWL
> coach
> > > today and found..
front and
tag
lead,
> a
> > > question mark.
> > switches
> light
> > is
that
> > maybe
> > > it has gone bad..
> > > Thoughts
> > > help
> > > Jim Riordan
> > > 88 WBWL XXV
> > > stuart, fl
> > > 772-260-1328
