Sagging right front - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Sagging right front (/showthread.php?tid=6888) |
Sagging right front - Scott Forman - 06-21-2008 05:13 The right front corner of my coach is low. When I measure the ride heights, both sides of the rear are identical, but the right front is about an inch lower than the left front. I did a lot of work on my old FC air suspension, so I am pretty familiar with the system. If the rear ride heights are equal, that tells me that the rear height control valves (which also control left/right leveling) are working properly. Since the front has only one valve, I am at a loss for how it can be out of whack when the rear isn't. Suggestions? Scott Forman 86 PT38 Memphis Sagging right front - Curt Sprenger - 06-21-2008 05:26 Recycle the suspension a couple times and recheck. BB said the front (on the PT and might be the same for the FC) needs to be level. The '87 PT has one front leveling valve. To level the front, the rear could be off level (adjusted) and that is fine. On Sat, Jun 21, 2008 at 10:13 AM, Scott Forman <"scottforman75@gmail.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Sagging right front - Leroy Eckert - 06-21-2008 06:46
