Sporlan valves - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Sporlan valves (/showthread.php?tid=6903) |
Sporlan valves - erniecarpet@... - 06-24-2008 09:23 After so many years of having to do the "Ernie" fix- just loosening the bolts that hold the valve together, and letting some water flow out, I replaced the innards with Stephens kit. Now everything works great and all it took was 10 minutes. Don't forget that when you take the top of the valve off that you watch which way the little plunger actuator is psoitioned. I made the mistake when I operated on George Bush's coach last year of turning it upside down. it absolutely will not work that way.
Ernie Ekberg 83PT40 Livingston, Montana Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. Sporlan valves - williamcharrison - 06-24-2008 10:52 My cockpit roasts in the hot weather because I cannot turn off the front heaters. I am told that I must replace the Sporlan valves but I don't have any idea where they are located or how big a job it is to replace them. Help! Chuck Harrison Akron, Ohio 90SP36 Sporlan valves - Stephen Birtles - 06-24-2008 12:29 Chances are all you need is a rebuild kit fir the sporlan valves- we have them for sale on our website stephen 77fc35 dupreeproducts.com -- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > My cockpit roasts in the hot weather because I cannot turn off > the front heaters. I am told that I must replace the Sporlan valves > but I don't have any idea where they are located or how big a job it is > to replace them. > > Help! > > Chuck Harrison > Akron, Ohio > 90SP36 > Sporlan valves - pattypape - 06-24-2008 13:22 The Drawing of the Sporlan valve is in the files. This link may not work. Cut and paste or look in the files. <http://f1.grp.yahoofs.com/v1/kJhhSNdADN_NvupUHqeKGihCNgXtvhtEU7w56xxZ hQBeIQ334rqPdYSaxExFLPu2ItGsgU5ezfPbJMZtouvqZY8Op6cPpatG/Sporlan% 20Valve%2030-11.pdf> Four screws, a diaphragm, plunger and O ring seal. The trick is to find it, it is probably under the coach near the heater cores, follow the heater hoses. Stephen Birtles stocks the rebuild kits. BIll 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > My cockpit roasts in the hot weather because I cannot turn off > the front heaters. I am told that I must replace the Sporlan valves > but I don't have any idea where they are located or how big a job it is > to replace them. > > Help! > > Chuck Harrison > Akron, Ohio > 90SP36 > |
