Partial solution - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Partial solution (/showthread.php?tid=6912) |
Partial solution - Robin - 06-27-2008 09:26 --- In WanderlodgeForum@yahoogroups.com, "John Churchill" > > > I just purchased a 1980 FC33 and it's a bit of a project. The > original genset has been removed. A prior owner started to install a > Onan Marquis Gold 7kW unit. The 120V wiring is hooked up, but all the > 12V stuff is just a mess. Nothing labeled, loose wirenuts, etc. No > starting battery has been installed yet. I have just put in a ground > for the genset and pos/neg battery cables. > > My unidentified wires are: > 1) 2 reds joined with a wire nut in one loom > 2) 2 greens just loose with exposed ends in another loom > 3) one orange with a small ring terminal and a much longer purple (or > maybe brown) with a broken off terminal in their own loom > 4) one big black battery cable that does not have continuity to ground > or voltage from either the charger or the battery bank > > Things I know are disconnected are the microswitch for the door lock > indicator, the oil pressure and temp gauges (and the hour meter but I > thought that worked off one of the other leads.) There does not seem > be be a hot wire for battery charging present. > > Air slide cylinder is absent and the hose is just kinked off. > > Anyone able to identify which wires go where? An original wiring > diagram or picture of the factory installation would be helpful. > > John Churchill > Sanibel, FL > Big wire gets hot when I throw the "Aux Batt" switch, so it is to pos batt pole, not neg. |
