94pt 8v92 cooling lines to the aircompressor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 94pt 8v92 cooling lines to the aircompressor (/showthread.php?tid=6978) |
94pt 8v92 cooling lines to the aircompressor - Gregory OConnor - 08-08-2008 15:14 the coolant lines to the engine mounted aircompressor have proven to fail after 20 years. I think it is from the excess heat that gets trapped above the transmission / below bedroom.(not vented to engine bay, may be cause of heat in bedroom?). I replaced the coolant lines today as a PM (preventativeMaintenance) measure. there are two lines that run from the passanger side block to the compressor which is mounted above the transmission bell housing. one hose 28 inches long and the other about 8 inches long Short hose. there is a trap door under the carpet between rear dresser and the bed, just about center. I removed the carpeted baceboard box that covers wires and pipes, lifted the carpet and unscrewed a metal plate. under the wires is one more removable plate. the wire plate attaches to the wall behind the wires and to the floor. with both plates out you have easy access. the compressor has several lines 2 coolant 2 oil and two air. the coolant lines are at the top. a 7/8inch wrench is used to remove the swival end ( oil uses a 3/4) the short hose attaches to back of the block. when you remove the line you will see the coolant as a check Long hose. at the other end of the compressor head is the long hose attached to the compressor with a 7/8 swival fitting. the hose runs past the tranny mount between the frame and the block and reattaches to the block above the starter. I removed the compressor end and cut the hose to make it easy to slip thru a strap. with the bus jacked up wheels just on the ground,frame stands and chocks inplace, I reached over the starter (removed battery power and unplugged chargers) and found the attachement to the block. there are two lines attached to the block above the starter one is oil to the compressor. the one you want is the farthest reach and the swival is 7/8 and hose is larger than the oil. unable to get a full size wrench on the fitting I uses a "stubby whench". A 7/8crows foot and socket wrench would best serve to loosen the fitting but I used a bathroom sink wrench(?) (cheap long handel with a flip/flop little pipe wrench thing on the end). I made the long hose 5 inches longer as the OEM was jammed against the frame and 'flex tube vent'. Install the starter end fitting first to make it easy to line up the thread. I pointed the '90 degree fitting out of the block' downward a bit to help clear the 'frame pinch area'. I also bent the flex tube away frm the block for the new line. the hosefittings are reusable and I wanted to do so but I could not get high temp quickie tube. I had hydrolic line made but wonder how well hydrolic oil hose holds up to coolant product? took about one hour to remove and 2 to install. it was hard to line up the fitting above the starter and removal of the starter would have saved an hour. removal of trap door took an hour also. both hoses with pressed fittings cost about $60.00. SanDiego Detroit charged $700. for a 88pt parts and labor (July'08). no trap door access and required starter removal, sounds way fair. GregoryO'Connor 94ptRomolandCa 94pt 8v92 cooling lines to the aircompressor - Curt Sprenger - 08-08-2008 16:02 Greg,
Good post. It should be saved in the Files Section.Yes, $700.00 does seem fair. On Fri, Aug 8, 2008 at 8:14 PM, Gregory OConnor <"Gregoryoc@aol.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA 94pt 8v92 cooling lines to the aircompressor - Gregory OConnor - 08-24-2008 17:41 here are some pics of the 8v92 aircompressor coolant lines. at the fist pic chose next for the next 4 pics Greg http://www.pbase.com/gregoryoc/image/102145955 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > the coolant lines to the engine mounted aircompressor have proven to > fail after 20 years. I think it is from the excess heat that gets > trapped above the transmission / below bedroom.(not vented to engine > bay, may be cause of heat in bedroom?). I replaced the coolant lines > today as a PM (preventativeMaintenance) measure. > > there are two lines that run from the passanger side block to the > compressor which is mounted above the transmission bell housing. one > hose 28 inches long and the other about 8 inches long > > Short hose. there is a trap door under the carpet between rear > dresser and the bed, just about center. I removed the carpeted > baceboard box that covers wires and pipes, lifted the carpet and > unscrewed a metal plate. under the wires is one more removable > plate. the wire plate attaches to the wall behind the wires and to > the floor. with both plates out you have easy access. > > the compressor has several lines 2 coolant 2 oil and two air. the > coolant lines are at the top. a 7/8inch wrench is used to remove the > swival end ( oil uses a 3/4) the short hose attaches to back of the > block. when you remove the line you will see the coolant as a check > > Long hose. at the other end of the compressor head is the long hose > attached to the compressor with a 7/8 swival fitting. the hose runs > past the tranny mount between the frame and the block and reattaches > to the block above the starter. I removed the compressor end and cut > the hose to make it easy to slip thru a strap. with the bus jacked > up wheels just on the ground,frame stands and chocks inplace, I > reached over the starter (removed battery power and unplugged > chargers) and found the attachement to the block. there are two > lines attached to the block above the starter one is oil to the > compressor. the one you want is the farthest reach and the swival is > 7/8 and hose is larger than the oil. unable to get a full size > wrench on the fitting I uses a "stubby whench". A 7/8crows foot and > socket wrench would best serve to loosen the fitting but I used a > bathroom sink wrench(?) (cheap long handel with a flip/flop little > pipe wrench thing on the end). I made the long hose 5 inches longer > as the OEM was jammed against the frame and 'flex tube vent'. > Install the starter end fitting first to make it easy to line up > the thread. I pointed the '90 degree fitting out of the block' > downward a bit to help clear the 'frame pinch area'. I also bent the > flex tube away frm the block for the new line. > > the hosefittings are reusable and I wanted to do so but I could not > get high temp quickie tube. I had hydrolic line made but wonder how > well hydrolic oil hose holds up to coolant product? > > took about one hour to remove and 2 to install. it was hard to line > up the fitting above the starter and removal of the starter would > have saved an hour. removal of trap door took an hour also. > > > both hoses with pressed fittings cost about $60.00. SanDiego > Detroit charged $700. for a 88pt parts and labor (July'08). no trap > door access and required starter removal, sounds way fair. > > GregoryO'Connor > 94ptRomolandCa > 94pt 8v92 cooling lines to the aircompressor - mbulriss - 08-25-2008 03:42 Great pics Greg. They made that block mount hose above the starter look almost easily accessible! Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > here are some pics of the 8v92 aircompressor coolant lines. at the > fist pic chose next for the next 4 pics > Greg > > http://www.pbase.com/gregoryoc/image/102145955 > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > the coolant lines to the engine mounted aircompressor have proven > to > > fail after 20 years. I think it is from the excess heat that gets > > trapped above the transmission / below bedroom.(not vented to > engine > > bay, may be cause of heat in bedroom?). I replaced the coolant > lines > > today as a PM (preventativeMaintenance) measure. > > > > there are two lines that run from the passanger side block to the > > compressor which is mounted above the transmission bell housing. > one > > hose 28 inches long and the other about 8 inches long > > > > Short hose. there is a trap door under the carpet between rear > > dresser and the bed, just about center. I removed the carpeted > > baceboard box that covers wires and pipes, lifted the carpet and > > unscrewed a metal plate. under the wires is one more removable > > plate. the wire plate attaches to the wall behind the wires and to > > the floor. with both plates out you have easy access. > > > > the compressor has several lines 2 coolant 2 oil and two air. the > > coolant lines are at the top. a 7/8inch wrench is used to remove > the > > swival end ( oil uses a 3/4) the short hose attaches to back of > the > > block. when you remove the line you will see the coolant as a check > > > > Long hose. at the other end of the compressor head is the long > hose > > attached to the compressor with a 7/8 swival fitting. the hose > runs > > past the tranny mount between the frame and the block and > reattaches > > to the block above the starter. I removed the compressor end and > cut > > the hose to make it easy to slip thru a strap. with the bus > jacked > > up wheels just on the ground,frame stands and chocks inplace, I > > reached over the starter (removed battery power and unplugged > > chargers) and found the attachement to the block. there are two > > lines attached to the block above the starter one is oil to the > > compressor. the one you want is the farthest reach and the swival > is > > 7/8 and hose is larger than the oil. unable to get a full size > > wrench on the fitting I uses a "stubby whench". A 7/8crows foot > and > > socket wrench would best serve to loosen the fitting but I used a > > bathroom sink wrench(?) (cheap long handel with a flip/flop > little > > pipe wrench thing on the end). I made the long hose 5 inches > longer > > as the OEM was jammed against the frame and 'flex tube vent'. > > Install the starter end fitting first to make it easy to line up > > the thread. I pointed the '90 degree fitting out of the block' > > downward a bit to help clear the 'frame pinch area'. I also bent > the > > flex tube away frm the block for the new line. > > > > the hosefittings are reusable and I wanted to do so but I could > not > > get high temp quickie tube. I had hydrolic line made but wonder > how > > well hydrolic oil hose holds up to coolant product? > > > > took about one hour to remove and 2 to install. it was hard to > line > > up the fitting above the starter and removal of the starter would > > have saved an hour. removal of trap door took an hour also. > > > > > > both hoses with pressed fittings cost about $60.00. SanDiego > > Detroit charged $700. for a 88pt parts and labor (July'08). no > trap > > door access and required starter removal, sounds way fair. > > > > GregoryO'Connor > > 94ptRomolandCa > > > |
