coolant leak - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: coolant leak (/showthread.php?tid=7014) |
coolant leak - coreyg67 - 08-22-2008 09:38 hello all, Just moved the bird after a week or so of inactivity, and have a new problem. I noticed the low coolant light was on, and the stop engine light was lit. After a walk around the bus, I found a steady stream of coolant flowing out of my water bay. I'm assuming a line for the aquahot has failed, but havent verified this. Can anyone shed some light on making repairs in this area? I'm due to be leaving town on Wednesday, so I'm somewhat in a rush to get it repaired. Thanks again as always! Corey and Jenni Graham 1996 PT 42 60series Prosper, TX coolant leak - Ralph L. Fullenwider - 08-22-2008 09:46 Hi Corey: First you need to indent where exactly the leak is, there is some lines that are copper and some that are PEX, then you will know which line splice to look for to do the repair, I am assuming it is a line, but there is a good starting point. Or it could be as simple as tightening a connection, but simple and Bluebird really don't belong in the same sentence. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 09:38 PM 8/22/2008 +0000, you wrote: >hello all, > >Just moved the bird after a week or so of inactivity, and have a new >problem. I noticed >the low coolant light was on, and the stop engine light was lit. After a >walk around the >bus, I found a steady stream of coolant flowing out of my water bay. I'm >assuming a line >for the aquahot has failed, but havent verified this. Can anyone shed some >light on >making repairs in this area? I'm due to be leaving town on Wednesday, so >I'm somewhat >in a rush to get it repaired. Thanks again as always! > > >Corey and Jenni Graham >1996 PT 42 60series >Prosper, TX > > Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma |
