Bus Standing TALL - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Bus Standing TALL (/showthread.php?tid=7025) |
Bus Standing TALL - Curt Sprenger - 08-25-2008 05:54 After airing up the suspension (air springs), the front and the rear of the coach height is about 2" taller than normal. Suspension was cycled three times and no change. I doubt the 3 ride-height valves would go bad at the same time. Thoughts?
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Bus Standing TALL - pattypape - 08-25-2008 06:11 It is just taller ??? This is odd ??? If the coach is still level, I would suggest, that Curt is shorter, ( shrinking)?? Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > After airing up the suspension (air springs), the front and the rear of the > coach height is about 2" taller than normal. Suspension was cycled three > times and no change. I doubt the 3 ride-height valves would go bad at the > same time. Thoughts? > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > Bus Standing TALL - Leroy Eckert - 08-25-2008 06:24
Bus Standing TALL - Ralph L. Fullenwider - 08-25-2008 06:30 Curt: Some times the ride height valves need to go to the negative side then return to the positive this resets the setting back to normal. Try undocking and take a tour around the block then another block with right and left turns and see if this corrects the problem. I agree, it is odd they would all fail at the same time but then Murphy says" if it can happen it will.?" Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 10:54 AM 8/25/2008 -0700, you wrote: After airing up the suspension (air |
Bus Standing TALL - Rob Robinson - 08-25-2008 08:48 Curt there is an airpressure regulator involved and the only common denominator for all the air bags.
2008/8/25 Curt Sprenger <"curtsprenger@gmail.com">
-- Rob, Sue & Merlin Robinson 94 WLWB Bus Standing TALL - Curt Sprenger - 08-25-2008 10:28 Right you are Rob. I picked up an Haldex pressure regulator. Now to get it installed.
Greg, is it OK if I come out and use your pit? On Mon, Aug 25, 2008 at 1:48 PM, Rob Robinson <"wander.rob@gmail.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Bus Standing TALL - Rob Robinson - 08-25-2008 10:35 Curt I'd like to take the credit but can't. I passed your problem by Randy Dupree and it was his expertise that came up with the solution.
-- Rob, Sue & Merlin Robinson 94 WLWB Bus Standing TALL - Gregory OConnor - 08-25-2008 16:44 Curt, pit aint done but the keys are in the excavator and there is a stack of trench plates by my bus. I got to get past the design and just dig the hole. gunite and steel are paid for in swaps. kinda the reason I have two gunite swimmingpools. Greg --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Right you are Rob. I picked up an Haldex pressure regulator. Now to get it > installed. > > Greg, is it OK if I come out and use your pit? > > > On Mon, Aug 25, 2008 at 1:48 PM, Rob Robinson wrote: > > > Curt there is an air pressure regulator involved and the only common > > denominator for all the air bags. > > > > 2008/8/25 Curt Sprenger > > > > After airing up the suspension (air springs), the front and the rear of > >> the coach height is about 2" taller than normal. Suspension was cycled three > >> times and no change. I doubt the 3 ride-height valves would go bad at the > >> same time. Thoughts? > >> > >> > >> -- > >> Curt Sprenger > >> 1987 PT38 8V92 "MacAttack Racing" > >> Anaheim Hills, CA > >> > >> > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
