New Water Pumps - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: New Water Pumps (/showthread.php?tid=7045) |
New Water Pumps - Kurt Horvath - 08-28-2008 16:45 After a close look at the original plumbing in the bay with the water pumps, I have decided to remove most of the pipes and keep only the basics. As per the installation instructions it recommends that there be no restrictive elbows, shut off or check valves, use as few elbows and valves as possible in the first 2 feet after the pump. Using the ½ I.D. flexible high pressure tubing, cut at 2 ½ feet for each side of the pump will eliminate 4 elbows on each pump, ( my coach has 2 pumps, you can run pump #1 or #2, or #1 together ). It also has 4 T valves in the system. I am still trying to decide their valor in the greater scheme of things. If anyone has any thoughts on why they have these cut off valves on each side of the pumps I would like to hear about it. I guess they are to shut off water to service the pumps or in case of a leak, I just do not see if you would even use them that much. So that will cut out 6 restrictive devices off each pump, all of which are within 12" of the pumps. The exit side of the pumps have 3 elbows within 3" of each other before they reach the accumulator tank.. Speaking of that, the out side of the tank has a couple of 2 or 3 unnecessary elbows to boot! If you gently heat any plastic tubing you can make it bend into any shape needed. So that would remove 3 elbows on the out side of the accumulator tank, very easy to do, but will it help? It couldn't hurt. The cold water dump valve also has enough hardware to open a pluming supply. I will redo that with a little upgrade, After he BBQ/Toolbox Bay upgrade, it would be nice if the coach had flowing water on the curb side, near the outdoor kitchen. Nothing fancy just a practical cold water hose with some kind of head at the end. It will serve 2 uses as a curb side water source and replace the cold water dump valve. The installation manual also mentions mounting the pumps in a easily accessible location, well the space allotted , is, what it, is. I'll mount the pumps on a 20" X12" piece of good plywood, then bolt that to the outside of the plywood framing that surrounds the toolbox and BBQ shelf. So with that and the Hydraulic fluid flush and the new 3000psi switch I have to put on the HWH levelers and now you guys got me thinking about Coolant filters! All I can say I'm happy Fuel prices are going down @ Flying J. Not much but $3.99 is better than the $4.69 I paid last trip. Kurt Horvath 95 PT-42 WLWB S-60 10AC New Water Pumps - Gregory OConnor - 08-28-2008 17:50 the cut in a pipe or the end of a internal fitting cause more friction than a 90 degree elbow. if water takes a path that doesnt cross a fitting, that fitting causes no friction loss. If you want a project make a manual accessable sporlan tank fill bypass. I agree with you that there is little need for extra valves that may fail. CCW-BB even includes a row of plumbing valves with logo handles in their 15 photo 2009 brochure. I guess rich folks like lots of valves??? But.......... if the backflow device in one pump fails, it will make the other pump run continiously. the good pump will send the water thru the bad pump backwards and then resupply the continiously running pump. the good pump can not build pressure unless you cut off the circular path. Greg --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > > > After a close look at the original plumbing in the bay with the water > pumps, I have decided to remove most of the pipes and keep only the > basics. > > As per the installation instructions it recommends that there be no > restrictive elbows, shut off or check valves, use as few elbows and > valves as possible in the first 2 feet after the pump. > > Using the ½ I.D. flexible high pressure tubing, cut at 2 ½ feet for > each side of the pump will eliminate 4 elbows on each pump, ( my > coach has 2 pumps, you can run pump #1 or #2, or #1 together ). > It also has 4 T valves in the system. I am still trying to decide > their valor in the greater scheme of things. > > If anyone has any thoughts on why they have these cut off valves on > each side of the pumps I would like to hear about it. I guess they > are to shut off water to service the pumps or in case of a leak, I > just do not see if you would even use them that much. > > So that will cut out 6 restrictive devices off each pump, all of > which are within 12" of the pumps. The exit side of the pumps have 3 > elbows within 3" of each other before they reach the accumulator > tank.. Speaking of that, the out side of the tank has a couple of 2 > or 3 unnecessary elbows to boot! > > If you gently heat any plastic tubing you can make it bend into any > shape needed. So that would remove 3 elbows on the out side of the > accumulator tank, very easy to do, but will it help? It couldn't hurt. > > The cold water dump valve also has enough hardware to open a pluming > supply. I will redo that with a little upgrade, > > After he BBQ/Toolbox Bay upgrade, it would be nice if the coach had > flowing water on the curb side, near the outdoor kitchen. Nothing > fancy just a practical cold water hose with some kind of head at the > end. It will serve 2 uses as a curb side water source and replace the > cold water dump valve. > > The installation manual also mentions mounting the pumps in a easily > accessible location, well the space allotted , is, what it, is. I'll > mount the pumps on a 20" X12" piece of good plywood, then bolt that > to the outside of the plywood framing that surrounds the toolbox and > BBQ shelf. > > So with that and the Hydraulic fluid flush and the new 3000psi switch > I have to put on the HWH levelers and now you guys got me thinking > about Coolant filters! All I can say I'm happy Fuel prices are going > down @ Flying J. Not much but $3.99 is better than the $4.69 I paid > last trip. > > Kurt Horvath > 95 PT-42 WLWB S-60 > 10AC > New Water Pumps - Kurt Horvath - 08-29-2008 03:51 Gregg, That's exactly what my pumps were doing,"the backflow device in one pump fails, it will make the other pump run continuously." A by-pass or direct fill to the fresh water tank would be nice. I don't know about your coach, but I have to plan in advance when I want to fill my tank. It takes while 35 to 45 minuets, some times longer. It all passes through the water filter before it hits the tanks, it's just a thing, like the sewage air dumps, just have to plan for it. I guess you could fabricate a loop with a hose coupling around the Sporlan valve. Just went to have a look see at the Valve Controls on the new Bird at http://www.bluebirdcoachworks.com . No labels ! I'm not genius, I would at least need a sticker or two. From an engravers POV, I see lots of potential, I just love shinny metal! The dash looks better, although I would have problem with the CB radio rammed up upon the seat. Huumm there's that attention to details I was talking about back in January. Kurt Horvath 95 PT-42, ( one of the golden years ) 10AC --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > the cut in a pipe or the end of a internal fitting cause more > friction than a 90 degree elbow. if water takes a path that doesnt > cross a fitting, that fitting causes no friction loss. If you want > a project make a manual accessable sporlan tank fill bypass. I agree > with you that there is little need for extra valves that may fail. > CCW-BB even includes a row of plumbing valves with logo handles in > their 15 photo 2009 brochure. I guess rich folks like lots of > valves???. But.......... . the good pump will send > the water thru the bad pump backwards and then resupply the > continiously running pump. the good pump can not build pressure > unless you cut off the circular path. > > Greg > --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > bumpersbird@ wrote: > > > > > > > > After a close look at the original plumbing in the bay with the > water > > pumps, I have decided to remove most of the pipes and keep only > the > > basics. > > > > As per the installation instructions it recommends that there be > no > > restrictive elbows, shut off or check valves, use as few elbows > and > > valves as possible in the first 2 feet after the pump. > > > > Using the ½ I.D. flexible high pressure tubing, cut at 2 ½ feet > for > > each side of the pump will eliminate 4 elbows on each pump, ( my > > coach has 2 pumps, you can run pump #1 or #2, or #1 > together ). > > It also has 4 T valves in the system. I am still trying to decide > > their valor in the greater scheme of things. > > > > If anyone has any thoughts on why they have these cut off valves > on > > each side of the pumps I would like to hear about it. I guess they > > are to shut off water to service the pumps or in case of a leak, I > > just do not see if you would even use them that much. > > > > So that will cut out 6 restrictive devices off each pump, all of > > which are within 12" of the pumps. The exit side of the pumps have > 3 > > elbows within 3" of each other before they reach the accumulator > > tank.. Speaking of that, the out side of the tank has a couple of > 2 > > or 3 unnecessary elbows to boot! > > > > If you gently heat any plastic tubing you can make it bend into > any > > shape needed. So that would remove 3 elbows on the out side of the > > accumulator tank, very easy to do, but will it help? It couldn't > hurt. > > > > The cold water dump valve also has enough hardware to open a > pluming > > supply. I will redo that with a little upgrade, > > > > After he BBQ/Toolbox Bay upgrade, it would be nice if the coach > had > > flowing water on the curb side, near the outdoor kitchen. Nothing > > fancy just a practical cold water hose with some kind of head at > the > > end. It will serve 2 uses as a curb side water source and replace > the > > cold water dump valve. > > > > The installation manual also mentions mounting the pumps in a > easily > > accessible location, well the space allotted , is, what it, is. > I'll > > mount the pumps on a 20" X12" piece of good plywood, then bolt > that > > to the outside of the plywood framing that surrounds the toolbox > and > > BBQ shelf. > > > > So with that and the Hydraulic fluid flush and the new 3000psi > switch > > I have to put on the HWH levelers and now you guys got me thinking > > about Coolant filters! All I can say I'm happy Fuel prices are > going > > down @ Flying J. Not much but $3.99 is better than the $4.69 I > paid > > last trip. > > > > Kurt Horvath > > 95 PT-42 WLWB S-60 > > 10AC > > > |
