Water Pumps & UV water treatment - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Water Pumps & UV water treatment (/showthread.php?tid=7083) |
Water Pumps & UV water treatment - Kurt Horvath - 09-05-2008 14:18 Well it looks like I'm going to end up with a total water pump bay rebuild. I have the new pumps and filter screens ,the reinforced vinyl tubing, (210PSI), stainless hose clamps and the SeaTeck fittings. I thought I was going top get away with the old Accumulator tank, but it's shot. When you depress the Schrader valve it blow water, so the bladder is leaking. The original Jabsco tank is a little price. I found a Groco PST-1 for about ½ price and if I'm not mistaken Jabsco gets their tanks from Groco. Dimensions are the same as Jabso Had I known I would end up re-doing everything I would have gone with a combination pump/accumulator tank set up. Mount it, plug in the power, hook up the water and your done. The system already has a water filter inside the Tank Bay, one of those Life Time filters, I don't know about that, it seems as though other than taking it out and runniung water through it backwards there is no other way to clean it. Seems like sooner or later it will reach it's operational capacity, etc. etc. I have a problem with water! You never really know if it is safe to drink. If you top off the tanks at last nights campground where did they get it from? The municipal plant, the well, ground water???? Who knows. I don't mind water tasting different from place to place. That's part of the travel experience. What I have a problem with is germs & bacteria that can make you sick or worse! I'm looking into installing a UV water treatment system. http://www.h2ofilter.net/650560.asp I like this system over other alternatives like Ozone, mostly because I'm Thrifty, read in here CHEEP! It has a UV bulb and a power supply, the water flows through it to or from the pumps. SIMPLE. You can get them in 120V, 220-240V, and 12V models. It has a capacity large enough to disinfect any water flow rate you would see in a Bird, I almost never run off of shore water, I'll fill my tanks and run off the 12V pump system., even when parked for a long stay. It's just the way I've done it for years. I've seen water regulators fail, and parks that have extreme water pressures. The above model is 14 gallons per min. Which should be more than sufficient for 2 pumps that deliver 3.5 GPM each. I'm not sure but 2 pumps running together at a rate of 3.5 GPM @ 45 PSI will not deliver 7 GPM @ 90PSI, I think it somewhat less. Maybe one of you engineers could figure that out for us. Regardless this UV system can handle it. Ozone while it is more effective, it will sanitize the water and whatever is containing it. Has some disadvantages, uses more power, is more complex in it's construction and IT COSTS MORE, There is some debate about it being harmful in large doses. I've used Ozonators to kill mold and to get smells out of rooms and even in the coach to freshen up the air and upholstery, carpets, it works well, I just don't think I want to drink it. Here again some people swear it's beneficial. I not looking for the fountain of youth, just safe water. There are several ways that you could install this system. In the initial filling of the storage tanks, or in the system just before it hits the interior plumbing. I'll most likely place it just past the accumulator in the pump bay, There is enough space to mount the unit, easy to service and there is an electric outlet already in place. Kurt Horvath 95 PT-42 10AC |
