Series 60, DDEC 4, Check engine light - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Series 60, DDEC 4, Check engine light (/showthread.php?tid=7141) |
Series 60, DDEC 4, Check engine light - David Brady - 09-19-2008 13:25 Folks, On my way up Vale Pass, near the Eisenhower Tunnel, my check engine light came on and my DDEC displayed: PID 103, MID 128, FMI 1 Which decodes to "turbo speed sensor low". I'll take it to the local Detroit Service Center here in Denver, but in the meantime, does anyone have an idea of what this could be? Thanks, David Brady '02 LXi, CO -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM Series 60, DDEC 4, Check engine light - Gregory OConnor - 09-19-2008 16:47 high would be a problem (Why use high and low and not fast and slow??) low might mean an injector is pissing and the turbo is spinning slow in relation to fuel?? Are you one of those guys in love with the sound of the Jake? they make heat and stress. the other thing is how does Ddec account for the thin air up there, ??? surf around on this site for forum threads on series 60 under transportation trucks and busses http://www.answerbag.com/ Greg --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > On my way up Vale Pass, near the Eisenhower Tunnel, my check engine > light came > on and my DDEC displayed: > > PID 103, MID 128, FMI 1 > > Which decodes to "turbo speed sensor low". I'll take it to the local > Detroit Service > Center here in Denver, but in the meantime, does anyone have an idea of > what this > could be? > > Thanks, > David Brady > '02 LXi, CO > > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > Series 60, DDEC 4, Check engine light - David Brady - 09-19-2008 17:11 It may mean high, or overspeed. The flash code associated with the message is 64 which my ddec 4 manual translates to "turbo overspeed". The "turbo speed sensor low" message was read from the J1939 port. I think the "low" portion of the message means voltage low, and low voltage in this case corresponds to turbo overspeed, which may be a problem. In high altitudes, the turbo can make up for thin air by spinning faster (to a degree). I don't think my turbo has a waste gate, so I'm not sure what would prevent it form overspeeding. I might be in love with the sound of the jake... David Gregory OConnor wrote: > > high would be a problem (Why use high and low and not fast and > slow??) low might mean an injector is pissing and the turbo is > spinning slow in relation to fuel?? > Are you one of those guys in love with the sound of the Jake? they > make heat and stress. > the other thing is how does Ddec account for the thin air up > there, ??? > > surf around on this site for forum threads on series 60 under > transportation trucks and busses > http://www.answerba g.com/ <http://www.answerbag.com/> > > Greg > > --- In WanderlodgeForum@ yahoogroups. com > > wrote: > > > > Folks, > > > > On my way up Vale Pass, near the Eisenhower Tunnel, my check > engine > > light came > > on and my DDEC displayed: > > > > PID 103, MID 128, FMI 1 > > > > Which decodes to "turbo speed sensor low". I'll take it to the > local > > Detroit Service > > Center here in Denver, but in the meantime, does anyone have an > idea of > > what this > > could be? > > > > Thanks, > > David Brady > > '02 LXi, CO > > > > > > -- > > No virus found in this outgoing message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > 9/16/2008 8:15 AM > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM Series 60, DDEC 4, Check engine light - David Brady - 09-19-2008 17:23 Greg, Do you think the turbo overspeed could have happened while under jake brake. It all happened pretty fast, but I'm almost certain that the condition occurred on a down hill section. When using the jake, I can achieve 15 psi of turbo boost, which is quite a bit lower than the 28 psi I get under full power. I wonder if it's possible for the turbo to spin faster under jake. David Brady '02 LXi, CO David Brady wrote: > > It may mean high, or overspeed. The flash code associated > with the message is 64 which my ddec 4 manual translates > to "turbo overspeed". > > The "turbo speed sensor low" message was read from the > J1939 port. I think the "low" portion of the message means > voltage low, and low voltage in this case corresponds to turbo > overspeed, which may be a problem. In high altitudes, the turbo > can make up for thin air by spinning faster (to a degree). I don't > think my turbo has a waste gate, so I'm not sure what would > prevent it form overspeeding. > > I might be in love with the sound of the jake... > > David > > Gregory OConnor wrote: > > > > high would be a problem (Why use high and low and not fast and > > slow??) low might mean an injector is pissing and the turbo is > > spinning slow in relation to fuel?? > > Are you one of those guys in love with the sound of the Jake? they > > make heat and stress. > > the other thing is how does Ddec account for the thin air up > > there, ??? > > > > surf around on this site for forum threads on series 60 under > > transportation trucks and busses > > http://www.answerba g.com/ <http://www.answerbag.com/ > <http://www.answerbag.com/>> > > > > Greg > > > > --- In WanderlodgeForum@ yahoogroups. com > > > > wrote: > > > > > > Folks, > > > > > > On my way up Vale Pass, near the Eisenhower Tunnel, my check > > engine > > > light came > > > on and my DDEC displayed: > > > > > > PID 103, MID 128, FMI 1 > > > > > > Which decodes to "turbo speed sensor low". I'll take it to the > > local > > > Detroit Service > > > Center here in Denver, but in the meantime, does anyone have an > > idea of > > > what this > > > could be? > > > > > > Thanks, > > > David Brady > > > '02 LXi, CO > > > > > > > > > -- > > > No virus found in this outgoing message. > > > Checked by AVG. > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > > 9/16/2008 8:15 AM > > > > > > > > > ---------------------------------------------------------- > > > > No virus found in this incoming message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > 9/16/2008 8:15 AM > > > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > 9/16/2008 8:15 AM > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM Series 60, DDEC 4, Check engine light - Richard Gideon - 09-19-2008 18:01 David: A quick search of the DDEC III/IV guide below will show connector pinputs and sensor locations...if this will help great, otherwise disregard. http://www.ddcsn.com/cps/rde/xbcr/ddcsn/1-SECM-03-03.pdf Dick Gideon 1989 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > On my way up Vale Pass, near the Eisenhower Tunnel, my check engine > light came > on and my DDEC displayed: > > PID 103, MID 128, FMI 1 > > Which decodes to "turbo speed sensor low". I'll take it to the local > Detroit Service > Center here in Denver, but in the meantime, does anyone have an idea of > what this > could be? > > Thanks, > David Brady > '02 LXi, CO > > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > Series 60, DDEC 4, Check engine light - Kurt Horvath - 09-19-2008 18:14 These manuals may help http://www.detroitdiesel.com/Support/On- Highway/Manuals/Application_and_Installation/Series_60/Series_60_2007_ AI_7SA717.pdf http://www.detroitdiesel.com/Support/On- Highway/Manuals/Application_and_Installation/ Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > David: A quick search of the DDEC III/IV guide below will show > connector pinputs and sensor locations...if this will help great, > otherwise disregard. > > http://www.ddcsn.com/cps/rde/xbcr/ddcsn/1-SECM-03-03.pdf > > Dick Gideon > 1989 35FC > Rolla, MO > > --- In WanderlodgeForum@yahoogroups.com, David Brady > wrote: > > > > Folks, > > > > On my way up Vale Pass, near the Eisenhower Tunnel, my check engine > > light came > > on and my DDEC displayed: > > > > PID 103, MID 128, FMI 1 > > > > Which decodes to "turbo speed sensor low". I'll take it to the > local > > Detroit Service > > Center here in Denver, but in the meantime, does anyone have an > idea of > > what this > > could be? > > > > Thanks, > > David Brady > > '02 LXi, CO > > > > > > -- > > No virus found in this outgoing message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > 9/16/2008 8:15 AM > > > Series 60, DDEC 4, Check engine light - Gregory OConnor - 09-20-2008 02:18 One of the great things about check engine warning systems and computer control is the epa clean air thing (who do you think I'm voting for?). One of the true problems is too much information. the early s60's were considered junk because they spit out check engine codes and that sent cautious operators(hypoMechanicalChondriacs) to the shop to have things tweeked till there truly was a problem. Every condition is not gonna let the engine operate within epa. **If you are adding fuel to the mix of variables (uphill) and somthing like the turbo is spinning too fast the computer can turn down the amount of fuel it lets you send, therefor no need for a code. **If you are being push down a hill, loading the integrity of the engine via the Jake to hold you back and there is too much heat, speed (in relation to other variables), R's, boost, wrong mix of fuel to air, bla bla bla. All the computer can do is complain (CHECK ENGINE). there is no way it can control the stress caused by the down hill. Newton and Einstine didnt agree how to explain it. Only John Mayer made sence. http://www.youtube.com/watch?v=7VBex8zbDRs I would bet 300% more engines get burnt up decending a hill than climbing. climbing they get hot, pull over, and call the tech. decending they roll of the highway and call the bank. For every action there is an equal and opposit reaction. stress the bus up a 8% hill burn fuel and heat the air. the faster you go up the more stress heat and fuel per mile. Blow down a hill up against the Jake with Gravity as your fuel there is no stress and little friction unless you want to control the speed. controlling a 35 mile per hour decend with the brakes only causes major heat at he drums. 'brakes' and 'down shift trans' share the heat between the tranny and the drums. decending at 35 with the 'jake' 'trans' and 'brakes' more or less shares the heat between the trans, and engine leaving the brakes for a back up with a controlable speed if one of the 3 miles of wire fail and the engine shuts down and shifts into N. Greg --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Greg, > > Do you think the turbo overspeed could have happened while > under jake brake. It all happened pretty fast, but I'm almost > certain that the condition occurred on a down hill section. > When using the jake, I can achieve 15 psi of turbo boost, > which is quite a bit lower than the 28 psi I get under full power. > I wonder if it's possible for the turbo to spin faster under > jake. > > David Brady > '02 LXi, CO > > David Brady wrote: > > > > It may mean high, or overspeed. The flash code associated > > with the message is 64 which my ddec 4 manual translates > > to "turbo overspeed". > > > > The "turbo speed sensor low" message was read from the > > J1939 port. I think the "low" portion of the message means > > voltage low, and low voltage in this case corresponds to turbo > > overspeed, which may be a problem. In high altitudes, the turbo > > can make up for thin air by spinning faster (to a degree). I don't > > think my turbo has a waste gate, so I'm not sure what would > > prevent it form overspeeding. > > > > I might be in love with the sound of the jake... > > > > David > > > > Gregory OConnor wrote: > > > > > > high would be a problem (Why use high and low and not fast and > > > slow??) low might mean an injector is pissing and the turbo is > > > spinning slow in relation to fuel?? > > > Are you one of those guys in love with the sound of the Jake? they > > > make heat and stress. > > > the other thing is how does Ddec account for the thin air up > > > there, ??? > > > > > > surf around on this site for forum threads on series 60 under > > > transportation trucks and busses > > > http://www.answerba g.com/ <http://www.answerbag.com/ > > <http://www.answerbag.com/>> > > > > > > Greg > > > > > > --- In WanderlodgeForum@ yahoogroups. com > > > > > > wrote: > > > > > > > > Folks, > > > > > > > > On my way up Vale Pass, near the Eisenhower Tunnel, my check > > > engine > > > > light came > > > > on and my DDEC displayed: > > > > > > > > PID 103, MID 128, FMI 1 > > > > > > > > Which decodes to "turbo speed sensor low". I'll take it to the > > > local > > > > Detroit Service > > > > Center here in Denver, but in the meantime, does anyone have an > > > idea of > > > > what this > > > > could be? > > > > > > > > Thanks, > > > > David Brady > > > > '02 LXi, CO > > > > > > > > > > > > -- > > > > No virus found in this outgoing message. > > > > Checked by AVG. > > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > > > 9/16/2008 8:15 AM > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > No virus found in this incoming message. > > > Checked by AVG. > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > > 9/16/2008 8:15 AM > > > > > > > -- > > No virus found in this outgoing message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > > 9/16/2008 8:15 AM > > > > > > ----------------------------------------------------------------- ------- > > > > No virus found in this incoming message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > > > > > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > Series 60, DDEC 4, Check engine light - David Brady - 09-20-2008 02:49 Thanks you'll for your help. I just spoke with an S-60 mechanic at Transwest Trucks in Commerce City, Co. He said that the overspeed happens when the intake runner is not building enough pressure to limit turbo speed. Possible causes are: 1) bad intake manifold gasket, 2) leaky intake hose(s), 3) loose hose clamp(s), 4) leak in the intake charge cooler. I'll pay them a visit this week for a diagnosis and will keep you posted. Thanks, David Brady '02 LXi, CO Kurt Horvath wrote: > > > > These manuals may help > > http://www.detroitd iesel.com/ Support/On- > <http://www.detroitdiesel.com/Support/On-> > Highway/Manuals/ Application_ and_Installation /Series_60/ Series_60_ > 2007_ > AI_7SA717.pdf > > http://www.detroitd iesel.com/ Support/On- > <http://www.detroitdiesel.com/Support/On-> > Highway/Manuals/ Application_ and_Installation / > > Kurt Horvath > 95 PT-42 > 10AC > > --- In WanderlodgeForum@ yahoogroups. com > > > > > > David: A quick search of the DDEC III/IV guide below will show > > connector pinputs and sensor locations... if this will help great, > > otherwise disregard. > > > > http://www.ddcsn. com/cps/rde/ xbcr/ddcsn/ 1-SECM-03- 03.pdf > <http://www.ddcsn.com/cps/rde/xbcr/ddcsn/1-SECM-03-03.pdf> > > > > Dick Gideon > > 1989 35FC > > Rolla, MO > > > > --- In WanderlodgeForum@ yahoogroups. com > > > wrote: > > > > > > Folks, > > > > > > On my way up Vale Pass, near the Eisenhower Tunnel, my check > engine > > > light came > > > on and my DDEC displayed: > > > > > > PID 103, MID 128, FMI 1 > > > > > > Which decodes to "turbo speed sensor low". I'll take it to the > > local > > > Detroit Service > > > Center here in Denver, but in the meantime, does anyone have an > > idea of > > > what this > > > could be? > > > > > > Thanks, > > > David Brady > > > '02 LXi, CO > > > > > > > > > -- > > > No virus found in this outgoing message. > > > Checked by AVG. > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > > 9/16/2008 8:15 AM > > > > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM Series 60, DDEC 4, Check engine light - David Brady - 09-20-2008 03:02 I'm with you Greg. This is why I had the jake preselect changed to 5th instead of 4th gear when I was in Utah. With a preselect of 4th, the tranny caused the engine to speed to 2400 rpm when it shifted into 4th, exceeding the 2100 rpm governed speed of the engine. Now I choose when the downshift to 4th takes place and the engine never over revs. My driving style is in line with your description: slow descents leaving plenty of margin if the jake fails. The beauty of the '02 engine is that it's the last without any of the EPA clean air stuff, including no EGR, and it has most of the S-60 mechanical upgrades developed over the last 15 years. My four year ownership traveling 50K miles resulted in only 2 check engine light events, both times for the "turbo overspeed" event. David Brady '02 LXi, CO Gregory OConnor wrote: > > One of the great things about check engine warning systems and > computer control is the epa clean air thing (who do you think I'm > voting for?). One of the true problems is too much information. the > early s60's were considered junk because they spit out check engine > codes and that sent cautious operators(hypoMecha nicalChondriacs) to > the shop to have things tweeked till there truly was a problem. > Every condition is not gonna let the engine operate within epa. > > **If you are adding fuel to the mix of variables (uphill) and > somthing like the turbo is spinning too fast the computer can turn > down the amount of fuel it lets you send, therefor no need for a > code. > **If you are being push down a hill, loading the integrity of the > engine via the Jake to hold you back and there is too much heat, > speed (in relation to other variables), R's, boost, wrong mix of > fuel to air, bla bla bla. All the computer can do is complain (CHECK > ENGINE). there is no way it can control the stress caused by the > down hill. Newton and Einstine didnt agree how to explain it. Only > John Mayer made sence. > http://www.youtube. com/watch? v=7VBex8zbDRs > <http://www.youtube.com/watch?v=7VBex8zbDRs> > > I would bet 300% more engines get burnt up decending a hill than > climbing. climbing they get hot, pull over, and call the tech. > decending they roll of the highway and call the bank. > > For every action there is an equal and opposit reaction. stress the > bus up a 8% hill burn fuel and heat the air. the faster you go up > the more stress heat and fuel per mile. Blow down a hill up against > the Jake with Gravity as your fuel there is no stress and little > friction unless you want to control the speed. controlling a 35 > mile per hour decend with the brakes only causes major heat at he > drums. 'brakes' and 'down shift trans' share the heat between the > tranny and the drums. decending at 35 with the 'jake' 'trans' > and 'brakes' more or less shares the heat between the trans, and > engine leaving the brakes for a back up with a controlable speed if > one of the 3 miles of wire fail and the engine shuts down and shifts > into N. > > Greg > > --- In WanderlodgeForum@ yahoogroups. com > > wrote: > > > > Greg, > > > > Do you think the turbo overspeed could have happened while > > under jake brake. It all happened pretty fast, but I'm almost > > certain that the condition occurred on a down hill section. > > When using the jake, I can achieve 15 psi of turbo boost, > > which is quite a bit lower than the 28 psi I get under full power. > > I wonder if it's possible for the turbo to spin faster under > > jake. > > > > David Brady > > '02 LXi, CO > > > > David Brady wrote: > > > > > > It may mean high, or overspeed. The flash code associated > > > with the message is 64 which my ddec 4 manual translates > > > to "turbo overspeed". > > > > > > The "turbo speed sensor low" message was read from the > > > J1939 port. I think the "low" portion of the message means > > > voltage low, and low voltage in this case corresponds to turbo > > > overspeed, which may be a problem. In high altitudes, the turbo > > > can make up for thin air by spinning faster (to a degree). I > don't > > > think my turbo has a waste gate, so I'm not sure what would > > > prevent it form overspeeding. > > > > > > I might be in love with the sound of the jake... > > > > > > David > > > > > > Gregory OConnor wrote: > > > > > > > > high would be a problem (Why use high and low and not fast and > > > > slow??) low might mean an injector is pissing and the turbo is > > > > spinning slow in relation to fuel?? > > > > Are you one of those guys in love with the sound of the Jake? > they > > > > make heat and stress. > > > > the other thing is how does Ddec account for the thin air up > > > > there, ??? > > > > > > > > surf around on this site for forum threads on series 60 under > > > > transportation trucks and busses > > > > http://www.answerba g.com/ <http://www.answerba g.com/ > <http://www.answerbag.com/> > > > <http://www.answerba g.com/ <http://www.answerbag.com/>>> > > > > > > > > Greg > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com > > > > > > > > > wrote: > > > > > > > > > > Folks, > > > > > > > > > > On my way up Vale Pass, near the Eisenhower Tunnel, my check > > > > engine > > > > > light came > > > > > on and my DDEC displayed: > > > > > > > > > > PID 103, MID 128, FMI 1 > > > > > > > > > > Which decodes to "turbo speed sensor low". I'll take it to > the > > > > local > > > > > Detroit Service > > > > > Center here in Denver, but in the meantime, does anyone have > an > > > > idea of > > > > > what this > > > > > could be? > > > > > > > > > > Thanks, > > > > > David Brady > > > > > '02 LXi, CO > > > > > > > > > > > > > > > -- > > > > > No virus found in this outgoing message. > > > > > Checked by AVG. > > > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release > Date: > > > > 9/16/2008 8:15 AM > > > > > > > > > > > > > > > > > ------------ --------- --------- --------- --------- --------- - > > > > > > > > No virus found in this incoming message. > > > > Checked by AVG. > > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release > Date: > > > 9/16/2008 8:15 AM > > > > > > > > > > -- > > > No virus found in this outgoing message. > > > Checked by AVG. > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > > > 9/16/2008 8:15 AM > > > > > > > > > ------------ --------- --------- --------- --------- --------- - > ------- > > > > > > No virus found in this incoming message. > > > Checked by AVG. > > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > 9/16/2008 8:15 AM > > > > > > > > > > > -- > > No virus found in this outgoing message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: > 9/16/2008 8:15 AM > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.6.21/1674 - Release Date: 9/16/2008 8:15 AM |
