HELP-----NO FRONT AIR BAGS - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: HELP-----NO FRONT AIR BAGS (/showthread.php?tid=7142) |
HELP-----NO FRONT AIR BAGS - Peggy & Ed McStay - 09-20-2008 13:31 SEVERAL DAYS AGO I STARTED THE BUS AND THE FRONT AIR BAGS WOULD NOT COME UP. SORT OF THOUGHT THAT THE LEVELING VALVE MIGHT BE DIRTY OR NOT WORKING JUST RIGHT. SO AFTER DRIVING IT UP ON ME RAMPS AND BLOCKING UP UNDER IT SO IT WAS SAFE TO GET UNDER I PULLED THE VALVE. ALL THE LINES WERE TIGHT AND IT LOOKED GOOD FROM THE OUTSIDE. THIS VALVE IS MADE BY NEWAY . THEIR ARE TWO CHAMBERS ON THE VALVE SO I OPENED THE ONE WITH FOUR SCREWS. UNDER THE COVER IS TWO AIR VALVES THAT LOOKED OK AND WERE VERY CLEAN. I PUT THE COVER BACK ON AND OPENED THE OTHER COVER THAT HAS SIX SCREWS IN IT.INSIDE THIS COVER WAS AND OIL THAT LOOKED LIKE KARO SYRUP. SORT OF THICK AND CLEAR. THIS SORT OF THREW ME, I WAS NOT LOOKING FOR THIS VALVE TO HAS OIL IN IT. DOES THIS VALVE INDEED HAVE OIL IN IT OR HAS THIS OIL COME FROM SOMEWHERE ELSE. I DONT UNDER STAND HOW THE VALVE WORKS WITH THE OIL IN IT BUT MAYBE SO. PLEASE SOMEONE THAT HAS BEEN HERE WITH THIS PROBLEM OR HAS SOME KNOWLEDGE PLEASE CHIME IN. IF ITS NOT THE VALVE WHAT ELSE SHOULD I LOOK FOR. SURE DO MISS RALPH F. ED MCSTAY 83 FC RB 35FT "LONESOME DOVE" lake charles, louisiana HELP-----NO FRONT AIR BAGS - erniecarpet@... - 09-20-2008 21:57 Ed that sounds like you need a new ride height valve. Costs about 80 bucks, and since you have her on blocks, your 3/4 of the way done.
Ernie Ekberg 83PT40 Livingston, Montana Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators. HELP-----NO FRONT AIR BAGS - Bob Lawrence - 09-21-2008 03:07 Don't yell!! Bob Lawrence 84 PT36 Branson, Mo > SEVERAL DAYS AGO I STARTED THE BUS AND THE FRONT AIR BAGS WOULD NOT > COME UP. SORT OF THOUGHT THAT THE LEVELING VALVE MIGHT BE DIRTY OR > NOT WORKING JUST RIGHT. SO AFTER DRIVING IT UP ON ME RAMPS AND > BLOCKING UP UNDER IT SO IT WAS SAFE TO GET UNDER I PULLED THE VALVE. > ALL THE LINES WERE TIGHT AND IT LOOKED GOOD FROM THE OUTSIDE. THIS > VALVE IS MADE BY NEWAY . THEIR ARE TWO CHAMBERS ON THE VALVE SO I > OPENED THE ONE WITH FOUR SCREWS. UNDER THE COVER IS TWO AIR VALVES > THAT LOOKED OK AND WERE VERY CLEAN. I PUT THE COVER BACK ON AND > OPENED THE OTHER COVER THAT HAS SIX SCREWS IN IT.INSIDE THIS COVER > WAS AND OIL THAT LOOKED LIKE KARO SYRUP. SORT OF THICK AND CLEAR. > THIS SORT OF THREW ME, I WAS NOT LOOKING FOR THIS VALVE TO HAS OIL IN > IT. DOES THIS VALVE INDEED HAVE OIL IN IT OR HAS THIS OIL COME FROM > SOMEWHERE ELSE. I DONT UNDER STAND HOW THE VALVE WORKS WITH THE OIL > IN IT BUT MAYBE SO. PLEASE SOMEONE THAT HAS BEEN HERE WITH THIS > PROBLEM OR HAS SOME KNOWLEDGE PLEASE CHIME IN. IF ITS NOT THE VALVE > WHAT ELSE SHOULD I LOOK FOR. > SURE DO MISS RALPH F. > > ED MCSTAY > 83 FC RB 35FT > > "LONESOME DOVE" > lake charles, louisiana > |
