Information on batterys - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Information on batterys (/showthread.php?tid=7147) |
Information on batterys - Jon - 09-21-2008 16:23 I have a 1978 Wanderlodge and it has a gas generator. I was wondering as I have not seen an extra battery to run this unit if there is one someplace other than the four up front. Thanks Jon Information on batterys - bubblerboy64 - 09-22-2008 01:22 Jon, My bus is the same. I believe that originally there would have been a battery in the generator compartment which was to start the genny. The previous owner(s) wired my bus so that battery was not necessary. Nothing much original after 35 years on my bus. I have 4 house batteries in the forward drivers side compartment. These are 6 volts. On the passengers side forward compartment there is a 12 volt marine style battery which is to start the engine. I have never completely sorted out the method or madness in all of this but it seems to work. John Heckman central Pa 1973 FC > > I have a 1978 Wanderlodge and it has a gas generator. I was wondering > as I have not seen an extra battery to run this unit if there is one > someplace other than the four up front. Thanks Jon > Information on batterys - Gardner Yeaw - 09-22-2008 03:09 Jon, My former '78 had a battery in the genny compartment as well. It went through an isolator to keep it charged but prevent discharging while using the house batteries. That way even if you discharged the house batteries you could still start the generator to recover. Gardner 83FC35 --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I have a 1978 Wanderlodge and it has a gas generator. I was wondering > as I have not seen an extra battery to run this unit if there is one > someplace other than the four up front. Thanks Jon > Information on batterys - George Burke - 09-23-2008 12:22 Jon, My 77FC31 is set up as Gardner mentioned. It is powered by a 534 c.i.Ford SD gas engine, with (4) 6volt batterys up front. The 6.5 KWOnan gas gen. starts from its own 12V battery in that compartment. George Burke 1977FC31 Charlotte
On Mon, Sep 22, 2008 at 12:23 AM, Jon <"jipjob@yahoo.com"> wrote:
