Airbag Warning Buzzers on fc'83 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Airbag Warning Buzzers on fc'83 (/showthread.php?tid=7155) |
Airbag Warning Buzzers on fc'83 - Betsy and George - 09-23-2008 01:56 Both warning buzzers stay on constantly. Both front and aft air guages indicate proper levels. WL is at usual level and even. Found 2 buzzers behind drivers front panel located 8" deep behind many wires. Cannot access. 2 wires to each box are hot. Can I disconnect? Thoughts on subject?? George Bush WL'fc83 31 near Bangor, Maine Airbag Warning Buzzers on fc'83 - Don Bradner - 09-23-2008 02:04 The gauges are front and rear brakes. You do not have a gauge for air bags or other auxiliary tanks. On 9/23/2008 at 1:56 PM Betsy and George wrote: >Both warning buzzers stay on constantly. Both front and aft air guages >indicate proper levels. WL is at usual level and even. Found 2 buzzers >behind drivers front panel located 8" deep behind many wires. Cannot >access. 2 wires to each box are hot. Can I disconnect? Thoughts on >subject?? George Bush WL'fc83 31 near Bangor, Maine > > >------------------------------------ > >Yahoo! Groups Links > > > Airbag Warning Buzzers on fc'83 - Chet Geist - 09-23-2008 02:10 Sounds like a pressure indicating stuck switch on the aux. air tank. Tank is just inboard and forward of your propane tank. Switch is on top of that tank and has one wire off of it. New switch from most any auto supply store about $8.00. About a fifteen minute job, but don't forget to drain air down on that tank first.
Chet Geist
1981 FC33, Austin, Texas
