Air tank ID - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air tank ID (/showthread.php?tid=7156) |
Air tank ID - David Brady - 09-23-2008 02:24 Folks, My bird has 4 air tanks. 2 on either side of the drive axle above the brakes, 1 in front of the drive axle, and one behind the steer axle. What does each do? Thanks David Brady '02 LXi, CO -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.7.0/1683 - Release Date: 9/21/2008 10:10 AM Air tank ID - Leroy Eckert - 09-23-2008 13:45
Air tank ID - David Brady - 09-23-2008 16:08 Thanks Leroy, Mine is the same. I assume thee aux air tank provides air to the suspension, door stairs, drivers seat, and (on my coach) air door lock? David Brady '02 LXi, CO Leroy Eckert wrote: > I do not know the placement on your coach by tank. On mine, there is a > wet tank, front and rear brake tanks and an aux air tank. I have three > around the dryer in front of the rear axle and one in front above the > axle in parts unknown. I installed lanyards.' > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > --- On *Tue, 9/23/08, David Brady / > > From: David Brady > Subject: [WanderlodgeForum] Air tank ID > To: WanderlodgeForum@ yahoogroups. com > Date: Tuesday, September 23, 2008, 10:24 AM > > Folks, > > My bird has 4 air tanks. 2 on either side of the > drive axle above the brakes, 1 in front of the drive > axle, and one behind the steer axle. What does > each do? > > Thanks > David Brady > '02 LXi, CO > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.7.0/1683 - Release Date: > 9/21/2008 10:10 AM > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: 9/23/2008 7:38 AM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: 9/23/2008 7:38 AM Air tank ID - Leroy Eckert - 09-24-2008 01:53
Air tank ID - David Brady - 09-24-2008 03:51 Hi Leroy, Thanks, I forgot to mention those additional items. They all apply except I don't have the drop down driving lights or the bulk oil fill on my coach. David Brady '02 LXi, CO Leroy Eckert wrote: > The aux tank on my coach provides air to all that you mentioned except > the air door lock that I do not have, plus the drop down driving > lights, step well cover, bulk oil fill, winterization blow out system, > dump valves and the left and right fresh air vents. I think that's it. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On *Wed, 9/24/08, David Brady / > > From: David Brady > Subject: Re: [WanderlodgeForum] Air tank ID > To: WanderlodgeForum@ yahoogroups. com > Date: Wednesday, September 24, 2008, 12:08 AM > > Thanks Leroy, > > Mine is the same. I assume thee aux air tank provides air to the > suspension, door stairs, drivers seat, and (on my coach) air door > lock? > > David Brady > '02 LXi, CO > > Leroy Eckert wrote: > > I do not know the placement on your coach by tank. On mine, > there is a > > wet tank, front and rear brake tanks and an aux air tank. I have > three > > around the dryer in front of the rear axle and one in front > above the > > axle in parts unknown. I installed lanyards.' > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > > > --- On *Tue, 9/23/08, David Brady / > > > > From: David Brady > > Subject: [WanderlodgeForum] Air tank ID > > To: WanderlodgeForum@ yahoogroups. com > > Date: Tuesday, September 23, 2008, 10:24 AM > > > > Folks, > > > > My bird has 4 air tanks. 2 on either side of the > > drive axle above the brakes, 1 in front of the drive > > axle, and one behind the steer axle. What does > > each do? > > > > Thanks > > David Brady > > '02 LXi, CO > > > > -- > > No virus found in this outgoing message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.7.0/1683 - Release Date: > > 9/21/2008 10:10 AM > > > > > > > > ------------ --------- --------- --------- --------- --------- - > > > > No virus found in this incoming message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: > 9/23/2008 7:38 AM > > > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: > 9/23/2008 7:38 AM > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: 9/23/2008 7:38 AM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: 9/23/2008 7:38 AM Air tank ID - David Brady - 09-24-2008 03:53 I also neglected to mention the driver's air seat. This should also be powered by the aux tank. David Brady '02 LXi, CO David Brady wrote: > > Hi Leroy, > > Thanks, I forgot to mention those additional items. They all apply > except I don't have > the drop down driving lights or the bulk oil fill on my coach. > > David Brady > '02 LXi, CO > > Leroy Eckert wrote: > > The aux tank on my coach provides air to all that you mentioned except > > the air door lock that I do not have, plus the drop down driving > > lights, step well cover, bulk oil fill, winterization blow out system, > > dump valves and the left and right fresh air vents. I think that's it. > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > > --- On *Wed, 9/24/08, David Brady / > > > > From: David Brady > > Subject: Re: [WanderlodgeForum] Air tank ID > > To: WanderlodgeForum@ yahoogroups. com > > Date: Wednesday, September 24, 2008, 12:08 AM > > > > Thanks Leroy, > > > > Mine is the same. I assume thee aux air tank provides air to the > > suspension, door stairs, drivers seat, and (on my coach) air door > > lock? > > > > David Brady > > '02 LXi, CO > > > > Leroy Eckert wrote: > > > I do not know the placement on your coach by tank. On mine, > > there is a > > > wet tank, front and rear brake tanks and an aux air tank. I have > > three > > > around the dryer in front of the rear axle and one in front > > above the > > > axle in parts unknown. I installed lanyards.' > > > Leroy Eckert > > > 1990 WB-40 Smoke N Mirrors > > > Dahlonega, GA > > > > > > --- On *Tue, 9/23/08, David Brady / > > > > > > From: David Brady > > > Subject: [WanderlodgeForum] Air tank ID > > > To: WanderlodgeForum@ yahoogroups. com > > > Date: Tuesday, September 23, 2008, 10:24 AM > > > > > > Folks, > > > > > > My bird has 4 air tanks. 2 on either side of the > > > drive axle above the brakes, 1 in front of the drive > > > axle, and one behind the steer axle. What does > > > each do? > > > > > > Thanks > > > David Brady > > > '02 LXi, CO > > > > > > -- > > > No virus found in this outgoing message. > > > Checked by AVG. > > > Version: 7.5.524 / Virus Database: 270.7.0/1683 - Release Date: > > > 9/21/2008 10:10 AM > > > > > > > > > > > > ------------ --------- --------- --------- --------- --------- - > > > > > > No virus found in this incoming message. > > > Checked by AVG. > > > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: > > 9/23/2008 7:38 AM > > > > > > > -- > > No virus found in this outgoing message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: > > 9/23/2008 7:38 AM > > > > > > > > ---------------------------------------------------------- > > > > No virus found in this incoming message. > > Checked by AVG. > > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: > 9/23/2008 7:38 AM > > > > -- > No virus found in this outgoing message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: > 9/23/2008 7:38 AM > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: 9/23/2008 7:38 AM > -- No virus found in this outgoing message. Checked by AVG. Version: 7.5.524 / Virus Database: 270.7.1/1686 - Release Date: 9/23/2008 7:38 AM |
