Priming 3208T? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Priming 3208T? (/showthread.php?tid=7183) |
Priming 3208T? - xz3kg7 - 09-29-2008 05:43 So, last week I decided to do some "routine" maintenance on my Bird. Why is it that I always get into something when I do routine maintenance? ![]() How do I prime my 87 3208T? I read some posts about a "prime pump", but I don't know if mine has one. Below is how I got to this problem, if it matters. Thanks, Alan 87FC35 Here's what happened. I took off my doghouse, which included disconnecting the guage on the side of the doghouse for the Racor. Later on, I decided I needed to turn my Bird around so I would be in the shade. While I was moving it, it started idling rough. Being the quick thinker that I am, I remembered the hose that was connected to the Racor. When I put my finger over the hose, it started running better. I finished turning it around, left it running to go check on if I had it positioned where I wanted it (now without my finger on the hose). It then started idling rough again and died. I finished my maintenance, reconnected the racor guage and tried to start it, but it seems to not be getting fuel. I'm pretty sure it had something to do with my disconnecting the guage. Priming 3208T? - Kurt Horvath - 09-29-2008 05:53 Alan, This routine! :} Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" wrote: > > So, last week I decided to do some "routine" maintenance on my Bird. > Why is it that I always get into something when I do routine > maintenance? ![]() > > How do I prime my 87 3208T? I read some posts about a "prime pump", > but I don't know if mine has one. Below is how I got to this problem, > if it matters. > > Thanks, > Alan > 87FC35 > > Here's what happened. I took off my doghouse, which included > disconnecting the guage on the side of the doghouse for the Racor. > Later on, I decided I needed to turn my Bird around so I would be in > the shade. While I was moving it, it started idling rough. Being the > quick thinker that I am, I remembered the hose that was connected to > the Racor. When I put my finger over the hose, it started running > better. I finished turning it around, left it running to go check on > if I had it positioned where I wanted it (now without my finger on the > hose). It then started idling rough again and died. > > I finished my maintenance, reconnected the racor guage and tried to > start it, but it seems to not be getting fuel. I'm pretty sure it had > something to do with my disconnecting the guage. > Priming 3208T? - bubblerboy64 - 09-29-2008 06:14 Alan, No project I have attempted on my Bird has gone as routinely as it should have. On the other hand with the help of my friends I have gotten it done. If it was mine I have a manual pump right at the fuel filter. I would remove the filter and fill it with fuel and then crack one or two of the injector nuts and pump fuel thru the system and see if that works. Not certain this is correct but its what I would try until better heads are available. Lets see how far off I am. John Heckman central Pa 1973 FC > > So, last week I decided to do some "routine" maintenance on my Bird. > Why is it that I always get into something when I do routine > maintenance? ![]() > > How do I prime my 87 3208T? I read some posts about a "prime pump", > but I don't know if mine has one. Below is how I got to this problem, > if it matters. > > Thanks, > Alan > 87FC35 > > Here's what happened. I took off my doghouse, which included > disconnecting the guage on the side of the doghouse for the Racor. > Later on, I decided I needed to turn my Bird around so I would be in > the shade. While I was moving it, it started idling rough. Being the > quick thinker that I am, I remembered the hose that was connected to > the Racor. When I put my finger over the hose, it started running > better. I finished turning it around, left it running to go check on > if I had it positioned where I wanted it (now without my finger on the > hose). It then started idling rough again and died. > > I finished my maintenance, reconnected the racor guage and tried to > start it, but it seems to not be getting fuel. I'm pretty sure it had > something to do with my disconnecting the guage. > Priming 3208T? - Richard Gideon - 09-29-2008 06:15 Alan: You need to place a jumper on the oil pressure switch (near oil filters) and then turn on ignition switch...the facet pump near top front of the fuel tank should run and you can check by listening at rear of coach to hear the clicking sound. If your Facet lift pump is operating you should see positive pressure on the Racor guage by drivers right knee. You will need to open the T-handle on the right front of the injection pump to purge air from the system. How did you get air into the system...changing Racor? I'm inside by coach typing this...call Cell 573.465.0527 if I can help. Dick Gideon 1989 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" wrote: > > So, last week I decided to do some "routine" maintenance on my Bird. > Why is it that I always get into something when I do routine > maintenance? ![]() > > How do I prime my 87 3208T? I read some posts about a "prime pump", > but I don't know if mine has one. Below is how I got to this problem, > if it matters. > > Thanks, > Alan > 87FC35 > > Here's what happened. I took off my doghouse, which included > disconnecting the guage on the side of the doghouse for the Racor. > Later on, I decided I needed to turn my Bird around so I would be in > the shade. While I was moving it, it started idling rough. Being the > quick thinker that I am, I remembered the hose that was connected to > the Racor. When I put my finger over the hose, it started running > better. I finished turning it around, left it running to go check on > if I had it positioned where I wanted it (now without my finger on the > hose). It then started idling rough again and died. > > I finished my maintenance, reconnected the racor guage and tried to > start it, but it seems to not be getting fuel. I'm pretty sure it had > something to do with my disconnecting the guage. > Priming 3208T? - Jeff Miller - 09-29-2008 13:11 If you're only changing the Racor (in '83-up FCS) then change the filter, leave the T-handle loose on the filter lid, start the engine, when fuel starts to bubble out around the lid of the Racor then tighten the T-handle. Self priming. And the oil-pressure sender on the oil filter on the '87-up (300hp ATAAC) 3208 is the one with 2-wires, the single wire ones are for the gauge and KYSOR system. - Jeff --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > Alan: You need to place a jumper on the oil pressure switch (near > oil filters) and then turn on ignition switch...the facet pump near > top front of the fuel tank should run and you can check by listening > at rear of coach to hear the clicking sound. > > If your Facet lift pump is operating you should see positive pressure > on the Racor guage by drivers right knee. You will need to open the > T-handle on the right front of the injection pump to purge air from > the system. > > How did you get air into the system...changing Racor? > > I'm inside by coach typing this...call Cell 573.465.0527 if I can > help. > > Dick Gideon > 1989 35FC > Rolla, MO > > > --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" > wrote: > > > > So, last week I decided to do some "routine" maintenance on my Bird. > > Why is it that I always get into something when I do routine > > maintenance? ![]() > > > > How do I prime my 87 3208T? I read some posts about a "prime pump", > > but I don't know if mine has one. Below is how I got to this > problem, > > if it matters. > > > > Thanks, > > Alan > > 87FC35 > > > > Here's what happened. I took off my doghouse, which included > > disconnecting the guage on the side of the doghouse for the Racor. > > Later on, I decided I needed to turn my Bird around so I would be in > > the shade. While I was moving it, it started idling rough. Being the > > quick thinker that I am, I remembered the hose that was connected to > > the Racor. When I put my finger over the hose, it started running > > better. I finished turning it around, left it running to go check on > > if I had it positioned where I wanted it (now without my finger on > the > > hose). It then started idling rough again and died. > > > > I finished my maintenance, reconnected the racor guage and tried to > > start it, but it seems to not be getting fuel. I'm pretty sure it > had > > something to do with my disconnecting the guage. > > > Priming 3208T? - Henry Jay Hannigan - 09-30-2008 03:19 I have always had just as much luck just refilling the racor with fuel until it is at the top, put the T lid back on and start the engine.......kind of hard to start the engines and ask the wife in "curlers" to tell me when it is "bubbling" out the top. Stop! Good luck. Regards, Hank 90SP36 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > If you're only changing the Racor (in '83-up FCS) then change the > filter, leave the T-handle loose on the filter lid, start the > engine, when fuel starts to bubble out around the lid of the Racor > then tighten the T-handle. Self priming. > > And the oil-pressure sender on the oil filter on the '87-up (300hp > ATAAC) 3208 is the one with 2-wires, the single wire ones are for > the gauge and KYSOR system. > > - Jeff > > --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > > > > Alan: You need to place a jumper on the oil pressure switch (near > > oil filters) and then turn on ignition switch...the facet pump > near > > top front of the fuel tank should run and you can check by > listening > > at rear of coach to hear the clicking sound. > > > > If your Facet lift pump is operating you should see positive > pressure > > on the Racor guage by drivers right knee. You will need to open > the > > T-handle on the right front of the injection pump to purge air > from > > the system. > > > > How did you get air into the system...changing Racor? > > > > I'm inside by coach typing this...call Cell 573.465.0527 if I can > > help. > > > > Dick Gideon > > 1989 35FC > > Rolla, MO > > > > > > --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" > > wrote: > > > > > > So, last week I decided to do some "routine" maintenance on my > Bird. > > > Why is it that I always get into something when I do routine > > > maintenance? ![]() > > > > > > How do I prime my 87 3208T? I read some posts about a "prime > pump", > > > but I don't know if mine has one. Below is how I got to this > > problem, > > > if it matters. > > > > > > Thanks, > > > Alan > > > 87FC35 > > > > > > Here's what happened. I took off my doghouse, which included > > > disconnecting the guage on the side of the doghouse for the > Racor. > > > Later on, I decided I needed to turn my Bird around so I would > be in > > > the shade. While I was moving it, it started idling rough. Being > the > > > quick thinker that I am, I remembered the hose that was > connected to > > > the Racor. When I put my finger over the hose, it started running > > > better. I finished turning it around, left it running to go > check on > > > if I had it positioned where I wanted it (now without my finger > on > > the > > > hose). It then started idling rough again and died. > > > > > > I finished my maintenance, reconnected the racor guage and tried > to > > > start it, but it seems to not be getting fuel. I'm pretty sure > it > > had > > > something to do with my disconnecting the guage. > > > > > > |
