Fridge Inop on Propane - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fridge Inop on Propane (/showthread.php?tid=7188) |
Fridge Inop on Propane - Scott Forman - 10-01-2008 13:22 My fridge (Dometic RM2807...I believe original to the coach) is no longer working on propane. Works great on electric. When in propane "mode", I can hear the ignitor clicking, but it never lights. It worked fine last spring. No trouble with other propane features. Where should I start? I have zero experience working on one of these. Scott Forman 86 PT38 Memphis Fridge Inop on Propane - Don Bradner - 10-01-2008 13:53 Chris Bryant provides a large number of Dometic service and troubleshooting documents here: http://www.bryantrv.com/docs.html That would be my starting point. On 10/2/2008 at 1:22 AM Scott Forman wrote: >My fridge (Dometic RM2807...I believe original to the coach) is no >longer working on propane. Works great on electric. When in >propane "mode", I can hear the ignitor clicking, but it never lights. >It worked fine last spring. No trouble with other propane features. > >Where should I start? I have zero experience working on one of these. > >Scott Forman >86 PT38 >Memphis > > >------------------------------------ > >Yahoo! Groups Links > > > Fridge Inop on Propane - Curt Sprenger - 10-01-2008 14:52 Scott,
My notes from a year ago... OEM board control the Thermoelectric Solenoid Valve "intermittently". Installed a Dinosaur Board that I had on hand (bought it used). It did not work or "same problem". I called the board manufacture. They walked me through testing the OEM board and their board. End result, Dinosaur sent me a new board. Propane operation continues to work just fine. On Wed, Oct 1, 2008 at 6:53 PM, Don Bradner <"bluethunder@arcatapet.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Fridge Inop on Propane - Chuck Wheeler - 10-02-2008 02:44 Scott,
Go for the easy problems first. You should first hear a click which is the gas valve turning on, then a snap, snap, snap, ...... as theigniter fires. If this happens the control circuits are fine. There is one Phillips head screw that hold the cover over the burner in place. Check under this fordirt, mud daubers, etc.There is also a small gas valve in this area, make sure it is on. If it goes through the cycle and fails to light see if you can smell propane near the burner to see if you have gas. I usually turn on one of the heaters to make sure the propane system is working and the air is out. Good luck!
- Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Wednesday, October 01, 2008 8:22 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Fridge Inop on Propane My fridge (Dometic RM2807...I believe original to the coach) is no longer working on propane. Works great on electric. When in propane "mode", I can hear the ignitor clicking, but it never lights. It worked fine last spring. No trouble with other propane features. Where should I start? I have zero experience working on one of these. Scott Forman 86 PT38 Memphis Fridge Inop on Propane - Gregory OConnor - 10-02-2008 04:15 thats a good way to check the circuit board. is there not a prompt of the c-board that shuts off the gas valve when heat is not felt after a period of time? on the subject of refers and gas. the aftermarket mod I made and fan I use to vent my refer mechanicals in low pointing up to the vent and over the coil. I shrouded the boiler to keep from passivly cooling it with the fan. my fan pressurizes the compartment and pushes air out the roof vent. I like the way Scot positioned a fan in the stack blowing out because it wont pressurize the unburnt gas into the coach. Now I am concerned about the low resting fan becoming a spark igniter for unburned heavey LPG. the unobstructed step down below the floor that the refer vent opens to reveal is a functional design to exhaust heavy gas. a
greg94pt --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Scott, > > Go for the easy problems first. You should first hear a click which is the > gas valve turning on, then a snap, snap, snap, ...... as the igniter fires. > If this happens the control circuits are fine. There is one Phillips head > screw that hold the cover over the burner in place. Check under this for > dirt, mud daubers, etc. There is also a small gas valve in this area, make > sure it is on. If it goes through the cycle and fails to light see if you > can smell propane near the burner to see if you have gas. I usually turn on > one of the heaters to make sure the propane system is working and the air is > out. Good luck! > > - Chuck Wheeler- > FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman > Sent: Wednesday, October 01, 2008 8:22 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Fridge Inop on Propane > > > > My fridge (Dometic RM2807...I believe original to the coach) is no > longer working on propane. Works great on electric. When in > propane "mode", I can hear the ignitor clicking, but it never lights. > It worked fine last spring. No trouble with other propane features. > > Where should I start? I have zero experience working on one of these. > > Scott Forman > 86 PT38 > Memphis > |
