Access to steering reservoir - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Access to steering reservoir (/showthread.php?tid=7195) |
Access to steering reservoir - hippieforever3 - 10-03-2008 05:06 This is for an 1984 FC35. We have a slight steering fluid leak and need to check/add fluid. What is the easiest access to the reservoir? Regards, GPSGary 1984FC35 Washoe Lake State Park, NV Access to steering reservoir - Peter Goddu - 10-03-2008 15:44 --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > This is for an 1984 FC35. > > We have a slight steering fluid leak and need to check/add fluid. > > What is the easiest access to the reservoir? > > Regards, > GPSGary > 1984FC35 > Washoe Lake State Park, NV > Should be under the doghouse, right on top pf the engine. Round reservoir with conical top and dipstick. Access to steering reservoir - Kurt Achenbach - 10-04-2008 00:03 Gary, I used to have similar problem with my 83 FC, you may considder creating a vent in the Reservoir lid to eliviate some pressure while your at it. Kurt in NH had 83 FC (sold) now '97 BMC '37 --- In WanderlodgeForum@yahoogroups.com, "Peter Goddu" > > --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" > wrote: > > > > This is for an 1984 FC35. > > > > We have a slight steering fluid leak and need to check/add fluid. > > > > What is the easiest access to the reservoir? > > > > Regards, > > GPSGary > > 1984FC35 > > Washoe Lake State Park, NV > > > Should be under the doghouse, right on top pf the engine. Round > reservoir with conical top and dipstick. > Access to steering reservoir - david edwards - 10-04-2008 06:12
Access to steering reservoir - hippieforever3 - 10-04-2008 07:26 My reservoir looks different and is loacted differently than your pictures but the combination of the descriptions and your pictures gave me the confidence to throw power steering fluid into it. The squeeling has almost stopped. What FC group? Where? Regards, GPSGary --- In WanderlodgeForum@yahoogroups.com, david edwards > > Power steering systems on FC's are a problem. I have a thread and pictures (here I think but also over on the FC group) explaining how to upgrade the hoses, insulate them, add a cooler and enlarge the reservoir. Fluid runs too hot on the original system. I was able to reduce fluid temperatures by about 100 degrees with the changes I made. > > kerry > 82 FC > Denver > Access to steering reservoir - Richard Gideon - 10-04-2008 07:53 Try this URL for joining the FC group http://autos.groups.yahoo.com/group/FC_Wanderlodge/ Dick Gideon 1989 35FC --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > My reservoir looks different and is loacted differently than your > pictures but the combination of the descriptions and your pictures > gave me the confidence to throw power steering fluid into it. > > The squeeling has almost stopped. > > What FC group? Where? > > Regards, > GPSGary > > > > --- In WanderlodgeForum@yahoogroups.com, david edwards > > > > > Power steering systems on FC's are a problem. I have a thread and > pictures (here I think but also over on the FC group) explaining how > to upgrade the hoses, insulate them, add a cooler and enlarge the > reservoir. Fluid runs too hot on the original system. I was able to > reduce fluid temperatures by about 100 degrees with the changes I > made. > > > > kerry > > 82 FC > > Denver > > > |
