89SP air brake wont release, all pressure gauges normal(115) front +rear - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 89SP air brake wont release, all pressure gauges normal(115) front +rear (/showthread.php?tid=7206) Pages: 1 2 |
89SP air brake wont release, all pressure gauges normal(115) front +rear - Ed Gardels - 10-07-2008 07:38 Went to storage today to bring bus home, and the brake knob wont push in releasing the brakes. It feels like air pressue pushing back, preventing me from pushing it in.All the pressures came up normal, both front and rear gauges register 115.Step operates. Everything seems normal. I put buss in reverse to back out of my space and it wont move. then tried fwd, same result. If I add power in reverse it will try to move. I tried and tried to press brake knob in but it wont go. When I press brake pedel I here normal air release sounds. Im not very experienced, am I doing something wrong? Any help would be apprieated. Thanks in advance!! Ed Gardels 89sp Arlington Texas 89SP air brake wont release, all pressure gauges normal(115) front +rear - Rob Robinson - 10-07-2008 08:01 Ed someone more experienced individual will chime in here soon but for now I would not try overcoming the emergency brake by putting it into driver or reverse. Nothing good can come of that.
2008/10/7 Ed Gardels <"egardata@tx.rr.com">
-- Rob, Sue & Merlin Robinson 94 WLWB 89SP air brake wont release, all pressure gauges normal(115) front +rear - Leroy Eckert - 10-07-2008 08:05
89SP air brake wont release, all pressure gauges normal(115) front +rear - Ed Gardels - 10-07-2008 08:24 --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert >Leroy, Thanks for responding,I hope I didnt have foot on pedal, I dont think I did. but I have gone brain dead before Thanks Ed Gardels 89sp Arlington Texas > Are you holding the brake pedal down when you push the button in.?? Try and see if it will work. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Tue, 10/7/08, Rob Robinson > From: Rob Robinson > Subject: Re: [WanderlodgeForum] 89SP air brake wont release, all pressure gauges normal(115) front +rear > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, October 7, 2008, 4:01 PM > > > > > > > > > > > > Ed someone more experienced individual will chime in here soon but for now I would not try overcoming the emergency brake by putting it into driver or reverse. Nothing good can come of that. > > > 2008/10/7 Ed Gardels > > > > > > > Went to storage today to bring bus home, and the brake knob wont push > in releasing the brakes. It feels like air pressue pushing back, > preventing me from pushing it in.All the pressures came up normal, both > > front and rear gauges register 115.Step operates. Everything seems > normal. I put buss in reverse to back out of my space and it wont move. > then tried fwd, same result. If I add power in reverse it will try to > > move. I tried and tried to press brake knob in but it wont go. When I > press brake pedel I here normal air release sounds. > Im not very experienced, am I doing something wrong? Any help would > be apprieated. Thanks in advance!! > > Ed Gardels 89sp > Arlington Texas > > > > > -- > Rob, Sue & Merlin Robinson > > 94 WLWB > 89SP air brake wont release, all pressure gauges normal(115) front +rear - Rob Robinson - 10-07-2008 08:26 I never release my emergency brake without first depressing my service brakes.
-- Rob, Sue & Merlin Robinson 94 WLWB 89SP air brake wont release, all pressure gauges normal(115) front +rear - Leroy Eckert - 10-07-2008 08:32
89SP air brake wont release, all pressure gauges normal(115) front +rear - Ed Gardels - 10-07-2008 08:33 --- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" wrote: > Some good points brought up.. Can you press on the brake while releasing the emergency brake(parking brake)at the same time? Thanks Ed Gardels 89sp Arlington Texas > Went to storage today to bring bus home, and the brake knob wont push > in releasing the brakes. It feels like air pressue pushing back, > preventing me from pushing it in.All the pressures came up normal, both > front and rear gauges register 115.Step operates. Everything seems > normal. I put buss in reverse to back out of my space and it wont move. > then tried fwd, same result. If I add power in reverse it will try to > move. I tried and tried to press brake knob in but it wont go. When I > press brake pedel I here normal air release sounds. > Im not very experienced, am I doing something wrong? Any help would > be apprieated. Thanks in advance!! > Ed Gardels 89sp > Arlington Texas > 89SP air brake wont release, all pressure gauges normal(115) front +rear - Leroy Eckert - 10-07-2008 08:45
89SP air brake wont release, all pressure gauges normal(115) front +rear - Pete Masterson - 10-07-2008 10:40 I note that I was having some difficulties with releasing my parking brake, and I found that the screws holding the knob to the bracket were loose. Tightened them up, and it worked better. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road near Lancaster, PA On Oct 7, 2008, at 4:45 PM, Leroy Eckert wrote: > Yes. Apply the service brakes and push the button in. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Tue, 10/7/08, Ed Gardels > From: Ed Gardels > Subject: [WanderlodgeForum] Re: 89SP air brake wont release, all > pressure gauges normal(115) front +rear > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, October 7, 2008, 4:33 PM > > --- In WanderlodgeForum@ yahoogroups. com, "Ed Gardels" > > wrote: > > > > Some good points brought up.. Can you press on the brake while > releasing the emergency brake(parking brake)at the same time? > > Thanks > Ed Gardels 89sp > Arlington Texas > > Went to storage today to bring bus home, and the brake knob wont > push > > in releasing the brakes. It feels like air pressue pushing back, > > preventing me from pushing it in.All the pressures came up normal, > both > > front and rear gauges register 115.Step operates. Everything seems > > normal. I put buss in reverse to back out of my space and it wont > move. > > then tried fwd, same result. If I add power in reverse it will > try to > > move. I tried and tried to press brake knob in but it wont go. > When I > > press brake pedel I here normal air release sounds. > > Im not very experienced, am I doing something wrong? Any help would > > be apprieated. Thanks in advance!! > > Ed Gardels 89sp > > Arlington Texas > > > > > > 89SP air brake wont release, all pressure gauges normal(115) front +rear - Gregory OConnor - 10-07-2008 15:51 you dont need the service brake (foot pedal) on to release the spring brake. I park on a slight incline with the tow hooked and release the spring/parking brake, let it roll to about 2 mph then pull the park/spring brake lever to a stop, never touching the pedal. the parking brake is refered to as the spring brake because there is a spring that is always trying to apply the brake. when you release the brake the valve fills a chamber behind the spring and compresses it in. the drive axle has a brake chamber with twin pumkin looking things. one pumkin is for the service brake and one holds the spring. There is a long bolt on each twin pumkin that is a tool to manualy release the brake for towing or emergancies. I wonder if the brake camed over??? that is if the shoes are so worn the lever that pushes the shoe to the drum went past center????? it could also be modulator valve hung up or the 2 way valve. . I would try dumping the air by shutting the bus of and pumping the service brake untill it exhaust then try once again but wait untill the tanks are full to max before you try and release the parking spring brake. if its a valve problem, chock the tires and dont leave air in the tanks while parked. Greg94ptCa |
