HOT SKIN - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: HOT SKIN (/showthread.php?tid=723) |
HOT SKIN - Jay Darst - 05-29-2005 05:40 My Bird is setting in my driveway and plugged into a standard 20 amp receptacle via the 50amp/30amp cordset with a 30amp to 15amp adapter. I have used this method here at home for 2 1/2 years and have never had HOT SKIN. It has been plugged in for about 10 days now(this time). I have been in and out of the Bird most every day. No shocks. But this morning, with door key in hand, I touched the door key to the deadbolt and got a shock.(DAM!) I have read old posts that indicate "there must be something wrong". Am looking for something a bit more definitive. Being the Bird has never done this, and that it hasn't moved since having no HOT SKIN, I doubt that it is a bare skinned wire. In reading information provided by the Freedom Inverter, there is a section that indicates that the unit internally bonds the AC output white(neutral) and green(ground) when the unit is OFF or in the INVERT mode (neither of these being the case today). When incoming AC is applied, this bond is lifted. When AC power is applied, the grounding system is supplied by the source(in this case, my house wiring system), where neutral and earth ground are bonded together. This probably has nothing to with it, but just in case I am missing something here... Jeff Miller had posted a few years back that generally the power source or the cordset are the issue. With the adapters taking us from 50amp to 15amp, can't be sure if thats an issue, its always worked before. Could be the source ground system? Not sure how to check that. HOT SKIN conditions are caused by? Any help will be greatly appreciated! Thanks Jay Darst 85PT40 SpringfieldIL HOT SKIN - Jay Darst - 05-29-2005 06:07 ****NEVER MIND**** Went out and checked the cords(10-3 extension cord, 35' . Thecordage goes like this: 1. from Bird 50 amp recept to 50amp/30amp std BB adapter cord 2. 50/30 cord to 30/15 adapter 3. 30/15 adapter to above mentioned 35' 10-3 extension cord 4. 35' cord to a 5' 12-3 cord(with the ground prong cut off the male end) Forgot about that little cord not being grounded. Changed cords to one with proper prongs and plugged it into the house. END of HOT SKIN! As to being "in and out of the Bird Daily", Always had some kind of shoes on that would provide some insulation. This morning I was bare foot. Next time I will do a bit more diag before posting... thanks to those of you who had started sifering the probelm. Jay Darst 85PT40 SpringfieldIL --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > My Bird is setting in my driveway and plugged into a standard 20 amp > receptacle via the 50amp/30amp cordset with a 30amp to 15amp adapter. > > I have used this method here at home for 2 1/2 years and have never > had HOT SKIN. > > It has been plugged in for about 10 days now(this time). I have been > in and out of the Bird most every day. No shocks. > > But this morning, with door key in hand, I touched the door key to > the deadbolt and got a shock.(DAM!) > > I have read old posts that indicate "there must be something wrong". > > Am looking for something a bit more definitive. Being the Bird has > never done this, and that it hasn't moved since having no HOT SKIN, > I doubt that it is a bare skinned wire. > > In reading information provided by the Freedom Inverter, there is a > section that indicates that the unit internally bonds the AC output > white(neutral) and green(ground) when the unit is OFF or in the > INVERT mode (neither of these being the case today). > > When incoming AC is applied, this bond is lifted. When AC power is > applied, the grounding system is supplied by the source(in this > case, my house wiring system), where neutral and earth ground are > bonded together. > > This probably has nothing to with it, but just in case I am missing > something here... > > Jeff Miller had posted a few years back that generally the power > source or the cordset are the issue. With the adapters taking us > from 50amp to 15amp, can't be sure if thats an issue, its always > worked before. Could be the source ground system? Not sure how to > check that. > > HOT SKIN conditions are caused by? > > Any help will be greatly appreciated! > > Thanks > Jay Darst > 85PT40 > SpringfieldIL HOT SKIN - Stephen Birtles - 05-29-2005 10:42 had 2 cases of hot skin first was short in roof air conditioner second was wife's credit card bill ( just kidding Dear) Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > My Bird is setting in my driveway and plugged into a standard 20 amp > receptacle via the 50amp/30amp cordset with a 30amp to 15amp adapter. > > I have used this method here at home for 2 1/2 years and have never > had HOT SKIN. > > It has been plugged in for about 10 days now(this time). I have been > in and out of the Bird most every day. No shocks. > > But this morning, with door key in hand, I touched the door key to > the deadbolt and got a shock.(DAM!) > > I have read old posts that indicate "there must be something wrong". > > Am looking for something a bit more definitive. Being the Bird has > never done this, and that it hasn't moved since having no HOT SKIN, > I doubt that it is a bare skinned wire. > > In reading information provided by the Freedom Inverter, there is a > section that indicates that the unit internally bonds the AC output > white(neutral) and green(ground) when the unit is OFF or in the > INVERT mode (neither of these being the case today). > > When incoming AC is applied, this bond is lifted. When AC power is > applied, the grounding system is supplied by the source(in this > case, my house wiring system), where neutral and earth ground are > bonded together. > > This probably has nothing to with it, but just in case I am missing > something here... > > Jeff Miller had posted a few years back that generally the power > source or the cordset are the issue. With the adapters taking us > from 50amp to 15amp, can't be sure if thats an issue, its always > worked before. Could be the source ground system? Not sure how to > check that. > > HOT SKIN conditions are caused by? > > Any help will be greatly appreciated! > > Thanks > Jay Darst > 85PT40 > SpringfieldIL |
