Bulk oil system - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Bulk oil system (/showthread.php?tid=7327) |
Bulk oil system - hippieforever3 - 11-03-2008 07:44 I looked in the little bit of documentation I have and searched this forum on bulk oil. Can someone please explain how the bulk oil system works and where the tank (and fill) are located? Thanks, GPSGary 1984FC35 Bulk oil system - jim riordan - 11-03-2008 08:41 Gary,
On my coach88 WLWL the bulk oil tank in at the rear curbside Starboard of the coach. It is a switchable pressurized tank that has a dispenser with a hand held wand. it has a meter that keeps track of oil dispersed. Great option.
Jim Riordan
From: hippieforever3 To: WanderlodgeForum@yahoogroups.com Sent: Monday, November 3, 2008 2:44:40 PM Subject: [WanderlodgeForum] Bulk oil system I looked in the little bit of documentation I have and searched this forum on bulk oil. Can someone please explain how the bulk oil system works and where the tank (and fill) are located? Thanks, GPSGary 1984FC35 Bulk oil system - Alan Hetzel - 11-03-2008 08:46 What is the purpose of that? Dorn Hetzel 77FC35 Hogansville, GA On Mon, Nov 3, 2008 at 3:41 PM, jim riordan <"jqrjr@yahoo.com"> wrote:
Bulk oil system - jim riordan - 11-03-2008 08:48 to fill the engine oil eaisly ant to have oil onboard, very nice option! Jim RIordan Alan Hetzel
Bulk oil system - John - 11-03-2008 09:01 On my 83 Fc the tank is in the LP Compartment just forward of the door.
My understanding of the the system is this.
When you need to fill engine oil you flip a lever on the tank that will put pressure from the air system into the oil tank.
Then you go to the engine and dial up how much oil you wish to add, then squeeze the trigger and it will dispense that much oil though the hand wand.
I am very new at this, but that is the way I understand it to work
thx
John
No virus found in this outgoing message Checked by PC Tools AntiVirus (4.0.0.26 - 10.100.050). http://www.pctools.com/free-antivirus/ Bulk oil system - hippieforever3 - 11-03-2008 09:51 Thanks, That's what I needed. Perfect except there is no lever on the tank. Regards, GPSGary --- In WanderlodgeForum@yahoogroups.com, "John" > > On my 83 Fc the tank is in the LP Compartment just forward of the door. > > My understanding of the the system is this. > > When you need to fill engine oil you flip a lever on the tank that will put pressure from the air system into the oil tank. > Then you go to the engine and dial up how much oil you wish to add, then squeeze the trigger and it will dispense that much oil though the hand wand. > > I am very new at this, but that is the way I understand it to work > > thx > John > > > ----- Original Message ----- > From: hippieforever3 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, November 03, 2008 11:44 > Subject: [WanderlodgeForum] Bulk oil system > > > I looked in the little bit of documentation I have and searched this > forum on bulk oil. > > Can someone please explain how the bulk oil system works and where the > tank (and fill) are located? > > Thanks, > GPSGary > 1984FC35 > > > > > > No virus found in this outgoing message > Checked by PC Tools AntiVirus (4.0.0.26 - 10.100.050). > http://www.pctools.com/free-antivirus/ > Bulk oil system - brad barton - 11-03-2008 10:27 It's an electric toggle switch..and I think it's there in the engine. It might even have an indicator light on the switch panel. You need to have the engine off..but have plenty of air pressure built up at the time. BradBarton00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: debra@... Date: Mon, 3 Nov 2008 21:51:11 +0000 Subject: [WanderlodgeForum] Re: Bulk oil system
Thanks, That's what I needed. Perfect except there is no lever on the tank. Regards, GPSGary --- In "WanderlodgeForum@yahoogroups.com", "John" > > On my 83 Fc the tank is in the LP Compartment just forward of the door. > > My understanding of the the system is this. > > When you need to fill engine oil you flip a lever on the tank that will put pressure from the air system into the oil tank. > Then you go to the engine and dial up how much oil you wish to add, then squeeze the trigger and it will dispense that much oil though the hand wand. > > I am very new at this, but that is the way I understand it to work > > thx > John > > > ----- Original Message ----- > From: hippieforever3 > To: "WanderlodgeForum@yahoogroups.com" > Sent: Monday, November 03, 2008 11:44 > Subject: [WanderlodgeForum] Bulk oil system > > > I looked in the little bit of documentation I have and searched this > forum on bulk oil. > > Can someone please explain how the bulk oil system works and where the > tank (and fill) are located? > > Thanks, > GPSGary > 1984FC35 > > > > > > No virus found in this outgoing message > Checked by PC Tools AntiVirus (4.0.0.26 - 10.100.050). > http://www.pctools. > Store, manage and share up to 5GB with Windows Live SkyDrive. Start uploading now Bulk oil system - dthollis1961 - 11-03-2008 11:15 Gary, There are 2 switches on my 84FC. One on the right side lower dash and the other is under the engine doghouse left side mounted on the bracket that holds the dial where you select the amount of oil to be dispensed. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" wrote: > > Thanks, > > That's what I needed. Perfect except there is no lever on the tank. > > Regards, > GPSGary Bulk oil system - Ryan Wright - 11-05-2008 16:22 Hey Gary, http://www.ryanwright.com/tmp/eng-gauge1.jpg This is my '86 PT-40. Not sure if yours would be setup similarly or not, but the blue gauge on the right is the bulk oil fill gauge. This tells you how much oil you've dispensed. The on/off switch is right there immediately by the gauge, upper left side of it. That energizes a solenoid to send air pressure into the tank. No air pressure = no bulk oil filling. As others said this is, indeed, a very nice option. It ensures I have plenty of oil on board for just about any situation I might encounter, which is nice since the right type of oil for my 8V92, Delo 100 40wt, is difficult to find and I have to special order by the case. If I'm in the middle of nowhere and need oil, I have it. I actually do my oil changes right out of this tank, then fill the tank back up with fresh oil. This keeps the oil in the tank from getting too old and it's easier to add oil with that handy little dispensing wand vs. right out of the 1 gallon jugs. -Ryan '86 PT-40 8V92 On Mon, Nov 3, 2008 at 1:51 PM, hippieforever3 > Thanks, > > That's what I needed. Perfect except there is no lever on the tank. > > Regards, > GPSGary > > Bulk oil system - cfsomers@... - 11-08-2008 00:29 I am a little behind on this, but this bulk oil conversation brings up the question. Would an 81fc have this bulk oil system and if so how would i know? Chuck 81FCSB FLORIDA. > It's an electric toggle switch..and I think it's there in the engine. It > might even have an indicator light on the switch panel. You need to have > the engine off..but have plenty of air pressure built up at the time.Brad > Barton 00LXiDFW bbartonwx@... > > To: WanderlodgeForum@...: debra@...: Mon, 3 > Nov 2008 21:51:11 +0000Subject: [WanderlodgeForum] Re: Bulk oil system > > > > > Thanks,That's what I needed. Perfect except there is no lever on the > tank.Regards,GPSGary--- In WanderlodgeForum@yahoogroups.com, "John" > > forward of the door.> > My understanding of the the system is this.> > > When you need to fill engine oil you flip a lever on the tank that will > put pressure from the air system into the oil tank.> Then you go to the > engine and dial up how much oil you wish to add, then squeeze the trigger > and it will dispense that much oil though the hand wand.> > I am very new > at this, but that is the way I understand it to work> > thx> John> > > > ----- Original Message ----- > From: hippieforever3 > To: > WanderlodgeForum@yahoogroups.com > Sent: Monday, November 03, 2008 11:44> > Subject: [WanderlodgeForum] Bulk oil system> > > I looked in the little > bit of documentation I have and searched this > forum on bulk oil.> > Can > someone please explain how the bulk oil system works and where the > tank > (and fill) are located?> > Thanks,> GPSGary> 1984FC35> > > > > > No virus > found in this outgoing message> Checked by PC Tools AntiVirus (4.0.0.26 - > 10.100.050).> http://www.pctools.com/free-antivirus/> > > > > > > _________________________________________________________________ > Store, manage and share up to 5GB with Windows Live SkyDrive. > http://skydrive.live.com/welcome.aspx?provision=1?ocid=TXT_TAGLM_WL_skydrive_102\ 008 |
