83 Wanderlodge 40 PT A/C & electric heat relays - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 83 Wanderlodge 40 PT A/C & electric heat relays (/showthread.php?tid=7367) |
83 Wanderlodge 40 PT A/C & electric heat relays - wellsd62 - 11-13-2008 03:31 Who Knows? In wardrobe closet, under breaker panel, metal enclosure with three relays that switch power for cental air and or electric heat. Where is the 12v switched for these relays? Appears that 12v power is hot to all three relays and the ground is switched. Two of the relays are working normally the other pulls in if I ground it. Are these relays only switched at the master power switch under the dash, or are there other switches or controls I'm not seeing. The one causing the problem is for the bedroom A/C and heat. WHO KNOWS??????????????? Thanks Dan 83 Wanderlodge 40 PT A/C & electric heat relays - Ralph L. Fullenwider - 11-13-2008 08:32 Summer/ winter switch switches most, then the over head switches for A/C turns into heaters. Think, winter/ heat Summer/ Cool Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 03:31 PM 11/13/2008 +0000, you wrote: >Who Knows? >In wardrobe closet, under breaker panel, metal enclosure with three >relays that switch power for cental air and or electric heat. Where is >the 12v switched for these relays? Appears that 12v power is hot to all >three relays and the ground is switched. Two of the relays are working >normally the other pulls in if I ground it. Are these relays only >switched at the master power switch under the dash, or are there other >switches or controls I'm not seeing. The one causing the problem is for >the bedroom A/C and heat. WHO KNOWS??????????????? >Thanks Dan > > |
