Rear view monitor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Rear view monitor (/showthread.php?tid=7388) |
Rear view monitor - jburgessx2 - 03-29-2009 15:04 Has anyone replaced the tv monitor for the back-up camera on an 85 PT40? My tv/monitor seems very worn out, heavy and needs to be replaced. Of course, I would like to do it as economically as possible. Also, do I have to replace all the cables or will the existing cables work with new systems. I realize I might have to replace the camera as well. Thanks in advance. Jerry 85 PT40 Rear view monitor - surplushound - 03-30-2009 02:23 --- In WanderlodgeForum@yahoogroups.com, "jburgessx2" > > Has anyone replaced the tv monitor for the back-up camera on an 85 PT40? My tv/monitor seems very worn out, heavy and needs to be replaced. Of course, I would like to do it as economically as possible. Also, do I have to replace all the cables or will the existing cables work with new systems. I realize I might have to replace the camera as well. > > Thanks in advance. > > Jerry > 85 PT40 > I am interested to see the reply's you get Jerry. My monitor is not performing well either. Sam Powers 85 PT-40 Lexington,OH Rear view monitor - Curt Sprenger - 03-30-2009 02:58 Adapters are available so the existing cables in our coach could be used. I installed this backup camera CC25NV-B and the lens is a Fuji yv5x27r4bsa2L. The original backup monitor was replaced with a 7" LCD. I did not consider the using the TV (or replacing the TV) at that time and use it as the backup monitor. Curt Sprenger On Mon, Mar 30, 2009 at 7:23 AM, surplushound <"surplushound@yahoo.com"> wrote:
Rear view monitor - Wayne Kotila - 03-30-2009 09:29 I have a 1985 PT40 and had to replace my rear camera monitor above the windsheild. I went to Radio Shack andbought a small 12 volt black and white tv that fit behind the existing clear panel, I think it was a 5", I did this about 5 years ago and I think at that time I paid $79.00 for the tv.
Wayne
From: jburgessx2 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 29, 2009 10:04:10 PM Subject: [WanderlodgeForum] Rear view monitor Has anyone replaced the tv monitor for the back-up camera on an 85 PT40? My tv/monitor seems very worn out, heavy and needs to be replaced. Of course, I would like to do it as economically as possible. Also, do I have to replace all the cables or will the existing cables work with new systems. I realize I might have to replace the camera as well. Thanks in advance. Jerry 85 PT40 Rear view monitor - jburgessx2 - 03-30-2009 11:14 Wayne, How do you turn the tv off/on if it's behind the clear panel? Or, did you just remove the clear panel? Jerry 85 PT40 --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila > > I have a 1985 PT40 and had to replace my rear camera monitor above the windsheild. I went to Radio Shack and bought a small 12 volt black and white tv that fit behind the existing clear panel, I think it was a 5", I did this about 5 years ago and I think at that time I paid $79.00 for the tv. > Wayne > > > > > ________________________________ > From: jburgessx2 > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, March 29, 2009 10:04:10 PM > Subject: [WanderlodgeForum] Rear view monitor > > > Has anyone replaced the tv monitor for the back-up camera on an 85 PT40? My tv/monitor seems very worn out, heavy and needs to be replaced. Of course, I would like to do it as economically as possible. Also, do I have to replace all the cables or will the existing cables work with new systems. I realize I might have to replace the camera as well. > > Thanks in advance. > > Jerry > 85 PT40 > Rear view monitor - Wayne Kotila - 03-30-2009 12:01 Abovethe drivers head on the left is the pull out on/off knob for the old tv/monitor and the old tv chassis, I removed the old aluminum box that contained the old chassis and cut the wires to that pull out tv on/off knob.
Then I took the 12 volt wires that I was running to power the new Radio Schack tv andcut one of them (the power wire) and soldered the ends to the terminals on the back of that existing switch,now that old switch turns the new tv monitor on and off.If you can find the 12 volt wires that powered the old chassis you can use them and that way the original fuse or breaker thatprotected the old monitor will be protecting the new one.
Good Luck
Wayne
From: jburgessx2 To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 30, 2009 6:14:54 PM Subject: [WanderlodgeForum] Re: Rear view monitor Wayne, How do you turn the tv off/on if it's behind the clear panel? Or, did you just remove the clear panel? Jerry 85 PT40 --- In "WanderlodgeForum%40yahoogroups.com", Wayne Kotila > > I have a 1985 PT40 and had to replace my rear camera monitor above the windsheild. I went to Radio Shack andbought a small 12 volt black and white tv that fit behind the existing clear panel, I think it was a 5", I did this about 5 years ago and I think at that time I paid $79.00 for the tv. > Wayne > > > > > ____________ _________ _________ __ > From: jburgessx2 > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Sunday, March 29, 2009 10:04:10 PM > Subject: [WanderlodgeForum] Rear view monitor > > > Has anyone replaced the tv monitor for the back-up camera on an 85 PT40? My tv/monitor seems very worn out, heavy and needs to be replaced. Of course, I would like to do it as economically as possible. Also, do I have to replace all the cables or will the existing cables work with new systems. I realize I might have to replace the camera as well. > > Thanks in advance. > > Jerry > 85 PT40 > Rear view monitor - Jerry Burgess - 03-30-2009 14:09 Wayne,
Thanks for the update. That sure sounds like a good way to handle the old tv stuff.
Jerry
85 PT40
From: Wayne Kotila To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 30, 2009 5:01:22 PM Subject: Re: [WanderlodgeForum] Re: Rear view monitor Abovethe drivers head on the left is the pull out on/off knob for the old tv/monitor and the old tv chassis, I removed the old aluminum box that contained the old chassis and cut the wires to that pull out tv on/off knob.
Good Luck
Wayne
From: jburgessx2 To: WanderlodgeForum@ yahoogroups. com Sent: Monday, March 30, 2009 6:14:54 PM Subject: [WanderlodgeForum] Re: Rear view monitor Wayne, How do you turn the tv off/on if it's behind the clear panel? Or, did you just remove the clear panel? Jerry 85 PT40 --- In "WanderlodgeForum%40yahoogroups.com", Wayne Kotila > > I have a 1985 PT40 and had to replace my rear camera monitor above the windsheild. I went to Radio Shack andbought a small 12 volt black and white tv that fit behind the existing clear panel, I think it was a 5", I did this about 5 years ago and I think at that time I paid $79.00 for the tv. > Wayne > > > > > ____________ _________ _________ __ > From: jburgessx2 > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Sunday, March 29, 2009 10:04:10 PM > Subject: [WanderlodgeForum] Rear view monitor > > > Has anyone replaced the tv monitor for the back-up camera on an 85 PT40? My tv/monitor seems very worn out, heavy and needs to be replaced. Of course, I would like to do it as economically as possible. Also, do I have to replace all the cables or will the existing cables work with new systems. I realize I might have to replace the camera as well. > > Thanks in advance. > > Jerry > 85 PT40 > Rear view monitor - GARY MINKER - 04-07-2009 06:51
Rear view monitor - J R - 04-07-2009 17:45 When I bought our coach, the PO gave me a new system he got,(Rear View Safety Model RVS-770613)but had not installed. Marked on the box is $399.00 not sure if he paid that or not. However I went on line to see what I had, here is a link http://rearviewsafety.com/content/blogsection/2/7/ This system sells for $199.00 on-line. Now I have yet to install this system or try it, so I can't say how well it works. I can tell you that it seems to be well made unit,(but that in it's self, don't mean much, till you turn it on). When I get it installed or tested, I'll post more. J R in Washington (South of SEA-TAC) aka jr182pilot Bug Smasher; 1982 PT40 Rear view monitor - Bill Garamella - 04-07-2009 18:37 JR, I installed the identical system in our 83 FC about 1.5 years ago ($199) and It works well. Because I installed the camera behind the glass camera window, the IR lights bounce off it in the dark and there is too much glare to see in the dark. If you mount the camera externally, you will not have this problem. I am considering mounting it outside, but I am reluctant to drill more holes. So far, this is something I can live with. There may be a way to disconnect the IR lights I have not researched this yet. NH Bill 1983 FC "Casa Billisa" |
