VENT GRILLS - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: VENT GRILLS (/showthread.php?tid=7400) |
VENT GRILLS - nelsons - 04-17-2010 02:46 Does anyone know where to buy replacment air vent grills for a 1994 Wanderlodge? Thanks Nelson SLinkman 1994 40' VENT GRILLS - Fred Hulse - 04-17-2010 03:53 Not quite certain what you are referring to. Nelson
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 VENT GRILLS - Ralph - 04-17-2010 04:53 Hello Nelson: Many of the items were fashioned from Chrysler products of one year or other. I am not sure which your referring to. The grills in the front dash and those in front of the co-pilots seat or the vent along the top edge running down each side of the salon and in some Coaches on into the galley. Your inquiry is the first that I can remember on the Forum. As to the headlight switch, good find, though I would suspect a possible mis wiring or wiring change on the switch proper. Perhaps, in trying to repair another problem and failing, a second problem was induced. With out a doubt the switch must be replaced but you need the schematic of the wiring to be sure it proper. One must ask the following question when any problem pops up. How is it supposed to work properly, in the first place? Then one goes about chasing a problem with a plan. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "nelsons" Date: Sat, 17 Apr 2010 14:46:27 To: Subject: [WanderlodgeForum] VENT GRILLS Does anyone know where to buy replacment air vent grills for a 1994 Wanderlodge? Thanks Nelson SLinkman 1994 40' ------------------------------------ Yahoo! Groups Links VENT GRILLS - Ralph - 04-17-2010 05:00 Sorry I also meant to mention, in most of the Birds of the 90's, Bluebird finally got the hint and started taking most of the amp load that used to go through the switch and made the switch pull the coil of a relay and the amperage ran through the contacts of that relay instead of the switch. Did that one item ever fix a whole host of problems, and about time too. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "Ralph" Date: Sat, 17 Apr 2010 16:53:25 To: Wanderlodge Forum Subject: Re: [WanderlodgeForum] VENT GRILLS Hello Nelson: Many of the items were fashioned from Chrysler products of one year or other. I am not sure which your referring to. The grills in the front dash and those in front of the co-pilots seat or the vent along the top edge running down each side of the salon and in some Coaches on into the galley. Your inquiry is the first that I can remember on the Forum. As to the headlight switch, good find, though I would suspect a possible mis wiring or wiring change on the switch proper. Perhaps, in trying to repair another problem and failing, a second problem was induced. With out a doubt the switch must be replaced but you need the schematic of the wiring to be sure it proper. One must ask the following question when any problem pops up. How is it supposed to work properly, in the first place? Then one goes about chasing a problem with a plan. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "nelsons" Date: Sat, 17 Apr 2010 14:46:27 To: Subject: [WanderlodgeForum] VENT GRILLS Does anyone know where to buy replacment air vent grills for a 1994 Wanderlodge? Thanks Nelson SLinkman 1994 40' ------------------------------------ Yahoo! Groups Links ------------------------------------ Yahoo! Groups Links VENT GRILLS - nelson slinkman - 04-17-2010 10:55
VENT GRILLS - Ralph - 04-17-2010 11:14 VENT GRILLS - Ernie Ekberg - 04-17-2010 11:30
