Toad / Tow Brakes - Printable Version
+--- Thread: Toad / Tow Brakes (/showthread.php?tid=7409)
Pages: 1 2
Toad / Tow Brakes - drw907 - 11-17-2008 15:50
We will begin full timing within the next 6 months. Our motorhome is
a 1994 Bluebird BMC diesel pusher with a Spartan air brake chassis
(mountain master type class) , tow car is a 2005 Subaru Impreza WRX
wagon 5 speed.
I have done some net research, and have not made a final decison.
I do not want to have to add/remove any components inside the the tow
car to tow/drive. I want feedback inside the coach of what the toad
brakes are doing.
I will likely install myself, and while mechanically inclined, and I
have most tools, easier install is always nice - if it doesn't give
up too many features.
Thus far I am at:
SMI Air Force One
SMI Stay In Play Duo
US Gear Unified Tow Brake UTB-1000
I could use any advice/rational to help me decide,
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
Toad / Tow Brakes - Curt Sprenger - 11-17-2008 18:05
Dan,
I have an SMI unit installed in our '87 PT38 and Bronco toad. The SMI gives feedback to let you know the toad brakes are applied, and the dial allows setting the amount of toad braking. This was installed a couple years ago so SMI may have updated units now. If you need more info. don't hesitate to let me know.
wagon 5 speed.
brakes are doing.
Thus far I am at:
SMI Air Force One
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
Curt Sprenger
Anaheim Hills, CA
Toad / Tow Brakes - Wallace Craig - 11-18-2008 02:50
I have had the u s gear on two coaches and find it excellent. I know nothing of the others.
Wallace Craig
95 WLWB 42
Azle, Texas
--- On Mon, 11/17/08, drw907 wrote:
Subject: [WanderlodgeForum] Toad / Tow Brakes
Date: Monday, November 17, 2008, 9:50 PM
We will begin full timing within the next 6 months. Our motorhome is a 1994 Bluebird BMC diesel pusher with a Spartan air brake chassis (mountain master type class) , tow car is a 2005 Subaru Impreza WRX wagon 5 speed.
I do not want to have to add/remove any components inside the the tow car to tow/drive. I want feedback inside the coach of what the toad brakes are doing.
I will likely install myself, and while mechanically inclined, and I have most tools, easier install is always nice - if it doesn't give up too many features.
Thus far I am at:
SMI Air Force One
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:WanderlodgeForum-digest@yahoogroups.com mailto:WanderlodgeForum-fullfeatured@yahoogroups.com
Toad / Tow Brakes - jim riordan - 11-18-2008 04:23
Dan,
I have both a jeep wrangler and chevy suburban, as toads. When I towed the jeep wrangler I did not have an aux braking system, the coach seemed to handle this fine. a breakaway situation would have been a problem however. When I decided to tow the suburban I did research and ended up using the M&G system.The hardest part was probally tapping into the brake system of the bus. Installation on the suburban took some time but once we read the instructions things went faster. LOL
www.m-gengineering.com
Jim Riordan
88 WBWL XXV
Stuart, Fl
772 -260 -1328
wagon 5 speed.
brakes are doing.
Thus far I am at:
SMI Air Force One
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
Toad / Tow Brakes - JERRY SMITH - 11-18-2008 06:18
We have the Air Force One towing a GMC Acadia and have had no problems including towing in the Rockies.
Jerry Smith
2005 450 LXI
wagon 5 speed.
brakes are doing.
Thus far I am at:
SMI Air Force One
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
Toad / Tow Brakes - Pete Masterson - 11-18-2008 06:24
Note that many states have requirements that a towed vehicle (car or
trailer) have a braking system if it is over a certain weight (which
varies by state). In this case, even if your home state does not have
that requirement, if you go into a neighboring state that does... you
can get a very expensive citation.
I note, too, that I've towed my Toyota Camry with the supplemental
brake system turned off (oops!) and I didn't notice any difference in
my coach's handling. That's why I have the sensitivity of the SMI
system I have set at the lowest position, so that the toad brakes
only come in during a very heavy braking situation. It also keeps the
brakes from over heating and wearing excessively.
aeonix1@...
On the road at Lockhart, TX.
On Nov 18, 2008, at 10:23 AM, jim riordan wrote:
> Dan,
> http://www.m-gengineering.com
> <snip>
Toad / Tow Brakes - freewill2008 - 11-18-2008 10:33
Our U S Gear brake has been in place since 2005. It performs great
and provides good feedback, and the toad is always ready to drive.
I was able to integrate the wiring into the 7-pin connector so only
one electric cable is needed for hookup.
The U S Gear does require some installation time, but the result is
worth the effort. A cable run is required from dashboard to rear
bumper of the coach. In my case, a small tail light loom had to be
installed from bumper to bumper in the toad. I also added a junction
box under the toad's hood for a cleaner install.
For toad tail lights I installed additional 1157 sockets and bulbs in
spare holes in the existing lenses so the bus and toad are entirely
independent except for ground and +12V battery connections.
When bus brakes are applied, the additional toad brake lights come
on. When the U S Gear brake activates, the stock toad brake lights
also come on. Turn signals and parking lights are supplied by the
additional 1157 bulbs. After dark or in the rain I usually turn the
toad parking lights on as well.
Bob Griesel '84 FC31 WLII WA, '04 Honda CRV toad
--- In WanderlodgeForum@yahoogroups.com, Wallace Craig
> Wallace Craig
> 95 WLWB 42
> Azle, Texas
> From: drw907
is
> wagon 5 speed.
tow
> brakes are doing.
I
> Thus far I am at:
> SMI Air Force One
> Thanks,
> Dan
> 94 BB BMC 37'
> Albuquerque NM
> Yahoo! Groups Links
Toad / Tow Brakes - Al Scudder - 11-19-2008 10:31
I agree with Jim on the M&G Braking. They have a site just Google and they will give you a list of who they can hook up to. I pull a Tahoe and it works fine. For your info If you use this system you should have two female air plug hookups one on the car onthe Bird and use a double ended male plug for air supply attachment It takes me about 3/4 minutes to hook up and go, brakes and all, but to my knowledge there is no feedback to the coach on the car brakes. another good thing is if you were to change toads, M&G will trade your old pump control (it goes between you master booster and master cylinder) for $400.00 and you are set to go.
Since I have another toad I am looking for a M&G for a 06 Trailblazer anybody have a lead?
Jim if you are reading this IF you were to be pulled over or heaven forbid you got in a accident with you Jeep attached, you are in violation. Not to mention your insurance would be out the window if no brakes on Jeep or any toad that is 1,200 pounds or more. this is the law.
Scooter
2000LX
Ocqueoc, MI
Sent: Tuesday, November 18, 2008 11:24 AM
Subject: Re: [WanderlodgeForum] Toad / Tow Brakes
Dan,
Jim Riordan
88 WBWL XXV
Stuart, Fl
772 -260 -1328
wagon 5 speed.
brakes are doing.
Thus far I am at:
SMI Air Force One
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
Toad / Tow Brakes - jim riordan - 11-19-2008 14:58
Al,
There are differing rules (laws)in different states regarding brakes for towed vehicles. some state don't even require aux brakes.No doubt it is clearly safer and smarter to have a braking system with a breakaway feature. My suburban requires no pump becauce my master cylinder is a vacuum.
Al Scudder wrote:
I agree
Scooter
2000LX
Ocqueoc, MI
Dan,
Jim Riordan
88 WBWL XXV
Stuart, Fl
772 -260 -1328
wagon 5 speed.
brakes are doing.
Thus far I am at:
SMI Air Force One
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
Toad / Tow Brakes - putneyflash@... - 11-20-2008 00:19
You can go to a web site that tells you by state what the requirements are. I think only two states require no braking regardless of weight, 26 states if it is over 3000 pounds you are required.I think the information is on the towmaster tow site
re brake 1984 pt-40 and 1983 Fc-35
RE
-------------- Original message from jim riordan : --------------
Al,
Scooter
2000LX
Ocqueoc, MI
Dan,
Jim Riordan
88 WBWL XXV
Stuart, Fl
772 -260 -1328
wagon 5 speed.
brakes are doing.
Thus far I am at:
SMI Air Force One
Thanks,
Dan
94 BB BMC 37'
Albuquerque NM
