These Thomas pumps for the microphor toilet - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: These Thomas pumps for the microphor toilet (/showthread.php?tid=7414) |
These Thomas pumps for the microphor toilet - luckyron1 - 11-20-2008 23:05 We're now on our 4th one. The last two we got directly from Thomas instead of BB. Now #4 sounds like it's going. I drain it about once every two weeks. What causes them to give out? Ron & Ruth in 2000 LXI in Port Aransas These Thomas pumps for the microphor toilet - Leroy Eckert - 11-21-2008 00:39
These Thomas pumps for the microphor toilet - g_man1146 - 11-21-2008 02:31 Ron & Ruth, The Thomas 12VDC compressor in my bus is set only run when there is no shore power for the 120VAC compressor. This is done by adjusting the ON?OFF pressure switches cut in and cut out points so they won't trigger the small compressor when the large one has power. Another problem that sometimes effects the Thomas compressor is a faulty check valve somewhere in the system that allows the Thomas compressor to loose pressure into other parts of the air system such as the suspension etc. When you drain water from the Thomas compressor's small tank, be sure to have the compressor running. Otherwise water trapped in the compressor itself and in the lines going to it will not drain. A change in the sound it makes running is a sure way to tell there is water in the system. After replacing a couple of check valves mine will hold for weeks of non-use without loosing air. (I shut it off, check the guage and check back weeks later.) It only cycles after several Microphor flushes. BTW, the regulator inside the Microphor is a known source of leaks. I removed mine and put another regulator for the toilet down by the air pressure switches. Now both systems have air regulators with guages making setting the cut in and out pressures easier. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > > We're now on our 4th one. The last two we got directly from Thomas > instead of BB. Now #4 sounds like it's going. I drain it about once > every two weeks. What causes them to give out? > > Ron & Ruth in 2000 LXI in Port Aransas > These Thomas pumps for the microphor toilet - luckyron1 - 11-24-2008 18:35 Thanks for the replies guys. As near as I can tell it's not an air leak issue. I didn't know that the 120 vt compressor had anything to do with it and I've never heard the 120 vt compressor kick in after flushing the toilet, only the Thomas 12 vt. The 12 vt. Thomas pump rarely runs outside of flushing the toilet. It'll typically run after the 2nd or third flush for about 40 seconds. G'man speaks of a switch to turn it on/off, an adjustable cut-in switch? Exactly where is it? Ron & Ruth in 2000 LXI --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > > We're now on our 4th one. The last two we got directly from Thomas > instead of BB. Now #4 sounds like it's going. I drain it about once > every two weeks. What causes them to give out? > > Ron & Ruth in 2000 LXI in Port Aransas > |
