Transmision leak? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Transmision leak? (/showthread.php?tid=742) |
Transmision leak? - Jeff August - 05-30-2005 10:48 Returned home today from our first real trip in our Bird, 900 miles of wheel griping fun.(Chicago will make any trip more stressfull)Looked around after we got home and noticed the housing on the rear of the transmision wet with fluid, it seems to be coming from a 1/4 inch copper tube that points forward from the housing.Also how do I check the fluid level? Is it like a automatic trans. on a car.(In gear with foot on brake)Type of fluid? Thankyou for your help! If we had some manuals with ours it would make some of this easier. Jeff & Michelle August 1980FC35RB Plymouth Wi Transmision leak? - Dan Weaver - 05-30-2005 11:05 Check the FC trans fluid idling in neutral, better when hot than cold. Dan --- In WanderlodgeForum@yahoogroups.com, "Jeff August" wrote: > Returned home today from our first real trip in our Bird, 900 miles of > wheel griping fun.(Chicago will make any trip more stressfull)Looked > around after we got home and noticed the housing on the rear of the > transmision wet with fluid, it seems to be coming from a 1/4 inch > copper tube that points forward from the housing.Also how do I check > the fluid level? Is it like a automatic trans. on a car.(In gear with > foot on brake)Type of fluid? > Thankyou for your help! If we had some manuals with ours it would make > some of this easier. > Jeff & Michelle August > 1980FC35RB > Plymouth Wi |
