3208 stalling problems - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 3208 stalling problems (/showthread.php?tid=748) |
3208 stalling problems - Anthony Louis Pawley - 05-31-2005 12:27 I doubt it is contaminated fuel, this sounds more like a air lock. The problem(or at least as i understand it) became immediately evident after changing out all the filters and such. I would first recheck EVERY gasket and line, things such as a misplaced hose clamp not quite fitted onto the nipple, a cock-eyed gasket, kinked fuel line by moving something or twisting it, all could be significant factors. Of course contaminated fuel is a menace as we all know. I went through this very same problem last week when I was testin' a genset here at work. The easiest way to eliminate the tank as the source of the problem would be to hook up a five gallon can of diesel from the very back end, then start tracing upstream. Or try right before the Racor, which is an easy place to put the can and hose next to the LP door. These methods of deductions will easily(hopefully!) put you onto a path that should show your problem quickly by process of elimination. Last week I changed out my secondary filter, and did not even bleed afterwards, amazingly no air locks, no problems, yes, I was astonished. Also what Jeff Miller said about ether being used is totally correct, BE VERY CAREFUL, starting fluid should only be used as a last ditch effort, and judiciously at that. I only recommend using ether on pos engines, usually where there are gaping holes, literally, in the pistons. Wish you best of luck! Also many apologies to other list members who e-mailed me a couple of weeks back. I have been frantically building marine gensets and propulsion units here in Seattle with lil' time left for fun. Heck, this weekend was spent cleaning my carpet and changing the Earl(oil), couldn't even make it to Stevens Pass to do some great train watching, arrrggghhh! Sincerely, Tony Pawley~Six Rivers Rail Ballard, Wash. 1979 FC33 Cat 3208T p.o.s....... --------------------------------- Do You Yahoo!? Yahoo! Small Business - Try our new Resources site! [Non-text portions of this message have been removed] |
