Oil filters - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Oil filters (/showthread.php?tid=7488) |
Oil filters - amweath - 12-13-2008 04:28 I am changing one of the hydraulic hoses on my PT36. While I have it up I want to change the engine oil and filters. I can see a spin-on filter on the engine and transmission. I see what looks like a cartrige filter to the left of the engine It has two hoses connected to it. I can't see which system it filters. Can anyone help? Art Weatherly Riverside Ca '85 PT36 Oil filters - George Burke - 12-13-2008 16:42 Art, If it has two hoses it is either hydraulic or fuel filter. What engine do you have, 6V92 or 8V92? I havea 8V71 in a Eagle Model 10 and it has two fuel filters, primary and secondary, not sure about yours. Hope I've helped. BTW how do you like your PT36? I may want to get one of those in a few yrs. Regards, George Burke 1977 FC31 Charlotte On Sat, Dec 13, 2008 at 11:28 AM, amweath <"amweatherly@charter.net"> wrote:
Oil filters - amweath - 12-14-2008 05:15 -I have a 6v92. I am very happy with my PT36 although have had nothing else to compare it to. Even though I like the 38 and 40 footers, in the 36 I can get in to almost any park. The filter is not for fuel. They are located elsewhere. Could be hydraulic though. Art Weatherly Riverside Ca '85 PT36 -- In WanderlodgeForum@yahoogroups.com, "George Burke" wrote: > > Art, If it has two hoses it is either hydraulic or fuel filter. What engine > do you have, 6V92 or 8V92? I have a 8V71 in a Eagle Model 10 and it has two > fuel filters, primary and secondary, not sure about yours. Hope I've helped. > BTW how do you like your PT36? I may want to get one of those in a few yrs. > Regards, George Burke 1977 FC31 Charlotte > On Sat, Dec 13, 2008 at 11:28 AM, amweath > > > I am changing one of the hydraulic hoses on my PT36. While I have it up > > I want to change the engine oil and filters. I can see a spin-on > > filter on the engine and transmission. I see what looks like > > a cartrige filter to the left of the engine It has two hoses connected > > to it. I can't see which system it filters. Can anyone help? > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > > > > > Oil filters - Leroy Eckert - 12-14-2008 05:27
Oil filters - timvasqz - 12-14-2008 05:40 Art, Napa has diff schedules of pricesper customers expected $volumn . you canhammer them for a better deal. Agood player for bigtruck parts that wins much of our business now isDrakeParts. There is one in Fontana and Perris. One of the more commonissues that happen when changing old filters is with the seating surface. Old orings and seals hangup and need to bescraped off. I'v pulled filters that had twoorings in the seat???? I wash seating surface with diesel fuel or wd40 or simple greento keep grit out of the new seat. Prior to mounting I put a finger full of grease (backoff Robertson) on the rubber oring or seal to keep it from ripping when tightened. someone told me it is best not to get grease on the threads?? If you need to remove hoses and want to reuse them, re mount the orientation identical. Best to marka reference line. over time the hose plys get set and lose the ability to relax in a new position. a common result is torn ply's and blockage in thehose interior. Damage not outwardly noticeable. Hard to reach filters are hard to remount . One of the fears is cross threading the hardware. Prior to removal check the trajectory of the filter. quite often the filter is not a perfect perpendicular or parallelof a frame, engine or other assumed reference. sometime both axis are off by a degree or 10. GregoryO'Connor ofTim&Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, "George Burke" > > Art, If it has two hoses it is either hydraulic or fuel filter. What engine > do you have, 6V92 or 8V92? I have a 8V71 in a Eagle Model 10 and it has two > fuel filters, primary and secondary, not sure about yours. Hope I've helped. > BTW how do you like your PT36? I may want to get one of those in a few yrs. > Regards, George Burke 1977 FC31 Charlotte > On Sat, Dec 13, 2008 at 11:28 AM, amweath amweatherly@... wrote: > > > I am changing one of the hydraulic hoses on my PT36. While I have it up > > I want to change the engine oil and filters. I can see a spin-on > > filter on the engine and transmission. I see what looks like > > a cartrige filter to the left of the engine It has two hoses connected > > to it. I can't see which system it filters. Can anyone help? > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > > > > > Oil filters - Bob Lawrence - 12-14-2008 14:45 Hi Art, It is the filter for the hydraulic can that powers the power steering the the fan. When the indicator starts going to the red side, I know either the 3 filters in the can need replacing or that filter is plugged up. I change mine with every oil change. Bob Lawrence 84 PT36 Fulltiming presently in San Antonio, Tx. > I am changing one of the hydraulic hoses on my PT36. While I have it up > I want to change the engine oil and filters. I can see a spin-on > filter on the engine and transmission. I see what looks like > a cartrige filter to the left of the engine It has two hoses connected > to it. I can't see which system it filters. Can anyone help? > > Art Weatherly > Riverside Ca > '85 PT36 > Oil filters - Hugh Turner - 12-31-2008 01:25
Oil filters - Hugh Turner - 12-31-2008 01:52
Oil filters - Rob Robinson - 12-31-2008 02:32 Yes the spin-on filter has a high pressure O-ring that must be replaced. This O-ring gets squashed and flattened and cannot be re-used. It is often forgotten. 2008/12/31 Hugh Turner <"ford10076@yahoo.com">
-- Rob, Sue and Joey Robinson 94 WLWB |
