low turbo boost - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: low turbo boost (/showthread.php?tid=757) |
low turbo boost - Mike McMahan - 06-01-2005 14:27 I finally go a chance to check out the low turbo boost/low power on my 89 PT40 8V92. Once I started looking for an exhaust leak, i found the drivers side exhaust manifold was cracked at th very front behind the mounting bolt. I am assuming/hoping that this leak is enough to kill the turbo boost I have been loosing. I'll let you know if this solves the problem when I get it replaced. Don't suppose anyone has a Detroit part number for the manifold. Mike McMahan 89 PT40 low turbo boost - vmarshall@... - 06-01-2005 15:02 Mike, as you know, I also had exhaust leaks to both of my exhaust manifolds and I had also suspected this when I started losing power. I purchased the manifolds plus one pipe that was rusted for $350.00. Stewart & Stevenson gave me a quote of $1,500.00 for new parts. Using my engine number Stewart & Stevenson was able to give me the part numbers. I then started searching the web and inquired on this forum for places to purchase used parts. I purchased one manifold from Diesel Exchange Inc., phone number 1-800-343-7355 and the other one from Scharf & Company, phone number 1- 800-727-4011. I also purchased the rusted manifold pipe from Scharf & Co. Both of these places were very helpful. The main business of Diesel Exchange, Inc. is rebuilding Detroit 8V92 Engines and they are very knowledgeable. Both places guaranteed the parts to be useable and mine were in excellent condition. I removed and installed the manifolds by myself (with the exception of borrowing some tools from my son-in-law and a mechanic I know). While I was at it I removed all of the exhaust and water pipes, took off all of the rust and painted them with rust protection paint. I replaced my turbo charger that I purchased from Stewart & Stevenson for $350.00 (after much complaining about their high prices.) I also changed my coolant and as many hoses as possible. If you decide to do the work yourself you will find that is much easier to replace the manifolds if you remove some of the water pipes. Thus, it makes sense to go ahead and drain all of the coolant. If you have heat blankets on your exhaust pipes I strongly suggest taking them off and inspecting the pipes to make sure they have no rust holes. Stainless steel flex pipe is very reasonable and easy to work with. If I recall, I had to purchase 10 feet of flex pipe at a cost of around $15.00 a foot. I reinstalled the blankets over the stainless steel flex piping but did not put them back on my exhaust manifolds. I feel that the manifolds will cool much better without the blankets. However, I did install thermo material in areas near the passenger's side manifolds in order to protect any nearby wiring. I believe after all was said and done I spent around $2,500.00 in parts. My engine now runs more efficient, has more power and operates about 10 degrees cooler (rarely above 185). I got a lot of satisfaction doing the work myself even though it probably took me five times longer than a person with more knowledge. At least I know every attempt was made to do it correctly and I certainly got to know my coach better. If I can be of any help please let me know. Gene Marshall, Dickinson, Texas 1988 PT40 low turbo boost - randydupree - 06-01-2005 23:43 i will add one thing here,when you pull the manifolds off they are held on with studs and nuts,if the stud unsrews out of the head you will lose coolant out of the bolt hole.randydupree93wb ----- Original Message ----- From: vmarshall@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 01, 2005 11:02 PM Subject: Re: [WanderlodgeForum] low turbo boost Mike, as you know, I also had exhaust leaks to both of my exhaust manifolds and I had also suspected this when I started losing power. I purchased the manifolds plus one pipe that was rusted for $350.00. Stewart & Stevenson gave me a quote of $1,500.00 for new parts. Using my engine number Stewart & Stevenson was able to give me the part numbers. I then started searching the web and inquired on this forum for places to purchase used parts. I purchased one manifold from Diesel Exchange Inc., phone number 1-800-343-7355 and the other one from Scharf & Company, phone number 1- 800-727-4011. I also purchased the rusted manifold pipe from Scharf & Co. Both of these places were very helpful. The main business of Diesel Exchange, Inc. is rebuilding Detroit 8V92 Engines and they are very knowledgeable. Both places guaranteed the parts to be useable and mine were in excellent condition. I removed and installed the manifolds by myself (with the exception of borrowing some tools from my son-in-law and a mechanic I know). While I was at it I removed all of the exhaust and water pipes, took off all of the rust and painted them with rust protection paint. I replaced my turbo charger that I purchased from Stewart & Stevenson for $350.00 (after much complaining about their high prices.) I also changed my coolant and as many hoses as possible. If you decide to do the work yourself you will find that is much easier to replace the manifolds if you remove some of the water pipes. Thus, it makes sense to go ahead and drain all of the coolant. If you have heat blankets on your exhaust pipes I strongly suggest taking them off and inspecting the pipes to make sure they have no rust holes. Stainless steel flex pipe is very reasonable and easy to work with. If I recall, I had to purchase 10 feet of flex pipe at a cost of around $15.00 a foot. I reinstalled the blankets over the stainless steel flex piping but did not put them back on my exhaust manifolds. I feel that the manifolds will cool much better without the blankets. However, I did install thermo material in areas near the passenger's side manifolds in order to protect any nearby wiring. I believe after all was said and done I spent around $2,500.00 in parts. My engine now runs more efficient, has more power and operates about 10 degrees cooler (rarely above 185). I got a lot of satisfaction doing the work myself even though it probably took me five times longer than a person with more knowledge. At least I know every attempt was made to do it correctly and I certainly got to know my coach better. If I can be of any help please let me know. Gene Marshall, Dickinson, Texas 1988 PT40 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] low turbo boost - John Suter - 06-02-2005 00:17 Hi Mike and sorry to hear about the "leak." While I don't want to lecture about this condition being dangerous and a serious fire hazard; among owners are those who have seen what a total "melt-down" from this condition looks like. The coach is not safe to drive in this condition. The lesson for us is to pay very close attention when turbo-boost/power drop without explanation. John Suter --- Mike McMahan <mmcmahan@...> wrote: > I finally go a chance to check out the low turbo > boost/low power on my > 89 PT40 8V92. Once I started looking for an exhaust > leak, i found the > drivers side exhaust manifold was cracked at th very > front behind the > mounting bolt. I am assuming/hoping that this leak > is enough to kill > the turbo boost I have been loosing. I'll let you > know if this solves > the problem when I get it replaced. Don't suppose > anyone has a Detroit > part number for the manifold. Mike McMahan 89 PT40 > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com low turbo boost - Blair - 06-02-2005 01:04 At 07:27 PM 6/1/2005, you wrote: >I finally go a chance to check out the low turbo boost/low power on my >89 PT40 8V92. Once I started looking for an exhaust leak, i found the >drivers side exhaust manifold was cracked at th very front behind the >mounting bolt. I am assuming/hoping that this leak is enough to kill >the turbo boost I have been loosing. I'll let you know if this solves >the problem when I get it replaced. Don't suppose anyone has a Detroit >part number for the manifold. Mike McMahan 89 PT40 > Mike, I replaced both of my exhaust manifolds broken at the same spot..go figure... Blair [Non-text portions of this message have been removed] |
