tv replacment in 88 widebody - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: tv replacment in 88 widebody (/showthread.php?tid=7579) |
tv replacment in 88 widebody - Robert Rahn - 01-13-2009 06:08 we are interested in replacing the tv up front in our 88 pt40. has anyone done this? should we concider the vibration when buying a new one? we want it to be bigger than the original and obviously the shape will be different so we will have to do a lot of modifying of the two overhead cabinets. or maybe just one can change and the other remain. any ideas on brackets? im sure the standard home brackets will be too light for going through montanas bumpy roads. robert rahn 88 pt 40 warner robins ga tv replacment in 88 widebody - pattypape - 01-13-2009 09:49 Robert, I have an 88 FC and Tom S. has an 87 PT38. We used this 19" Polaroid to replace the original 15" Panasonic. It is not the biggest TV but adequate, It required little modification, it is a solid installation ( no worry of falling on your head), and most important we can still access the both over head openings. see Picture, This is probably a cut and paste link. http://groups.yahoo.com/group/wanderlodge/photos/album/1415096421/pic/ 1903544945/view? picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc Or try http://tinyurl.com/6wbqsy Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Robert Rahn" > > we are interested in replacing the tv up front in our 88 pt40. has anyone done this? should > we concider the vibration when buying a new one? we want it to be bigger than the original > and obviously the shape will be different so we will have to do a lot of modifying of the two > overhead cabinets. or maybe just one can change and the other remain. any ideas on > brackets? im sure the standard home brackets will be too light for going through montanas > bumpy roads. > > robert rahn > 88 pt 40 > warner robins ga > tv replacment in 88 widebody - Henry Jay Hannigan - 01-15-2009 09:22 put in a regular LCD in our bird five years ago..no vib problems..Randy Dupree made an aluminium braket for me AND I also safety wired it in....recommend u squeeze in the biggest you can between the cabinets...our little 26 LCD is plenty big enough but we could have squeezed in a 32 but thats when they cost a TON of money!! cheap now.......I would squeeze the 32 inch in today...... good luck......I hear the PLASMA"S get HOT.......... 85 degrees today in Melbourne..in big poker tourney today...need lots of LUCK!!!!! ...crownpoker.com.au/aussiemillions.... Regards, Hank 90SP36 stored in Vegas --- In WanderlodgeForum@yahoogroups.com, "Robert Rahn" > > we are interested in replacing the tv up front in our 88 pt40. has anyone done this? should > we concider the vibration when buying a new one? we want it to be bigger than the original > and obviously the shape will be different so we will have to do a lot of modifying of the two > overhead cabinets. or maybe just one can change and the other remain. any ideas on > brackets? im sure the standard home brackets will be too light for going through montanas > bumpy roads. > > robert rahn > 88 pt 40 > warner robins ga > tv replacment in 88 widebody - Gene Sharp - 01-17-2009 23:56 Added two Sharp TVs. A 26" in the front & a 19" in the rear. To get rid of the heat a small computer fan was added in the back of each. Placed a dimmer switch to control the speed of the fan. TVs are setting on the stands provided and bungee cords holds them in position. They receive more programs & so far, it works. Gene Sharp 93 WL 40 In St Augustine, Fl & not missing the Ohio weather --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > put in a regular LCD in our bird five years ago..no vib > problems..Randy Dupree made an aluminium braket for me AND I also > safety wired it in....recommend u squeeze in the biggest you can > between the cabinets...our little 26 LCD is plenty big enough but we > could have squeezed in a 32 but thats when they cost a TON of money!! > cheap now.......I would squeeze the 32 inch in today...... > good luck......I hear the PLASMA"S get HOT.......... > 85 degrees today in Melbourne..in big poker tourney today...need lots > of LUCK!!!!! ...crownpoker.com.au/aussiemillions.... > Regards, > Hank > 90SP36 stored in Vegas > > > > > --- In WanderlodgeForum@yahoogroups.com, "Robert Rahn" > > > > > we are interested in replacing the tv up front in our 88 pt40. has > anyone done this? should > > we concider the vibration when buying a new one? we want it to be > bigger than the original > > and obviously the shape will be different so we will have to do a > lot of modifying of the two > > overhead cabinets. or maybe just one can change and the other > remain. any ideas on > > brackets? im sure the standard home brackets will be too light for > going through montanas > > bumpy roads. > > > > robert rahn > > 88 pt 40 > > warner robins ga > > > |
