newbie question, where is lower front load center? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: newbie question, where is lower front load center? (/showthread.php?tid=765) |
newbie question, where is lower front load center? - fl_bluebird_1983 - 06-02-2005 16:29 I have a 83fcsb, and I am trying to trouble shoot the spot light. The prints show the power for the light coming from the lower front load center. Where is that located and how do I get to it? I'm not getting any voltage at the back of the light bulb, I hope it's a fuse or a relay problem. It doesn't turn either that appears to be powered from a diffrent fuse, I searched the old posts and I think it might be in the battery compartment. I will check that later. Also does anyone know where to get the GE 4700 bulb from? Thanks Bruce Campbell 83 FC SB newbie question, where is lower front load center? - randydupree - 06-03-2005 00:09 i would check for power at the switch next. randydupree93wb ----- Original Message ----- From: fl_bluebird_1983 To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 03, 2005 12:29 AM Subject: [WanderlodgeForum] newbie question, where is lower front load center? I have a 83fcsb, and I am trying to trouble shoot the spot light. The prints show the power for the light coming from the lower front load center. Where is that located and how do I get to it? I'm not getting any voltage at the back of the light bulb, I hope it's a fuse or a relay problem. It doesn't turn either that appears to be powered from a diffrent fuse, I searched the old posts and I think it might be in the battery compartment. I will check that later. Also does anyone know where to get the GE 4700 bulb from? Thanks Bruce Campbell 83 FC SB ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] newbie question, where is lower front load center? - Jeff Miller - 06-03-2005 01:25 The lower front load center is behind the driver's side headlamp panel. On most '83 FCs, there are three glass fuses mounted above the batteries, for: Spotlight, Refrigerator, and Alarm. Check there also. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > I have a 83fcsb, and I am trying to trouble shoot the spot light. > The prints show the power for the light coming from the lower front > load center. Where is that located and how do I get to it? I'm not > getting any voltage at the back of the light bulb, I hope it's a fuse > or a relay problem. It doesn't turn either that appears to be powered > from a diffrent fuse, I searched the old posts and I think it might be > in the battery compartment. I will check that later. Also does anyone > know where to get the GE 4700 bulb from? > > > Thanks > Bruce Campbell 83 FC SB |
