...and also, what is "reversed polarity" ??? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: ...and also, what is "reversed polarity" ??? (/showthread.php?tid=771) |
...and also, what is "reversed polarity" ??? - erniecarpet@... - 06-04-2005 01:27 In a message dated 6/4/2005 11:53:13 AM Central Standard Time, mrbeebody@... writes: > taking much and offering very little John, please don't ever think that you are asking too much. The forum was started for that reason- to help. Ask away- Ernie 83PT40 in Texas- I had to learn somewhere- this was the place [Non-text portions of this message have been removed] ...and also, what is "reversed polarity" ??? - Adria Haynes - 06-04-2005 04:51 Guys, I have an electrical issue with my bus. I need your help because I'm no good with electricity. The only thing I have ever been able to figure out about electricity in my 29 years is that it hurts when I touch it. Every single time - some more than others. 110 hurts to the elbow. As expected, 220 goes twice as far and hurts to/through the shoulder. Both continue to hurt even after you are able to let go. Again, as expected, 220 hurts twice as long after as the 110 does. I don't recommend making a habit of touching either. Anyways, On my '80, I noticed a few days ago that there were 2 red lights on in the galley above the toaster. They were some kind of electrical gauges and the red lights indicated that I had a "reversed ploarity" condition. Could somebody please help me out with information about this. I have a radio plugged into the same outlet as the bus that never skipped a beat. It's actually a garage radio that I have left on for about 2 years now. I only keep it plugged in to keep the batteries up as they seem to love being dead if left alone. Nothing else is ever run like AC or fridges. Is there somethig wrong with my garage or is it with the bus? Is it bad? Please help if you can. I know I've been a pain in the ass lately taking much and offering very little in return but I assure you all that as soon as I can help anybody out I will be all over it. Thanks again, (and again, and again,) John ...and also, what is "reversed polarity" ??? - George Lowry - 06-04-2005 05:22 Hi John, Keep being a PITA if you need the info.... 8-) I would rather spend time helping you and others than having to go to a funeral.... I am not an expert on all models of the Wanderlodge but do have some experience designing and building electrical systems. It seems like you are speaking about the AC electrical system here. I believe that, in 1980, you only had 30 amp power available to the coaches. The 30 amp power is a three wire system consisting of a hot wire (normally black); A neutral (normally white); And a ground (normally green). If, for some reason the hot and neutral get reversed, it is called "reversed polarity". Now the cause can be from several places. First is to check the outlet where you have the coach plugged in. One of those pocket checkers with three lights is the easiest to use (about $10 at Home Depot). I am assuming that you have your coach plugged into a normal 20 amp outlet in the garage. That checker will tell you if your outlet is correctly wired. If not, get a good electrician to correct it for you. If the outlet is correct, then you have a problem with the coach. It could be the indicating system or the coach wiring could be screwed up. Using that same pocket tester, plug it into various outlets in the coach and see if you get a correct reading. If you do, then it would appear that the indicating system is a problem and you would need to contact PMMI (information in the contacts section of the files.). If you have an indication of a reversed polarity from your pocket tester, I suggest you get a knowledgeable technician/electrician to troubleshoot and correct the problem. If everything is wired correctly (House, coach, etc.), then it takes at least two failures to create a shock hazard. The lights you have indicate that you may have one failure. One more failure of the fail safe design could be dangerous. BTW, this is if everything is done in accordance with Section 551 of the National Electrical Code. Hope this is of some help. The code is designed to protect you if you are not knowledgeable in electrical matters. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Adria Haynes wrote: > Guys, > > I have an electrical issue with my bus. I need your help because > I'm no good with electricity. The only thing I have ever been able > to figure out about electricity in my 29 years is that it hurts when > I touch it. Every single time - some more than others. 110 hurts > to the elbow. As expected, 220 goes twice as far and hurts > to/through the shoulder. Both continue to hurt even after you are > able to let go. Again, as expected, 220 hurts twice as long after > as the 110 does. I don't recommend making a habit of touching > either. > > Anyways, > On my '80, I noticed a few days ago that there were 2 red lights on > in the galley above the toaster. They were some kind of electrical > gauges and the red lights indicated that I had a "reversed ploarity" > condition. Could somebody please help me out with information about > this. I have a radio plugged into the same outlet as the bus that > never skipped a beat. It's actually a garage radio that I have left > on for about 2 years now. I only keep it plugged in to keep the > batteries up as they seem to love being dead if left alone. Nothing > else is ever run like AC or fridges. > > Is there somethig wrong with my garage or is it with the bus? Is it > bad? > > Please help if you can. I know I've been a pain in the ass lately > taking much and offering very little in return but I assure you all > that as soon as I can help anybody out I will be all over it. > > Thanks again, (and again, and again,) > > John > > > > > > > > Yahoo! Groups Links > > > > > > > > > ...and also, what is "reversed polarity" ??? - Adria Haynes - 06-04-2005 05:41 Thanks Geroge. I guess I might know a little more than I thought. I just remembered seeing those lights on one other time last year. The bus was plugged into the house that time. I plugged it into the other socket of the same outlet and they went off - so I forgot about it. This year that outlet had to be swapped out from being fried internally. I had a mini fridge plugged into it when it fried so I just figured that THAT was the problem. The water/electrical panel in the back of my bus actually had been messed with - some of which by me when I bought it - since that panel was out and needed being put back together. It worked fine all last year at all the parks we stayed at without incident so I grew to trust it. I currently am running a 50 amp line inside the bus, but the extension cord I have is such that it lets me plug it into a 30 amp outlet. I also have a 50amp service cord that I use if I can get that level of hookup. My current setup is actually a little embarassing as I have the 50/30 cord hooked to another long extension 30 amp cord, then through a 110 outlet adapter - then through a surge protector, THEN finally into the wall. Shame on me. Thanks again and I'll start messing with the outlets as soon as I get one of them checkers. John --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Hi John, > > Keep being a PITA if you need the info.... 8-) I would rather spend > time helping you and others than having to go to a funeral.... > > I am not an expert on all models of the Wanderlodge but do have some > experience designing and building electrical systems. It seems like > you are speaking about the AC electrical system here. > > I believe that, in 1980, you only had 30 amp power available to the > coaches. The 30 amp power is a three wire system consisting of a hot > wire (normally black); A neutral (normally white); And a ground > (normally green). If, for some reason the hot and neutral get > reversed, it is called "reversed polarity". Now the cause can be from > several places. First is to check the outlet where you have the coach > plugged in. One of those pocket checkers with three lights is the > easiest to use (about $10 at Home Depot). I am assuming that you have > your coach plugged into a normal 20 amp outlet in the garage. That > checker will tell you if your outlet is correctly wired. If not, get a > good electrician to correct it for you. > > If the outlet is correct, then you have a problem with the coach. It > could be the indicating system or the coach wiring could be screwed > up. Using that same pocket tester, plug it into various outlets in the > coach and see if you get a correct reading. If you do, then it would > appear that the indicating system is a problem and you would need to > contact PMMI (information in the contacts section of the files.). If > you have an indication of a reversed polarity from your pocket tester, > I suggest you get a knowledgeable technician/electrician to > troubleshoot and correct the problem. > > If everything is wired correctly (House, coach, etc.), then it takes > at least two failures to create a shock hazard. The lights you have > indicate that you may have one failure. One more failure of the fail > safe design could be dangerous. BTW, this is if everything is done in > accordance with Section 551 of the National Electrical Code. > > Hope this is of some help. The code is designed to protect you if you > are not knowledgeable in electrical matters. > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > Adria Haynes wrote: > > > Guys, > > > > I have an electrical issue with my bus. I need your help because > > I'm no good with electricity. The only thing I have ever been able > > to figure out about electricity in my 29 years is that it hurts when > > I touch it. Every single time - some more than others. 110 hurts > > to the elbow. As expected, 220 goes twice as far and hurts > > to/through the shoulder. Both continue to hurt even after you are > > able to let go. Again, as expected, 220 hurts twice as long after > > as the 110 does. I don't recommend making a habit of touching > > either. > > > > Anyways, > > On my '80, I noticed a few days ago that there were 2 red lights on > > in the galley above the toaster. They were some kind of electrical > > gauges and the red lights indicated that I had a "reversed ploarity" > > condition. Could somebody please help me out with information about > > this. I have a radio plugged into the same outlet as the bus that > > never skipped a beat. It's actually a garage radio that I have left > > on for about 2 years now. I only keep it plugged in to keep the > > batteries up as they seem to love being dead if left alone. Nothing > > else is ever run like AC or fridges. > > > > Is there somethig wrong with my garage or is it with the bus? Is it > > bad? > > > > Please help if you can. I know I've been a pain in the ass lately > > taking much and offering very little in return but I assure you all > > that as soon as I can help anybody out I will be all over it. > > > > Thanks again, (and again, and again,) > > > > John > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > ...and also, what is "reversed polarity" ??? - Tom Warner - 06-04-2005 07:38 John do you have the BB manual (blue binder) for your coach? If so these questions are in there and you need to read it first. Then if you dont understand it I am sure that someone will go thru the lessons so you can understand. The answer is you have something wrong with the electricity in your barn. tom 1982 FC35 Vernon Center,NY At 04:51 PM 6/4/2005 +0000, you wrote: >Guys, > >I have an electrical issue with my bus. I need your help because >I'm no good with electricity. The only thing I have ever been able >to figure out about electricity in my 29 years is that it hurts when >I touch it. Every single time - some more than others. 110 hurts >to the elbow. As expected, 220 goes twice as far and hurts >to/through the shoulder. Both continue to hurt even after you are >able to let go. Again, as expected, 220 hurts twice as long after >as the 110 does. I don't recommend making a habit of touching >either. > >Anyways, >On my '80, I noticed a few days ago that there were 2 red lights on >in the galley above the toaster. They were some kind of electrical >gauges and the red lights indicated that I had a "reversed ploarity" >condition. Could somebody please help me out with information about >this. I have a radio plugged into the same outlet as the bus that >never skipped a beat. It's actually a garage radio that I have left >on for about 2 years now. I only keep it plugged in to keep the >batteries up as they seem to love being dead if left alone. Nothing >else is ever run like AC or fridges. > >Is there somethig wrong with my garage or is it with the bus? Is it >bad? > >Please help if you can. I know I've been a pain in the ass lately >taking much and offering very little in return but I assure you all >that as soon as I can help anybody out I will be all over it. > >Thanks again, (and again, and again,) > >John > > > > > > > >Yahoo! Groups Links > > > > ...and also, what is "reversed polarity" ??? - Jeff Miller - 06-04-2005 15:21 Since your bus is plugged into a 50a/220v-30a/110v-15a/220v adapter chain, along with a long extension cord, ... it is as likely the cords as the power source. The reverse polarity lights are telling you that there is a voltage potential between your neutral and your ground, on both legs, so possibly an open ground. Be sure the outlet ground is connected to ground and that the cords have their ground pins. You could also be plugged into an outlet that has the hot and neutral reversed, on a typical 15a outlet the smaller of the two slots is the hot and the larger is neutral, you should be able to measure 117vac from the small slot to the large slot, and from the small slot to the ground, but no voltage from the ground to the large slot. At the coach end of your power cord, there should be 117vac from each of the arcuate slots to both the metal case of the connector and to the enlarged locking slot, and ~234vac between the two arcuate slots (if plugged into 50a) or 0vac between the two arcuate slots if adapted down to 30a or less. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" <mrbeebody@n...> wrote: > Guys, > > I have an electrical issue with my bus. <<snip>> |
