450 20KW Generator - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 450 20KW Generator (/showthread.php?tid=7728) |
450 20KW Generator - Dan and Cindy Sunderland - 03-03-2009 09:32 Subject: Generator Hi all I had lost AC power from the generator at the Quartzsite rally and yesterday I took the coach to Temecula Valley RV in Southern Ca.. They diagnosed the regulator board bad. Gen only has 480 hours on it. I would not expect this scenario from a powertech gen. Almost a $700 bill. Awaiting the shipping of the board. I wonder if the recall move had anything to do with this. One will never know, as CCW would not take the coach in for service as they can no longer work on them. Don't know why. Bluebird Coachworks should have all the build prints for our coaches and I would like to find a way to get hold of these. Any ideas how? These are very important now and we should use all power to retrieve them. Any more 450 owners out there? Dan Sunderland 2005 450 LXi San Marcos, CA 450 20KW Generator - Leroy A. Eckert - 03-03-2009 09:46 --- In WanderlodgeForum@yahoogroups.com, "Dan and Cindy Sunderland" <86bluebird@...> wrote: Go to posts 41208 and 41211. That should be a start for you. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion > > Subject: Generator > > Hi all > > I had lost AC power from the generator at the Quartzsite rally and yesterday > I took the coach to Temecula Valley RV in Southern Ca.. They diagnosed the > regulator board bad. Gen only has 480 hours on it. I would not expect this > scenario from a powertech gen. Almost a $700 bill. Awaiting the shipping > of the board. > > I wonder if the recall move had anything to do with this. One will never > know, as CCW would not take the coach in for service as they can no longer > work on them. Don't know why. > > Bluebird Coachworks should have all the build prints for our coaches and I > would like to find a way to get hold of these. Any ideas how? > These are very important now and we should use all power to retrieve them. > > Any more 450 owners out there? > > Dan Sunderland > 2005 450 LXi > San Marcos, CA > 450 20KW Generator - David Brady - 03-03-2009 10:42 Dan, Is the regulator mounted w/in the soundproof enclosure with the diesel generator? (I believe it is). I seem to recall someone mentioning that they weren't too pleased with the genny airflow post recall. You may want to check the Powertech manual installation instructions to see if sufficient air flow was provided. Excessive heat could be the cause of failure. (Lots of speculation on my part). David Brady '02 LXi, NC -----Original Message----- 450 20KW Generator - Pete Masterson - 03-03-2009 12:08 I'd certainly take this up with PowerTech to see if there is a warranty that they will honor. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Mar 3, 2009, at 1:32 PM, Dan and Cindy Sunderland wrote:
