Fuse hunt - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fuse hunt (/showthread.php?tid=7731) |
Fuse hunt - jburgessx2 - 03-03-2009 14:47 Well, I'm replacing the stereo in the overhead panel. I've never seen such a rats nest of wires in my life and not a wire tie to be found. So, I spent a good hour sorting the wires, wire tied them together as needed and installed the stereo. In the shuffle, I guess the hot wire must of grounded because it lost power. I put a tester on it and it's no longer hot. I pulled the Blue Box and went through the wiring diagrams. It appears that wire goes to the front load center on the left. I pulled that panel and can't seem to locate any fuses. The drawing shows fuses, but I can't find them. Have I gone blind? Did I miss something? Or, is the drawing wrong? I do have an 85 PT40 but the drawing is for a 36. I suppose someone could have changed the drawings somewhere along the line. Any idea on where the fuse may be located? Anyone with an 85 PT40 ever had fuse issues? As always, thanks. Jerry 85 PT40 Port Hueneme, CA Fuse hunt - Ralph L. Fullenwider - 03-03-2009 15:21 Jerry: On the drivers side, over head cabinets go back to the last small cabinet in the Salon. Open it and you should find 2 large solenoids, relays circuit breakers and behind the breakers, towards the wall are the fuses you seek. This is in the same area as your electronic master switch. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 02:47 AM 3/4/2009 +0000, you wrote: >Well, I'm replacing the stereo in the overhead panel. I've never seen >such a rats nest of wires in my life and not a wire tie to be found. So, >I spent a good hour sorting the wires, wire tied them together as needed >and installed the stereo. In the shuffle, I guess the hot wire must of >grounded because it lost power. I put a tester on it and it's no longer >hot. I pulled the Blue Box and went through the wiring diagrams. It >appears that wire goes to the front load center on the left. I pulled >that panel and can't seem to locate any fuses. The drawing shows fuses, >but I can't find them. > >Have I gone blind? Did I miss something? Or, is the drawing wrong? I do >have an 85 PT40 but the drawing is for a 36. I suppose someone could have >changed the drawings somewhere along the line. > >Any idea on where the fuse may be located? Anyone with an 85 PT40 ever >had fuse issues? > >As always, thanks. > >Jerry >85 PT40 >Port Hueneme, CA > > Fuse hunt - jburgessx2 - 03-03-2009 16:12 Ralph, Thanks a bunch. I didn't look in that cabinet but that's the exact fuse panel I was look for. Jerry 85 PT40 Port Hueneme, CA --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" wrote: > > Jerry: > > On the drivers side, over head cabinets go back to the last small cabinet > in the Salon. Open it and you should find 2 large solenoids, relays circuit > breakers and behind the breakers, towards the wall are the fuses you seek. > This is in the same area as your electronic master switch. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 02:47 AM 3/4/2009 +0000, you wrote: > >Well, I'm replacing the stereo in the overhead panel. I've never seen > >such a rats nest of wires in my life and not a wire tie to be found. So, > >I spent a good hour sorting the wires, wire tied them together as needed > >and installed the stereo. In the shuffle, I guess the hot wire must of > >grounded because it lost power. I put a tester on it and it's no longer > >hot. I pulled the Blue Box and went through the wiring diagrams. It > >appears that wire goes to the front load center on the left. I pulled > >that panel and can't seem to locate any fuses. The drawing shows fuses, > >but I can't find them. > > > >Have I gone blind? Did I miss something? Or, is the drawing wrong? I do > >have an 85 PT40 but the drawing is for a 36. I suppose someone could have > >changed the drawings somewhere along the line. > > > >Any idea on where the fuse may be located? Anyone with an 85 PT40 ever > >had fuse issues? > > > >As always, thanks. > > > >Jerry > >85 PT40 > >Port Hueneme, CA > > > > > |
