FC Owner Uses Sawzall and Sledgehammer to Install New Gauge in EL Panel - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FC Owner Uses Sawzall and Sledgehammer to Install New Gauge in EL Panel (/showthread.php?tid=7737) |
FC Owner Uses Sawzall and Sledgehammer to Install New Gauge in EL Panel - Eric Johnson - 03-05-2009 01:34 OK, just kidding!!! Got Stephen Birtles on the phone yesterday and he convinced me the view wasn't worth the climb on this little project. I'll mount the new gauge somewhere to the side of the existing panel. Let me express my appreciation to everyone that jumped in on this subject. Your desire to keep me from ruining a perfectly good electroluminescent panel is impressive. It felt a little like being talked out of jumping out a 10 story window! That's what makes this forum such a valuable resource for BB owners. I'm very glad I took the time to post the message before getting any deeper into the job. FYI. I took a closer look and, yes, I do have a steel backing on the panel. Eric Johnson 84FC35SBWLII FC Owner Uses Sawzall and Sledgehammer to Install New Gauge in EL Panel - John McGinnis - 03-05-2009 13:52 --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > >It felt a little like being talked out of jumping out a 10 story window! JUMP! JUMP! JUUMMMP!! OK, just kidding!!! John McGinnis, 88FC35 Louisville, KY FC Owner Uses Sawzall and Sledgehammer to Install New Gauge in EL Panel - g_man1146 - 03-06-2009 02:18 > --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > > > > >It felt a little like being talked out of jumping out a 10 story window! Eric, In this case it is "OK" to jump, just not through the electroluminescent lines on the dash! You can drill between them as BB did for all of the gauges and switches but one cut through the EL lines and the panel is toast. Rich D. '99LXi43' CT FC Owner Uses Sawzall and Sledgehammer to Install New Gauge in EL Panel - Stephen Birtles - 03-06-2009 03:12 the el panels were cast in place and then applied to the panel the y may cover the entire panel or just a portion of it There are up to five individual pouches that are applied after to holes are cut There are different configurations that change by year if the light is a little off in the application you would have a failure My advice is dont take the chance take it for what it is worth Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > > > --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" > > > > > > > > >It felt a little like being talked out of jumping out a 10 story window! > > Eric, > > In this case it is "OK" to jump, just not through the electroluminescent lines on the dash! You can drill between them as BB did for all of the gauges and switches but one cut through the EL lines and the panel is toast. > > Rich D. '99LXi43' CT > |
