ddec electronic panel - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: ddec electronic panel (/showthread.php?tid=7751) |
ddec electronic panel - Hisham Amaral - 03-09-2009 23:51 My 97 Wanderlodge DDEC gauge on the instrument panel failed to turn on yesterday as I was preparing to move the coach to our new home at The Great Outdoors, Florida. Has anyone experienced the same problem and if so is there a fuse that popped or has the panel unit gone bad? Any help would greatly be appreciated. Hisham Amaral 97 Wanderlodge TGO Florida for winter. ddec electronic panel - timvasqz - 03-10-2009 01:26 many commercial trucks have cannon fuses off of the battery for the computer. Often it is the center battery for some reason. In the 94pt BB uses a resettable fuse under the bumper cover on the right as you look into the engine compartment. the other 1/2 of the computer problem is the ground. someone may be able to look at KurtS diagrams and find the fuse but the diagram more or less only tells you one exists, not location. Hints from the diagram are things like a number SK@ or S@ or K@ or the number of fuses in a location Remember a fuse is often not the cause . blown fuses are usuly a result of some other cause. A glass fuse will pop and show a problem resettable show intermitting problems. the advantage of a glass pop is you found the path of issue.the resettables with the pop reset buttons are a step up but not built for abuse in an engine compartment. Greg of Tim&Greg --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" > > My 97 Wanderlodge DDEC gauge on the instrument panel failed to turn on yesterday as I was preparing to move the coach to our new home at The Great Outdoors, Florida. Has anyone experienced the same problem and if so is there a fuse that popped or has the panel unit gone bad? Any help would greatly be appreciated. > > Hisham Amaral > 97 Wanderlodge > TGO Florida for winter. > ddec electronic panel - timvasqz - 03-10-2009 02:00 there are two cannon fuse off the battery both for the computer on my trucks, I just checked Greg --- In WanderlodgeForum@yahoogroups.com, "timvasqz" > > many commercial trucks have cannon fuses off of the battery for the computer. Often it is the center battery for some reason. In the 94pt BB uses a resettable fuse under the bumper cover on the right as you look into the engine compartment. the other 1/2 of the computer problem is the ground. > someone may be able to look at KurtS diagrams and find the fuse but the diagram more or less only tells you one exists, not location. Hints from the diagram are things like a number SK@ or S@ or K@ or the number of fuses in a location > Remember a fuse is often not the cause . blown fuses are usuly a result of some other cause. > A glass fuse will pop and show a problem resettable show intermitting problems. the advantage of a glass pop is you found the path of issue.the resettables with the pop reset buttons are a step up but not built for abuse in an engine compartment. > > Greg of Tim&Greg > > --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" > > > > My 97 Wanderlodge DDEC gauge on the instrument panel failed to turn on yesterday as I was preparing to move the coach to our new home at The Great Outdoors, Florida. Has anyone experienced the same problem and if so is there a fuse that popped or has the panel unit gone bad? Any help would greatly be appreciated. > > > > Hisham Amaral > > 97 Wanderlodge > > TGO Florida for winter. > > > |
