Mounting Hardware - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Mounting Hardware (/showthread.php?tid=7762) |
Mounting Hardware - PM7088@... - 03-12-2009 01:46 __There are several ways to approach this. Are the holes mutilated
when you remove the old fasteners? If the are, they can be helicoiled, if they are too bad for that, you can install any of several types of threaded inserts. To see what available, visit a local mill supply house. These are aircraft quality parts, no fear of them failing in proper application. Pete, retired form fastener manufacturing. ______________________________________________________________________ 2. Goat Rails/Catwalk Replace mounting hardware Posted by: "Kurt Horvath" kguns@... bumpersbird Date: Wed Mar 11, 2009 11:08 pm ((PDT)) Curt, Greg, et al, several months ago I recall you guys discussing redoing all the bolts that hold down everything on the roof, I seem to remember at a rally ???? Any way you guys described a Stainless fastener that is inserted into the newly drilled holes, then new bolts were screwed into the inserts. WOULD YA'LL REFRESH MY MEMORIE. I can't find the old posts. My coach was a Florida Coach and it's starting to show especially on the old roof hardware. Kurt Horvath 95 PT 42 10Ac |
