Maybe this will be a good approach? - Printable Version
+--- Thread: Maybe this will be a good approach? (/showthread.php?tid=7811)
Maybe this will be a good approach? - Robin - 03-24-2009 23:05
I did a little homework and read about the "hot skin test". One post there
mentioned simply checking continuity between neutral and ground on the coach
side of the shore power plug (with the power off of course). I've got only 2
Ohms of resistance, should be infinite. Leads me to think that I can do the
same test at the panel, checking continuity between the neutral bus bar and
ground. Pull one white at a time, and when I finally get an open circuit, there
is the problem. I may leave them all disconnected as I proceed to allow for
more than 1 bad circuit, checking again after reconnecting each. Does this
procedure make sense?
John Churchill
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" wrote:
> John,
> There are some active circuits even when all breakers are off. They are
> involved in the circuit that warns you if you turn the ignition on with
> shore power applied. Turning off the breakers only breaks the "hot" side.
> If there is a cross between Neutral and ground it will still be there even
> with the breakers off. That is why I had to disconnect the neutrals in
> order to isolate my problem. There may be a different or better way,but
> this was the only way I could think of.
> - Chuck Wheeler-
> 1982 FC 31SB Fort Worth TX
> _____
> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Robin
> Sent: Tuesday, March 24, 2009 9:19 PM
> Subject: [WanderlodgeForum] gfci still tripping
> way
> Well, I've completely removed both my PowerWatch reverse polarity indicators
> to re-do them. Decided to check the coach with them removed and the GFCI
> still trips when I plug the 30 amp cord in. It trips when I plug it into
> either of the two 30 amp receptacles on the coach. (I do not own a 50 amp
> cord.) Trips even though all the breakers are off including individual
> circuits, main breaker and the separate 30 amp disconnect breakers. If I
> switch the master shore power switch to off, gen or 50 amp it does not trip.
> It does trip if this switch is set at 30 amps. If I start with everything at
> off, then gradually flip switches it seems to barely hold, but if the
> switches are on and I plug in the cord, the GFCI trips, suggesting I am
> right at the trip point.
> One possible problem area is the genset which has been replaced in the past,
> but does not ever seem to have been run prior to my getting the coach.
> I am looking for advice on the proper troubleshooting technique for this
> problem.
> John Churchill
> 1980 FC33
> LARGE MARGE
> Sanibel, FL
Maybe this will be a good approach? - Ernie Ekberg - 03-25-2009 01:29
John, Ralph came up with the hot skin test a few years back. He is the best one to comment on that but he is currently on a fishing trip and has no internet. He will be back on Friday.
83PT40
Wanderlodge
--- On Wed, 3/25/09, Robin wrote:
Subject: [WanderlodgeForum] Maybe this will be a good approach?
Date: Wednesday, March 25, 2009, 5:05 AM
I did a little homework and read about the "hot skin test". One post there mentioned simply checking continuity between neutral and ground on the coach side of the shore power plug (with the power off of course). I've got only 2 Ohms of resistance, should be infinite. Leads me to think that I can do the same test at the panel, checking continuity between the neutral bus bar and ground. Pull one white at a time, and when I finally get an open circuit, there is the problem. I may leave them all disconnected as I proceed to allow for more than 1 bad circuit, checking again after reconnecting each. Does this procedure make sense?
John Churchill
--- In "WanderlodgeForum%40yahoogroups.com", "Chuck Wheeler" wrote:
> John,
> involved
> - Chuck Wheeler-
> _____
> From: "WanderlodgeForum%40yahoogroups.com"
> [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of Robin
> way
> problem.
> John Churchill
> 1980 FC33
> LARGE MARGE
> Sanibel, FL
Maybe this will be a good approach? - Chuck Wheeler - 03-25-2009 02:41
That should work, and was what I was trying to say...guess I do not write too clearly. The reason I disconnected more than one at a time was that I had several small "leaks" adding up. The worst was the front heater, but that is when I discovered that the various monitors all cause a little resistance. I had a red marker with me and when I discovered a circuit that caused the resistance to increase when disconnected I put a red mark on it. When finished I had three circuits open, the heater and the two that fed the power monitor and shore power. The heater and shore power monitor I could clear with repairs, the power monitor by design will draw a small ground current for it's proper operation but this is less than .5ma which is well below the GFI trip point. Since you have your power monitor out, I would think you should be able to clear it all.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Robin
Sent: Wednesday, March 25, 2009 5:06 AM
John Churchill
--- In "WanderlodgeForum%40yahoogroups.com", "Chuck Wheeler" .> wrote:
> John,
> - Chuck Wheeler-
> _____
> way
> problem.
> John Churchill
> 1980 FC33
> LARGE MARGE
> Sanibel, FL
Maybe this will be a good approach? - GARY MINKER - 03-29-2009 11:43
The National Electrical Code calls for a neutral bonding screw in the first disconnect or panel. Look in the disconnect or panels for this screw that is driven through the neutral bar in to the case. It is normal. Coaches are not meant to be plugged in to GFI recepticals because of this. You take a low risk removing the bolt/screw. This is why many newer units only have a 3 conductor cord.
Gary
--- On Wed, 3/25/09, Chuck Wheeler wrote:
Subject: RE: [WanderlodgeForum] Maybe this will be a good approach?
Date: Wednesday, March 25, 2009, 9:41 AM
- Chuck Wheeler-
From: WanderlodgeForum@ yahoogroups. com [mailto:Wanderlodge Forum@yahoogroup s.com] On Behalf Of Robin
John Churchill
--- In WanderlodgeForum@ yahoogroups. com, "Chuck Wheeler" wrote:
> John,
> - Chuck Wheeler-
> _____
> [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of Robin
> way
> problem.
> John Churchill
> 1980 FC33
> LARGE MARGE
> Sanibel, FL
Maybe this will be a good approach? - Robin - 03-29-2009 12:58
Gary-
Thanks for the info, but I am not sure I understand the function. Isn't the NEC
just applicable to houses, etc? In a boat (which I know a bit), the neutral is
kept separate aboard and brought ashore for connection to the ground. In the
main panel of LARGE MARGE, all the whites are together on the buss bar. Are you
saying that the neutral ought to be connected to the ground on the coach? That
does not make sense to me.
John Churchill
1980 FC33
cord.
> Gary
> From: Chuck Wheeler
cause
I
will
.5ma
> - Chuck
> Wheeler-
> Robin
> To:
same
1
> sense?
> John Churchill
> > John,
> are
> with
> side.
> there even
> neutrals in
> better way,but
> - Chuck Wheeler-
> _____
> On Behalf Of Robin
> > way
> indicators
> and the GFCI
> plug it into
> not own a 50 amp
> past,
> coach.
> technique for this
> > problem.
> > John Churchill
> > 1980
> FC33
> > LARGE MARGE
> > Sanibel, FL
Maybe this will be a good approach? - Pete Masterson - 03-29-2009 13:30
The RVIA establishes the standards for RV construction. While most of the NEC applies, the ground and neutral are to be kept separate in an RV. There is a danger than the RV frame (and in the case of a WL) and body can become energized, leading to a chance of electrocution if someone is grounded outside, is touching the body of the coach, and there is an electrical fault. That is one reason to check polarity when hooking up to a power source, reversed polarity can lead to the same dangerous situation.
El Sobrante CA
"aeonix1@mac.com"
On Mar 29, 2009, at 5:58 PM, Robin wrote:
Gary-
Thanks for the info, but I am not sure I understand the function. Isn't the NEC just applicable to houses, etc? In a boat (which I know a bit), the neutral is kept separate aboard and brought ashore for connection to the ground. In the main panel of LARGE MARGE, all the whites are together on the buss bar. Are you saying that the neutral ought to be connected to the ground on the coach? That does not make sense to me.
John Churchill
1980 FC33
Gary
- Chuck
Wheeler-
["Wanderlodge" Forum@yahoogroup s.com] On Behalf Of
Robin
To:
sense?
John Churchill
John,
are
with
side.
there even
neutrals in
better way,but
- Chuck Wheeler-
_____
["WanderlodgeForum@" yahoogroups. com]
On Behalf Of Robin
way
indicators
and the GFCI
plug it into
not own a 50 amp
past,
coach.
technique for this
problem.
John Churchill
1980
FC33
LARGE MARGE
Sanibel, FL
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
Maybe this will be a good approach? - GARY MINKER - 04-07-2009 06:54
Hi,
I almost missed the post. I don't get to read em all. Give me a call and I can go over it all with you.
Gary
561 969-9245
--- On Sun, 3/29/09, Robin wrote:
Subject: [WanderlodgeForum] Re: Maybe this will be a good approach?
Date: Sunday, March 29, 2009, 8:58 PM
Gary-
John Churchill
1980 FC33
> Gary
> From: Chuck Wheeler
> - Chuck
> Wheeler-
> Robin
> To:
> sense?
> John Churchill
> > John,
> are
> with
> side.
> there even
> neutrals in
> better way,but
> - Chuck Wheeler-
> _____
> [mailto:Wanderlodge Forum@ yahoogroups. com]
> On Behalf Of Robin
> > way
> indicators
> and the GFCI
> plug it into
> not own a 50 amp
> past,
> coach.
> technique for this
> > problem.
> > John Churchill
> > 1980
> FC33
> > LARGE MARGE
> > Sanibel, FL
Maybe this will be a good approach? - GARY MINKER - 04-07-2009 06:58
Hi Pete
Reversing the polarity on a 50 amp plug in is about 99.9% impossible without tripping a breaker. A single 30 or 15 perhaps but again, the breaker kicks in. Even twin 30's is tough without blowing a breaker unless it is an old federal 2 pole with only 1 side protected which is what ran them out of business.
--- On Sun, 3/29/09, Pete Masterson wrote:
Subject: Re: [WanderlodgeForum] Re: Maybe this will be a good approach?
Date: Sunday, March 29, 2009, 9:30 PM
El Sobrante CA
Gary-
John Churchill
1980 FC33
Gary
and the two that
- Chuck
Wheeler-
yahoogroups. com
Robin
To:
sense?
John Churchill
John,
are
with
"hot"
side.
there even
neutrals in
better way,but
- Chuck
Wheeler-
_____
[mailto:WanderlodgeF orum@ yahoogroups. com]
On Behalf Of Robin
way
indicators
and the GFCI
plug it into
not own a 50 amp
past,
coach.
technique for this
problem.
John Churchill
1980
FC33
LARGE MARGE
Sanibel, FL
Yahoo! Groups Links
http://groups. yahoo.com/ group/Wanderlodg eForum/
http://groups. yahoo.com/ group/Wanderlodg eForum/join
mailto:WanderlodgeF orum-digest@ yahoogroups. com
mailto:WanderlodgeF orum-fullfeature d@yahoogroups. com
WanderlodgeForum- unsubscribe@ yahoogroups. com
http://docs. yahoo.com/ info/terms/
Maybe this will be a good approach? - timvasqz - 04-07-2009 11:23
many inverter and gensets have internal grounding to neutral paths. so if the
transfer switch does only the two hot legs an additional relay is needed to
unbond the genset or inverter ground to neutral ( if it is bonded during use). I
think Magnum has this worked out with internal relays. or that is their sales
pitch.
I was concerned about the inverter charger bonding when I added a new unit and
couldnt get a good answer so I sent the updated bus into a good boat shop for a
look over. you are not going to get a good answer here because ther are many
variables and changed configurations in these old units. and the idea of 'to
bond' or 'not to bond' while on genset/invert has no standard.
Gregory of Tim&Greg
> Hi,
> Gary
> 561 969-9245
> From: Robin
> Gary-
> John Churchill
> 1980 FC33
cord.
> > Gary
> > From: Chuck Wheeler
cause
disconnected I
will
.5ma
> > - Chuck
> > Wheeler-
> > Robin
> > To:
same
ground.
than 1
make
> > sense?
> > John Churchill
> > > John,
> > are
> > with
> > side.
> > there even
> > neutrals in
> > better way,but
> > - Chuck Wheeler-
> > _____
> > On Behalf Of Robin
> > > way
> > indicators
> > and the GFCI
> > plug it into
> > not own a 50 amp
> > past,
> > coach.
> > technique for this
> > > problem.
> > > John Churchill
> > > 1980
> > FC33
> > > LARGE MARGE
> > > Sanibel, FL
