Propane safety - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Propane safety (/showthread.php?tid=7815) |
Propane safety - Ryan Wright - 03-25-2009 06:33 Hi folks, Quick safety check: I replaced my Dometic fridge with a slightly taller Norcold. In doing so, the fridge has been lowered about 4 inches. This puts the bottom of the vent on the side of the coach about 4 inches above the bottom of the fridge. Do I need to be concerned about propane build-up in the event of a leak? As propane is heavier than air, it would tend to settle down into this space, rather than flow out the vent. On the other hand, there is a huge vent there and a lot of air circulation between this space and the outside world - even the slightest breeze flows in there with ease, and the actual available cubic feet for propane to settle is quite small with the fridge installed. I did build a new shelf for the fridge to sit on and sealed the wood with a layer of clear coat and a spray-on rubber top coat designed for vehicle undercoating. All edges of that shelf and all other gaps in that compartment have been sealed with a thick bead of 50 year outdoor rated caulking, so leakage of propane and/or combustion gases into the coach should be eliminated. The only remaining concern, therefore, is whether propane is capable of gathering around the bottom portion of the fridge in that compartment and causing a fire or explosion. I don't believe it is due to the relatively large amount of outside air flowing through that vent at any given moment, and given the large openings to the outside world I can't see an explosion happening but I felt it would be prudent to ask here, just to be on the safe side. -Ryan '86 PT-40 8V92 Propane safety - Stephen Birtles - 03-25-2009 07:25 Blue bird did a modification adding a clam shell vent to out side of the coach directly underneath the vent as an additional safety feature Stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, Ryan Wright > > Hi folks, > > Quick safety check: I replaced my Dometic fridge with a slightly > taller Norcold. In doing so, the fridge has been lowered about 4 > inches. This puts the bottom of the vent on the side of the coach > about 4 inches above the bottom of the fridge. > > Do I need to be concerned about propane build-up in the event of a > leak? As propane is heavier than air, it would tend to settle down > into this space, rather than flow out the vent. On the other hand, > there is a huge vent there and a lot of air circulation between this > space and the outside world - even the slightest breeze flows in there > with ease, and the actual available cubic feet for propane to settle > is quite small with the fridge installed. > > I did build a new shelf for the fridge to sit on and sealed the wood > with a layer of clear coat and a spray-on rubber top coat designed for > vehicle undercoating. All edges of that shelf and all other gaps in > that compartment have been sealed with a thick bead of 50 year outdoor > rated caulking, so leakage of propane and/or combustion gases into the > coach should be eliminated. The only remaining concern, therefore, is > whether propane is capable of gathering around the bottom portion of > the fridge in that compartment and causing a fire or explosion. I > don't believe it is due to the relatively large amount of outside air > flowing through that vent at any given moment, and given the large > openings to the outside world I can't see an explosion happening but I > felt it would be prudent to ask here, just to be on the safe side. > > -Ryan > '86 PT-40 8V92 > Propane safety - Wilhelmus Schreurs - 03-26-2009 05:08 Ryan:
Drill another hole and put another clamshell like BB did originally, except put this one at the lowest point that you have now. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada Now with a new friend-happy design! Try the new Yahoo! Canada Messenger |
