changing out front TV in 1988 PT40 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: changing out front TV in 1988 PT40 (/showthread.php?tid=7827) |
changing out front TV in 1988 PT40 - Robert Rahn - 03-29-2009 09:22 Hello to all, We are looking into changing out the front old Panasonic TV in our bus to a newer flat pannel and were wondering if anyone had any experience with tapping into the current sound how it is set up. Currently the only sound from the front tv comes out of the speakers by the sofa and dinette. Found that BB had drilled a hole in back of old tv and tapped into old tv speakers and ran a wire that looks like it goes to 2 separate wires that goto the coach speakers which also are the ones for the radio. Am I making any sense? Can we get a new tv and use composite cables and tap into these same wires so we can use the bigger speakers? What is the best way to do this? Does anyone know if the current setup uses the dash stereo amp or if there is a separate amp? Any help, advice or suggestions would be greatly appreciated! thanks so much! Teri Rahn 1988 PT40 changing out front TV in 1988 PT40 - Curt Sprenger - 03-29-2009 10:53 Teri, Assuming the new TV has a Headphone Jack, it can be used to get the sound to the speakers. The Head Phone output is weak so the sound should go through an amp. I had already replaced the amp system in our coach so I used Y-adapters to connect the Headphone Jack wires to the amp. Curt Sprenger On Sun, Mar 29, 2009 at 2:22 PM, Robert Rahn <"chaunceyboyblu@hotmail.com"> wrote:
changing out front TV in 1988 PT40 - Fred Bellows - 03-29-2009 13:46 > On Sun, Mar 29, 2009 at 2:22 PM, Robert Rahn Hello to all, > > We are looking into changing out the front old Panasonic TV in our bus to a > > newer flat pannel and were wondering if anyone had any experience with > > tapping into the current sound how it is set up. > > > > Currently the only sound from the front tv comes out of the speakers by the > > sofa and dinette.... My '90SP was set up similarly. I ran a cable down to the dash from the TV's line out jacks in case we want to play it through the stereo, however, we have just used the speakers built into the TV so far, as this gives the best imaging (stereo phenomenon) and localizing (having the sound come from the image), and sounds great. I posted some picts of our modification in our picasa photo album, but I didn't have one of the TV mount installed before hanging the TV :-( If you run any cables through the "A" pillar, be sure to also run any you might need in the future as well. Sincerely, Fred & Wendy Bellows 90SP Queen Creek, AZ (basically Phx) "Maunder Maximum" nytexcel@... photo album of coach projects and mods: http://picasaweb.google.com/geefred/MaunderMaximum# |
